Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Automatic Transmission
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 11-03-2009, 07:59 PM   #21
mightyquickz28's Avatar
Trader Rating: 2
Send a message via Yahoo to mightyquickz28
This is one site's reference to what I'm talking about...
VSS Diagnostic Enable Minimum RPM:
Not sure exactly what this does, but I’ve been wondering if you set the rpm on this to it’s maximum value if the computer would not be able to activate the limp mode that causes the OBDI 1st-2nd shift problem. I’ve always been under the assumption that the no-shift is caused be a hard launch on sticky tires that would cause the VSS to lose it’s signal and set the trans into limp mode.
Try it and see if it works for you
__________________
www.fquick.com/mightyquick
'96 Z28 355 LT1, Custom Bret Bauer Turbo Cam, M6, 3.55 Ford 8.8 differential,
T76 Turbo, 60# mototron Inj, Turbo Tune by Bryan Herter(PCM4Less)
1/8th mile MPH (9/16/2009): 108 full street weight/tires.
http://www.taekwondoplus.org/z28/Tur...Turboinfo.html
mightyquickz28 is online now   Reply With Quote
Old 11-03-2009, 08:46 PM   #22
Trader Rating: 2
Here's the Tunercat settings to get around the issue...
http://good-times.webshots.com/album/554105334kOjaYY
__________________
Old 11-03-2009, 09:57 PM   #23
1995 Pontiac Trans Am
1995blacktattop's Avatar
Trader Rating: 1
Quote:
Originally Posted by waveoff View Post
Unfortunately, it sounds like your tranny is on its way out. My tranny has died twice and both times it exhibited the same symptoms as your car. Both times it was due to a burned up 3-4 clutch pack. Very rarely the tune is the problem but more often than not it's due to burned clutches. Sorry...
yeah i'll agree to that. my car did that a couple years ago and it was for all intents and purposes bone stock. msd wires, cap and rotor, K&N filter, and ngk plugs. it needed rebuilt. i'm sure the tune had nothing to do with it since it was a stock car with a stock tune.
__________________
1995 Black TA A4 LT1
Mods: MSD cap and rotor, MSD wires, NGK plugs, K&N filter, 17" corvette GS replica's, Ram Air and OEM WS6 hood
1995blacktattop is offline   Reply With Quote
Old 11-04-2009, 08:09 AM   #24
blackodium's Avatar
Trader Rating: 0
Send a message via MSN to blackodium
i am looking towards performabuilts stage one tranny. what is the rule for reusing or not reusing the stock torque converter
__________________
WWW.WS6STORE.COM
blackodium is offline   Reply With Quote
Old 11-04-2009, 08:11 AM   #25
blackodium's Avatar
Trader Rating: 0
Also can you run a 2000-2500 stall on a stock LS1?
__________________
WWW.WS6STORE.COM
Old 11-04-2009, 08:37 AM   #26
Trader Rating: 2
I would get the TC serviced. THey drain it, cut it apart, clean it, inspect it, weld it up(they may check the balance too. Not sure) The TC you can get with the Performabuilt is not that much from them. I'd just buy one of theirs rather than fussing with your stocker, waiting for it, etc.
Quote:
__________________
Old 11-04-2009, 08:38 AM   #27
Trader Rating: 2
Yes. Lots of guys have done that as their first mod. Buying a Vigilante 2800 stall and putting it in a stock Fbody. Great mod too!
__________________
Tags
23, 4l60e, car, high, hitting, limiter, limp, mode, probable, problem, problems, rev, revs, rpm, shift, wont, wot
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
