Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Appearance & Detailing
Old 09-04-2007, 04:21 PM   #1
My Garage
SSCamaroChick's Avatar
Trader Rating: 1
Default Foggy yellow headlights - sanding?
I read the thread on fixing Camaro headlights that are foggy and yellow. Well both headlights on one of my Camaros are fogged up and look terrible! I read that you're supposed to sand them then polish them. OK, this is a dumb question, but what do you sand them with, and do I sand the inside or the outside? It sounds like a way better alternative to buying new ones.
Thanks!
SSCamaroChick is offline   Reply With Quote
Old 09-04-2007, 05:01 PM   #2
My Garage
LS1BLKSS's Avatar
Trader Rating: 28
Quote:
Thanks!
I wet sand these Honda headlights with 1000 and polished them after i was done they looked like brand new!... I did this with my Camaro's headlights didn't look so good... the yellowness came off but they don't look clear you. should try to sand them down with 1000 Wet then use a high speed buffer and polish them up pretty good and see what you come up with if they don't look too good after you done then its time to buy some new ones!
LS1BLKSS is offline   Reply With Quote
Old 09-04-2007, 05:05 PM   #3
My Garage
Loochy88's Avatar
Trader Rating: 2
sand them with wetsand paper and water. you can find sandpaper from 500 to 2000 at your local wal mart. work progressively from about 600 to 2000. thats what i did. take time with each step in the paper.
once you have them well wetsanded out to 2000 grit get some sort of polish. I cant remember what i used, but i use mother's aluminum polish for about everything. there is also a plastic polish that meguiars makes that would work great for finishing them off after a slightly more abrasive polish. to make the polishing part go quicker you could buy some sort of buffing wheel and attach it to a bench grinder.
__________________
http://i65.photobucket.com/albums/h2...8/100_6047.jpg
1996 V6 Camaro
1999 Z28
Loochy88 is offline   Reply With Quote
Old 09-05-2007, 12:57 AM   #4
My Garage
Trader Rating: 10
Did this a while ago with a buddy he bought a crappy yellow set and after a bit of work they looked better thatn the near mint ones he had on his car, the set we refinished are for the whistler mod.
__________________
[size=1][color=dimgray][font=Arial][center] 94 Z28 Hardtop M6, K&N CAI, PS LT's, ORY, Magnaflow Catback, QTP E-Cutout, Bilstein HD's, Prokit, STB, Harwood 2.5" cowl, SS spoiler, Pro 5.0,
18x9.5 Polished ZO6's,
awaiting install: CME, aluminum driveshaft
airfix is offline   Reply With Quote
Old 09-05-2007, 12:55 PM   #5
My Garage
onyxxtreme's Avatar
Trader Rating: 4
i like to start with 400, to remove the UV/clear coat off easily. Then i go to 800, 1000, 1500, then 2000. Then i use Novus plastic polish #3, then finish with #2. I polish with plain ol terry cloth and elbow grease. But i use a high quality, "soft" kind that doesnt leave scratches. (skygeek.com has great prices on novus)
They look brand spankin new after that. You just need to polish with the #2 and wax, every so often to keep it from foggin' up again. It will fog up quicker, after removing the uv/clear coat.
Also some tips, go ahead and remove the weatherstrip that surrounds the lights, makes it 100x easier. Reattach with weather-stripping adhesive.
Also, have a plan of how you do it. I start on the nipples (sand the tops, sides, then bases) then sand the wide open areas last.
I always sand in one direction, then the other (left-right then up-down), to remove all the scratches from the previous grit.
Takes me about 5-10 minutes on each grit, and about 10 minutes total per light to polish. So about 35-60 minutes per light.
Here's some pics from the first headlight I tried. Both were equally yellow, before. They still had some small scratches left over though, which made them look somewhat "hazy". The second attempt came out much better, after getting my technique down. Now i can do a set of lights without any scratches left over, except a few small ones on the nipples. I just finished another set and did the whistler mod, and they are freakin awesome looking.
__________________
'98 Z28 M6
'87 Cuttlass Supreme Sedan: 307/A3, slow and slammed
onyxxtreme is offline   Reply With Quote
Old 09-05-2007, 06:09 PM   #6
My Garage
slick1851's Avatar
Trader Rating: 0
Send a message via AIM to slick1851
I would stay in the very high areas, 1,500 and up and spend the extra time on them..
slick1851 is offline   Reply With Quote
Old 09-09-2007, 01:56 AM   #7
My Garage
Trader Rating: 1
Here's the kit I bought from Advance Autopart. I believe you can get it from Walmart too.
The kit comes with 2 grits of sand papers and 2 types of chemicals. However, I felt like the kit by itself was not enough so I took some extra steps. Here's what I did.
- First I wet-sanded using sand papers 400, 600, 800, 1000, 1500, 2000.
- Then I wet-sanded with the blue sand paper supplied in the kit. This is a 2500 grit sand paper.
- Then I use the 1st chemical. This one is basically rubbing compound. You can use other types of rubbing compound instead if you want.
After this step the lens surface would be very smooth but still somewhat hazy. This is where the 2nd chemical comes in. Most of the haziness was gone after I applied the chemical. It also seals in the lens from future fogging.
It's been less than a month since I did my lens so I can't tell yet how well this kit helps protecting the lens from future fogging. But now I'm pleased with the results.
__________________
'00 Pewter Camaro SS Convertible A4
http://www.fquick.com/RoadHazard/
RoadHazard is offline   Reply With Quote
Old 01-18-2008, 05:47 PM   #8
My Garage
Cobra2WS6's Avatar
Trader Rating: 18
Send a message via AIM to Cobra2WS6 Send a message via Yahoo to Cobra2WS6
Quote:
I couldnt agree more... ANything below 1000 is asking for trouble... I did 1000 then 2000 took my time, used a miguries scratch remover then polish and they came out amazing... You will get scratches if you rub too hard or dig deep with anything under 1000. Now 1000 grit will also leave scratches but will polish up much easier
__________________
578/555
2001 GT Mineral Grey.. KB 2.2.. 17 PSI.. VT Built Motor.. Port & Polished Heads.. Stage 2 Blower Cams.. 6 Speed..
Cobra2WS6 is offline   Reply With Quote
Old 01-18-2008, 05:53 PM   #9
My Garage
Ls1CamaroGuy87's Avatar
Trader Rating: 5
^^I could not agree more.......
Its too bad that there is no company that just sells the lenses, they would make a shit load of money.........
__________________
Monterey Maroon Metallic 2001 A4 (GU2) Z28 Camaro. FQuick
Quote:
Originally Posted by 'Trust' View Post
Favorite superheros: Batman, Superman, Ls1CamaroGuy87, Spider-Man, and Chuck Norris.
Ls1CamaroGuy87 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
