Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Automatic Transmission
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 09-10-2009, 09:22 PM   #1
lt170chevelle's Avatar
Trader Rating: 0
Default B&M shift kit...plug 3-4 clutch hole?
I am in the middle of rebuilding my 4l60e and decided to get a trans go seperater plate. well i just noticed that the plate that came with a b&m shift kit that i had installed a few years back it had me hammer a plug onto the plate and from what i read is one of three being the biggest hole 3-4 clutch.From the size i am thinking maybe its an exhaust. does anybody know about this mod?
It was one of those cheap 25 buck kits that came with spacers to take the place of the acc springs ,in which i put stiff springs back in since i have heard that the spacers kill the impact absorbtion of the hydraulics.
Idk know if it was ignorance and maybe i some how plugged the wrong hole or if this is what was supposed to be blocked.
__________________
DAILY DRIVEN 1970 CHEVELLE ,94 LT1,TUNER CAT,2BAR, DIY PORT & POLISHED RUNNERS,BOWL & CHAMBERS ,DIY TURBO ,8LB EXTERNAL WASTEGATE,3" INTERCOOLED,255 PUMP,42LBS LUCAS INJECTORS, BUILT A4,YANK 3200,UMI 1"REAR SWAY BAR ,UMI CA Brackets,AND 3.42's....NOW GETTING THE MORE BOOST ITCH..
lt170chevelle is offline   Reply With Quote
Old 09-11-2009, 08:26 AM   #2
Trader Rating: 0
Hey guys can you give me some insight on this? I am going to be finishing up my tranny tonight and installing it.
__________________
Old 09-11-2009, 10:18 AM   #3
LS1TECH & Trucks Sponsor
performabuilt's Avatar
Trader Rating: 23
Send a message via AIM to performabuilt Send a message via MSN to performabuilt Send a message via Yahoo to performabuilt
Unfortunatley I am not so familiar with the B&M kit . I do know we dont plug any holes in our setup.
If you can post a pic or send it to me of the plate with the hole blocked and i will determine what it is.
Frank
__________________
You get-Free Shipping always-Free Cooler-Pro Cooler Flush-2yr warranty Trans/verter combos 1yr trans only-$950 Restore after warranty-No Core or charge-Core buy back $150-7 Day support-570-578-5686-MOST UNITS SHIP IN 1-2 DAYS OF ORDER-ALL DYNO TESTED! Clik BANNER for WEBSITE!
What more could you ask
performabuilt is offline   Reply With Quote
Old 09-11-2009, 01:18 PM   #4
Trader Rating: 0
Ok i can snap a pic when i get home. This according to my book is one of three holes that are really close together on the plate for the 3-4 clutch. It is a bigger round hole, a small round hole and a square hole. they are almost arranged in a triangular pattern. I dont know if these are for the exhaust or feed.But the bigger round one is the one that it says to plug. Another thing i noticed was it says to drill the feed holes to a 1/4" Wouldnt that be really hard on the internals?
I found an install instructions on it here:
http://rds.yahoo.com/_ylt=A0geu66Yha...9500582-03.pdf
__________________
Old 09-13-2009, 11:18 AM   #5
Trader Rating: 0
So i nevered figured out the reason for the plug on the vb plate from the b&m kit..so imma leave it off of the new trans go plate and see how it feels.And i was wrong on the square hole. It plugs a check ball hole and leaves that ball out of the vb. it does have a very small hole next to it.
__________________
Old 09-13-2009, 11:22 AM   #6
Trader Rating: 23
I tried to look at the link you posted , Its says "This link not authorized by yahoo"
__________________
Old 09-13-2009, 08:48 PM   #7
Trader Rating: 0
oh just skip passed that. its because the pdf file is on another site i believe.just click to look anyways..its just a security warning
Also i got everything back together and took it for a short drive and either 4th gear or lockup is going in and out ..like a slow pulsation..almost felt maybe electrical?..Its been pouring cats an dogs all weekend so didnt want to drive it to much. I manually shifted it and it felt like i could barely feel 4th shift. but like i said it has been pouring so i was very easy on the throttle. I hope for a drier day tomorrow so i can see exactly whats its doing.
__________________
Old 09-13-2009, 11:04 PM   #8
LS1Tech & Trucks Sponsor
Vince @ FLT's Avatar
Trader Rating: 7
The plug is located in the third accumulator check ball seat. The check balls primary function is to direct exhausting 3rd accumulator oil to the 3-2 control valve. It basically is used for the 2-4 band apply for a 3-2 downshift. On a 3-4 shift the ball would normally unseat itself with fluid pressure for a quick feed into the 3rd accumulator circuit. This would help the 3-4 clutch stay applied. Thus the reason for enlarging the hole next to the plugged hole. Mean while on the back side of the servo assembly, fluid is being supplied through the servo pin. Then the 4th servo strokes the servo pin to apply the band. If that makes any sense. Vince B
__________________
Vince Bielanski @ 1-630-350-7776 www.finishlinetrans.com
No Core Deposits All Transmissions Are Shipped Fully DYNO TESTED SEE Picture below
All Units Come Complete As A Bolt In Application. With Bell Housing And Tail Housing
Vince @ FLT is offline   Reply With Quote
Old 09-14-2009, 01:21 PM   #9
Trader Rating: 0
Ok yes that makes sense. So why would plugging it the way b&m shows to do help anything? Wouldnt that just make the 3rd accumulator curcuit not apply as quickly?I understand making the feed hole larger but why block the check ball hole?
Sorry for all the questions, i am just trying to understand the reasoning for it fully.
__________________
Old 09-14-2009, 05:43 PM   #10
Trader Rating: 0
Hey vince..i am a little confused now that i reread your reply and you mentioned that the hole next to the plugged hole gets enlarged? I thought the 3rd feed hole according to the paper that came with the transgo plate says 3rd is the center most small hole and on the b&m one it says to enlarge that one also.Was i supposed to open up the one next to the hole in question that was plugged?
According to the b&m plate for reference the 2nd, 3rd ,and 4th feed holes get enlarged 3/32 for hd which is what i went with,or a whopping 1/8 for street strip only on 2nd and 3rd.
__________________
Old 09-15-2009, 09:12 AM   #11
Trader Rating: 0
Update: Went ahead and drove it to work to see what it was doing on the highway. 1-3 is solid BUT 4th is slipping like carazy like its not getting barely any pressure to engage it. I can feel it shift into 4th but if i give anything over maybe 5% throttle the rpms just keep climbing until it hits 3rd gears rpm. Would this be related to the plug in the vb plate? I was really easy on it and kept it in 3rd as soon as i noticed it slipping in 4th.
__________________
Old 09-15-2009, 03:20 PM   #12
Trader Rating: 0
Possible 4th servo leak?
__________________
Old 09-16-2009, 08:43 PM   #13
Trader Rating: 7
Not sure why they do it that way. I have never done it nor tested it. The issue I see is when the release of the ball would occur. Seems to me it would help on one function of the ball but hurt on the flip side of it.
My bad on the enlarge of the hole comment. I just went and looked at the directions again and I was wrong. I wonder if plugging the one hole in question might help with detuning the accumulation. Basically because the feed hole is so large.
I really do not think that the plug not being installed would not cause a no 4th gear condition unless you did not install the check ball.
That would be my first guess.
__________________
Tags
12, 350, 4l60e, accumulator, bm, drilling, hole, instructions, kit, shift, size, transgo, turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
