Truck Manifold Turbo Crossover Pipe COATED!
I am selling my old setup to make a t-6 setup. Uses truck manifolds, keeps swaybar and stock radiator. You just have to flip your stock fans to the front .Pipe has flanges for the manifolds,Tial 44mm wastgate,T-4 turbo,and 2 O2 sensor bungs. Pipe is ceramic coated with the highest temp available inside and out. Pipe size is 2 1/2" All TIG welded. Used for 1500 miles. I will also throw in a 3" down tube with v-band clamp! Basically brand new. All you need to complete the hotside is truck manifolds.$1000 OBO
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG][IMG]
[/IMG][IMG]
[/IMG] Last edited by phildo; Nov 4, 2007 at 03:24 PM.
you mentioned you had to flip your stock fans to the front with these pipes. They are puller type fans so how does that make sense they would be backwards wouldnt they?? Maybe im missing something??
