Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Advanced Engineering Tech
Old 11-30-2008, 10:42 AM   #1
mebuildit's Avatar
Trader Rating: 0
Default Installing 8 O2 sensors which ones?
I'm having Texas Speed build me a LSX 454 and I would like to put O2 sensors on each exhaust to better tune the car. My question is which O2 sensors are the best for this type of set up?
__________________
It's easier to ask for forgiveness than permission!
mebuildit is online now   Reply With Quote
Old 11-30-2008, 02:31 PM   #2
ddnspider's Avatar
Trader Rating: 17
as far as i know there isnt a system out there that can use 8 O2 sensors.You can either use the FAST dual wideband setup to monitor each bank.....OR get 1 of the systems with 8 EGT probes.
__________________
Erik Koenig built 383|Phamspeed T76GTS|built T56 w/ Southbend clutch|WS9 hood|3800+lb club
welcome to the internet.....where everyone knows more about your setup than you do
ddnspider is offline   Reply With Quote
Old 11-30-2008, 02:34 PM   #3
Blacklightning744's Avatar
Trader Rating: 0
8 O2 sensors i think is overkill, u can still get extremely accurate readings from just 2 widebands, one in each pipe. thats what i would do n e way.
__________________
2002 WS6 M6. Fast Toys Lid, Smooth Bellow, Jet-Hot Longtube Headers 1 7/8, Jet-Hot ORY, SLP Loudmouth 1, LS7 Clutch and Flywheel, Eaton Diff, Richmond 3.73's, Powerbond Underdrive Pulley,LS6 Oil Pump, LS2 Timing Chain and Sprockets, HP Tuned, Short Throw Shifter, SLP Subframe Connectors, HP Tuned.
SPEC Super Twin Disc for sale,8 LS2 Engine Valves for sale, MUST SELL
Blacklightning744 is offline   Reply With Quote
Old 12-01-2008, 09:31 AM   #4
LS1TECH Sponsor
Schwanke Engines's Avatar
Trader Rating: 1
Send a message via Yahoo to Schwanke Engines
Well, I guess if you are going to go that route, I would recommend the AFM 1000 from ECM. You could then get a good data logging system from Racepak. Or, you could go with their plug and play widebands.
What is the reasoning behind doing this anyways? Unless you are using a very hi tech ECM that has the ability to tune cylinder to cylinder, you might just be spending money you don't have to be.
Plus, to do that you need to have the O2 sensors in the exact same location on each pipe, otherwise you are really just guessing. I know when I have dyno'd with 8 O2 sensors, you are looking for cylinder balance for design more so than tuning. But hey, to each his own I guess.
__________________
Mark Sanderson 800-423-6571 www.schwankeshortblocks.com
PCM Reflash - $300.00 1.5 to 2 mpg avg. gain on Trucks - Flex Fuel Option
Tune on Chassis Dyno - $175.00 per hour
8 years of endurance development on the LS series engines.
Schwanke Engines is offline   Reply With Quote
Old 12-01-2008, 10:15 AM   #5
mebuildit's Avatar
Trader Rating: 0
My plan is to run a RacePak system logger with a Haltek system. I saw this on another car and thought it would be a nice way to tune each cyl. individually. I just don't know how it's done yet.
I know it's not necessary, but I'm a data kind of guy and like to tinker with stuff.
__________________
Old 12-01-2008, 12:31 PM   #6
JL ws-6's Avatar
Trader Rating: 38
Send a message via AIM to JL ws-6 Send a message via Yahoo to JL ws-6
I think that 8 EGT probes would be your best bet rather then going with 8 wideband sensors, the packaging woudl be alot easier, and it's gonna give you the cylinder balance check that you are looking for.
__________________
Thanks to Eastside Performane, Exstreme Engineering, S-K Speed
http://s110.photobucket.com/albums/n...rrent=JL96.flv
Quote:
Originally Posted by J-Rod
First off Hp/L is ricer math, and is pretty much useless
JL ws-6 is offline   Reply With Quote
Old 12-01-2008, 04:41 PM   #7
Moderator
jimmyblue's Avatar
Trader Rating: 11
Narrowbands are not going to help you tune for
power, and wideband LSU4 type are not going
to tolerate close-in temperatures. I think a pair,
at the collector of each side, and count on (work
to get) component balance intra-bank is your bet.
Don't know what the deal is with the expensive
wideband sensors, re max temperature, but bet
you don't want 8 of those at >$300 a pop.
