Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > VEHICLE SPECIFIC FORUMS > 2010 Camaro
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
2010 Camaro
Discuss the 5th generation Camaro
Sponsored by
School of Automotive Machinists
Click Here
Old 10-10-2009, 09:32 PM   #1
Closed ex-Sponsor Account
Trader Rating: 11
Default 6L80 TM removal?
The Camaro was tuned with HP Tuners and the TM was removed. At the track it spins going into 2nd and 3rd. I want to fix that so it doesn't spin and make it safer at the track and maybe pick up a little time too. I have EFI Live and want to soften the shifts a little.
Any tuners out there that can help?
Here are some vids so you can see what I mean by spinning on the 1-2 shift and 2-3 shift.
Thanks, any help would be appreciated.
BTW, it is a 2010 Camaro L99 6spd Auto.
SRT10KLLR is offline   Reply With Quote
Old 10-10-2009, 10:00 PM   #2
HaulinHawk's Avatar
Trader Rating: 0
Why wouldnt u just put a stickier set of tires on it at the track?Get a second set of rims with some mt drag radials.Check out OrangeChevyII setup .I believe he's runnin a 18' corvette rim with a dr on it.
__________________
02 Pontiac Firehawk#11 \G5X3 \ Lid\ Dynatech LT\ Ory\ Asp\ Corsa\ YankSS4000\ Transgo\ B&M cooler\ BMR Susp\ Moser 12 Bolt\4.10s\ FAST 90\PTM 90TB\CUTOUT\ DYNOJET 384HP-357TQ CAM ONLY 11.15@121mph 1.52 60FT
HaulinHawk is offline   Reply With Quote
Old 10-10-2009, 10:23 PM   #3
Trader Rating: 11
Those runs were with Nitto 555R DR's on stock wheels. Also, I even tried lowering the PSI to 15 to no avail. I should be able to adjust the shifting in the TCM. Just need to know what parameters to change.
Old 10-11-2009, 07:20 AM   #4
HaulinHawk's Avatar
Trader Rating: 0
Im assuming a 20' rim correct?Your gonna need to run a 18' rim and a mt dr to get everything out of the car.Nittos on a 20' rim arent gonna cut it,a 20' rim or bigger just isnt condusive to good track times.Programing more tm into the equation,is only covering up the problem and takin away the potential of the car.Put a really good tire on it,play with the shift points,an try diff launch rpms to see what it likes.
__________________
Old 10-11-2009, 08:17 AM   #5
Señor Administrator™
unit213's Avatar
Trader Rating: 0
You want to add the torque management back into the tune?
I have a buddy that run's 10.80's on a 20" Nitto drag radial. They are great tires
for a 20". I'm sure you know that you have to do a John Force style burnout to really
get some heat into those Nittos.
__________________
630rwhp | 600rwtq | Fquick
Modified by Livernois Motorsports
unit213 is offline   Reply With Quote
Old 10-11-2009, 12:03 PM   #6
Trader Rating: 11
It dead hooks of the line but when going into 2nd it kicks to the side while spinning. The track was prepped good on the start but only for the first 60ft or so. I did not want to go any lower than 15 PSI in the tires. I heat the tires up by spinning until they grab and shoot the car forward then try a dry burnout. If it doesn't spin I know the tires are ready if not I do another burnout.
I can try 18" wheels with other DR's but it will not help me on the street. It would still shift very harsh. If I could just reduce the amount of TM taken out it would be perfect.
Old 10-12-2009, 08:10 AM   #7
HaulinHawk's Avatar
Trader Rating: 0
I never really had alot of success with nittos at the track.But u are correct,i think if u do a bigger/longer burnout at the track ;ala johforce style they will work better for u.You gotta really put alot of heat in these tires,for them to work.I was assumin u were talkin about a track setup,thats why i sugested that rim/tire setup.I still dont think u wanna add tm back in .You will be takin potential out of the car.Maybe check out bmr for there new susp parts.Prolly will help ya hook .
__________________
Old 10-12-2009, 02:27 PM   #8
someday's Avatar
Trader Rating: 0
y did it show u going 13.0 @ 178??? they use kilometers/hr in Cali??
i'd love to have a car that chirped in 2nd and 3rd...
__________________
'04 Monte Carlo SS/sc... Red/silver exterior, Black interior... drilled/slotted rotors, K&N AirCharger, 3" OR DP, Intense pcm, 180 thermostat...
'04 HD XL1200C... Blue/Orange flames, Bobtail rear fender, Custom front fender, 6 spoke front wheel, Chrome everything... Rinehart 2-1, Mid-Controls, Deuce Wheel w/ 170/60x17, Ness BS, 74hp/85tq... For Sale
someday is offline   Reply With Quote
Tags
23, 555r, 6l80, car, club, correct, drag, drive, harsh, hp, nitto, psi, radial, rating, roval, shift, tms
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
