Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Automatic Transmission
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 11-12-2008, 02:25 PM   #1
Blacksaleen95's Avatar
Trader Rating: 1
Default 4L80E/TH400 Dimension info
After doing a lot of searching on here, I've decided to put a 4L80 in my car... The only thing is my car is a 95 mustang.
For those of you not familiar with rustang stuff.. a popular swap is the th400 for obvious reasons...JW offers an ultrabell to swap the th400 to the sbf, it requires you to cut the stk bellhousing where the front pump bolts on, and it utilizes the front pump bolts to fasten the ultrabell to the trans.
They currently don't offer a swap bell for the 4L80E, but since they offer one for the TH400 I was hoping to see if any of the gm trans pros here knew if the front pump bolt holes are the same or similar... and if the depth of the bellhousings are the same.
I'm hoping to get this thing working with my turbod dart 363 and have it fully controlled by my AEM standalone.
Any help/info is appreciated!!
Blacksaleen95 is offline   Reply With Quote
Old 10-14-2009, 03:41 AM   #2
Trader Rating: 0
anyone got any info on this yet
clubdang is offline   Reply With Quote
Old 10-14-2009, 12:04 PM   #3
z28boy's Avatar
Trader Rating: 2
Send a message via Yahoo to z28boy
They are different the 80 is more massive all around and has the extra bolt hole where the 400 does not and a few inches longer. Hope this helps.
__________________
98 Camaro, STOCK 346,Afr225 72cc heads,comp 224/228 581lift 114lobe,moser12bolt 373 gears, Slp3/4long tubes,borla,Q1Rseries,LS6intake,4l80,PY3600, Procharger F1A.
z28boy is offline   Reply With Quote
Old 10-14-2009, 02:38 PM   #4
forcd ind's Avatar
Trader Rating: 1
i have a 400 and 4l80e sitting side by side, def the pumps are diff-besides the bolt pattern, the 400 has a flatter area around the bolts, the 4l80e has some extra bracing, not the nice flat area all around
forcd ind is offline   Reply With Quote
Old 10-15-2009, 12:25 AM   #5
Trader Rating: 12
A JW UltraBell can be adapted to the 4L80E but it's not a bolt on deal.
As stated the pump cover must be machined, as well as the Ultrabell.
jakeshoe is offline   Reply With Quote
Old 10-15-2009, 12:42 AM   #6
Trader Rating: 0
thanks all.. jake what is needed to be done to do it as im a machinest also still will be getting a converter off you this is the last thing i need to do
Old 10-15-2009, 01:08 AM   #7
Trader Rating: 0
I was looking for this part information but no need to looking forward.
__________________
***NON-SPONSOR LINK REMOVED!!! PLEASE DO NOT POST NON-SPONSOR CONTACT INFO!!!***
>>>Signature Policy - Click Here<<<
CRAGER - LS1TECH.com Staff
theclutchmart is offline   Reply With Quote
Old 10-15-2009, 02:09 AM   #8
Trader Rating: 0
Quote:
no need to looking forward...?
Tags
400, 4l80, 4l80e, bell, bellhousing, dimensions, gm, install, jw, sbf, swap, swapping, th400, thm, transmission, ultra, vs
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