__________________
2002 SS convertible
SLP Blackwing lid, 85mm MAF, 85mm Professional Products intake & TB, SLP CME, Jet-Hot LTs/ORY, McCord cutout, Fuddle 3500/2.0, GM truck pan, '98 flexplate, 3.42s, T-2R, MAC cover, welded tubes, Hotchkiss PHR, springs; BMR bolt-in LCA brackets, K-member; UMI TA, boxed stock 1LE LCAs, SLP Bilstein / Gabriel air shocks (F/R); Strano 35/22 sway bars, 224/224 116 cam, 160F 'stat, HPTuners 12.6@112MPH
jimmyblue is offline   Reply With Quote
Old 12-03-2008, 12:41 PM   #8
YellowToy/A's Avatar
Trader Rating: 1
Send a message via Yahoo to YellowToy/A
The only way I know to change to A/F ration in each cylinder is the port the intake or the head. Good luck with that.
__________________
2002 Collector Edition Trans Am 140 of 2000
comp cam with XER 224 228 on a 110 LSA +2, AFR 205 heads, QTP headers, DA Konis with ground control 400 lb/in springs, LCAs, PB, TA, STB, HPT tuning and Midwest Chassis & Performance Fabed 9in
"A SS looks like it could kick your ass if it wanted to, but a WS6 looks like it's coming over to do it!"
YellowToy/A is offline   Reply With Quote
Old 12-03-2008, 01:51 PM   #9
RoAdRaGe912's Avatar
Trader Rating: 0
Quote:
I believe most aftermarket control systems allow for individual cylinder injector pulse tuning.
__________________
Dead- 94 Z28
Built from the dead- 95 body, 94 powertrain
RoAdRaGe912 is offline   Reply With Quote
Old 12-03-2008, 02:25 PM   #10
JL ws-6's Avatar
Trader Rating: 38
BS3 definately allows the fueling for each cylinder to be controlled seperately, and if you're looking at nitrous, directport setups can also allow for tune adjustments for each cylinder.
__________________
Old 12-04-2008, 11:46 AM   #11
mebuildit's Avatar
Trader Rating: 0
Quote:
Thanks for the info. Although I have to admit, this whole electronic ignition stuff and acronyms I'm a little behind on. What is the BS3?
See I come from the drag racing world so I know split dominators Hogans manifolds, 1200+hp stuff. So this set up for me is all new. I'm pretty computer Knowledgeable but I need to get a grasp on this stuff.
Thanks in advance for the Laymen’s terms.
Greg
__________________
Old 12-04-2008, 12:30 PM   #12
Trader Rating: 0
http://www.bigstuff3.com/
__________________
Dead- 94 Z28
Old 12-04-2008, 03:45 PM   #13
Moderator
jimmyblue's Avatar
Trader Rating: 11
If I were trying to balance fueling beyond what a
matched set of injectors provides, I think I'd look
at the O2 sensor waveform real time, try and
distinguish the individual cylinders' "plateaus" and
observe whether you are pushing the one being
twiddled, closer to or further from center. In the
collector this ought to work reasonably at lower
RPM, maybe too much blending at higher RPM.
But have seen some SAE papers which kind of go
that way, looking at individual-cylinder fuel
management on the cheap (syncing the O2
sampling to time-of-flight etc.).
__________________
2002 SS convertible
Old 12-04-2008, 04:08 PM   #14
Trader Rating: 4
You can't put wideband O2 sensors to close to the exhaust port, so keep that in mind.
Jim
__________________
Don't bring a knife to a gunfight.
http://home.mindspring.com/~jim_fisk/sitebuildercontent/sitebuilderpictures/4dr_test_sig1.jpg
Half-Assed = Half Fast.
DeltaT is offline   Reply With Quote
Old 12-04-2008, 07:34 PM   #15
njc.corp's Avatar
Trader Rating: 0
Smile
x2-egts would show a nice heat balance between each cyclinder-
8 o2s is like f1 stuff-dont even think they run that on race day-all egts-
more power,and trq u make the more heat something will make-
egts^^^ is what u want-
i have tried most 02 kits out their and most of them are within each other-
they just got some cool things to spice them up a bit which makes them different from one and other-they read the same-
u can get a 4 channel 02 kit from racepack for $2000.00 per bank $2,000x 2=$4k
or a nice fast dual kit for about what-450-650 with all the features-
i know the more data u have the better the job can be has long as u know what to do with that data-but sometimes it leads into a wrong direction because the product is not needed for the job
egts all the way unless u really keen on the 8 o2's and got cash-
would be a pain to work on if the car had no room
What car is this going in?
Thanks
Nick--
njc.corp is offline   Reply With Quote
Old 12-04-2008, 07:40 PM   #16
njc.corp's Avatar
Trader Rating: 0
Smile
Quote:
Jim
yes-jim- i was told that not due to the heat temps but the carbon depoists getting stuck on the sensor-
a freind of mine tried that and got about 1 month out of a sensor-
Old 12-05-2008, 10:59 AM   #17
mebuildit's Avatar
Trader Rating: 0
I just want to thank everyone for their input. I have tuned to the EGT's before while drag racing and it does work quite well. I just thought that using O2 sensors might be a little more informative?
Either way, thanks again! I will probably do the EGT's due to cost. I am going to be putting on a RacePak v300 on the car, so if I do ever get some cash together later on I could put on the o2 sensors for something to screw with.
Like I had said before I like all of that computer work to tune, it's similar to something I do for work. I test missile guildance systems for a living and we use a data acquisition system that almost mimicks a RacePak graph.
Anyways, thanks guys...keep up the good work. I really like this site.
__________________
Old 12-05-2008, 12:48 PM   #18
the_merv's Avatar
Trader Rating: 24
I saw this title, I was wondering where the hell 8 of them were going..lol
__________________
1995 CAMARO "STRIPPER" Z28 HARDTOP
WEIGHT: 3300 | 402ci LQ4/L92 STROKER | MOSER 9 INCH
COMING SOON: T56 | TEXTRALIA OZ 700 | B&M SHORT SHIFT
the_merv is online now   Reply With Quote
Old 12-06-2008, 09:58 PM   #19
njc.corp's Avatar
Trader Rating: 0
Question
which one u getting the racepak v300 or the v300sd?
Old 12-06-2008, 10:37 PM   #20
mebuildit's Avatar
Trader Rating: 0
Quote:
Not sure? What is the difference between the two?
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Alphabetical sponsor list
Speed Engineering
Midwest Chassis
Diablo Sport
Advanced Induction
Southern Car Parts
Edelbrock
Pavlock Performance
Kee Audio
Horse Power Engineering
Comp Cams
Circle-D Converters
Speed South
Speed Inc.
Xtreme Powersports
MPH Motorsports
Rapid Motorsports
Air Flow Research
WS6 Store
Full Throttle Speed
Canadian Performance
Mast Motorsports
Century Transmission
Six Speeds Inc.
VFN Fiberglass
PerformaBuilt Transmissions
Strano Performance Parts
Forced Inductions
CarsDirect
Wolfe Racecraft
Dyno Tune
Discount Tire
Masport Speedshop
Slowhalk
LSx Tune
CompStar Components
Straightline Performance
TomZ Wheels
World Products
Finish Line Transmissions
Quick Time Performance
TT Performance
Speed Tweekerz
Late Model Engines
Livernois Motorsports
Afterthoughts Auto
LG Motorsports
Fuel Air Spark Technology
Redline Motorsports
American Racing headers
Yank Torque Converters
Shock Warehouse
EFI Alchemy
HP Tuners
Nano Nitrous
Nitrous Express
Vengeance Racing
Faster Proms
Maryland Speed
Redline Goods
BMR Suspension
Xtreme Horsepower
Performance Oil Technology
UMI Performance
Painless Performance
SJM Manufacturing
Kooks Custom Headers
Tick Performance
Spohn Performance
Nasty Performance
Speartech Fuel Injection Sys
Competition Clutch
Nitro Dave's Nitrous Outlet
Tropi-Care
Fast Toys
Total Engine Airflow
Harris Speedworks
Madman Racing
Patriot Performance
New Era Performance
Finish Line Performance
Race Engine Development
Futral Motorsports
Lonnies Performance
Nitrous Oxide Systems
Late Model Racecraft
School of Automotive Machinists
APS Turbo
Auto Parts Firm Online
Katech Engine Development
Cartek Racing
West Coast Cylinder Head
Car Shop Inc
Trifecta Performance
Cunningham Motorsports
Specialized Stainless
Race Proven Motorsports
Exotic Performance Plus
Racetronix Fuel Systems
Texas Speed & Performance
SLP
ByunSpeed
G-Force Motorsports
Burkhart Chassis
LM Performance
Scoggin-Dickey Parts Center
Performance Auto Fabrication
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
