Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > VEHICLE SPECIFIC FORUMS > Cadillac CTS-V 2004-2009
Old 11-04-2008, 09:09 AM   #1
CORNER CARVER's Avatar
Trader Rating: 0
Default Does anyone No-lift power shift their V.
Does anyone shift thru the gears without lifting off of the throttle? If so do you notice a delay or hesitation after letting the clutch back out?
It almost seems like the throttle actuator closes the throttle when the clutch is depressed, then delays for a split second reopening the butterfly?
I am wondering if anyone has felt his before. Or if not maybe I have a problem elsewhere, Clutch actuator? But it doesn't over-rev or bounce off of the limiter.
CORNER CARVER is offline   Reply With Quote
Old 11-04-2008, 09:40 AM   #2
jerrad's Avatar
Trader Rating: 2
I don't. Is the delay clutch slip or is it like the motor revs down some?
__________________
04 Black CTS-V: K&N, Borla, Katech, Wait4me tune,
BMR pinion support and rear wheel hop
kit, LS7 clutch/flywheel.
jerrad is online now   Reply With Quote
Old 11-04-2008, 11:25 AM   #3
Trader Rating: 0
Its not clutch slip because on the 2-3 shift when it reacts it lifts the whole front of the car and twists it to the left. Its kinda cool but the delay drives me nutz.
Its like the PCM sees the clutch being depressed and with no change in throttle it must back off the opening angle on the throttle body then when it gets a signal from the clutch switch that the clutch is out it goes back to 100% throttle angle.
Its more prevalent on the 2-3 and 3-4 upshifts. 1-2 it doesn't seem to delay.
Old 11-04-2008, 11:32 AM   #4
DoesSpeedTurnUon's Avatar
Trader Rating: 14
Send a message via AIM to DoesSpeedTurnUon Send a message via Yahoo to DoesSpeedTurnUon
Take traction control off and try it
__________________
2005 Cadillac CTS-V - Stainless Works Longtubes - Custom Borla Catback
Quote:
Originally Posted by SSquid
see let me explain my luck... I would of hit him like you did... but my head would of fell off... then a samuri sword would of flown out the airvent and impaled my shoulder then the car would of burst into flames and amazingly the ac would of turned on blowing dry ice temp. and turned my burning corpse into a icecicle then some idiot seagulls would of eatin me....
DoesSpeedTurnUon is offline   Reply With Quote
Old 11-04-2008, 12:38 PM   #5
Trader Rating: 0
I did it at the track and blew the tires of 1-4th going through the traps.
__________________
2004 CTS-V Ls6, TSP Terminator heads, 232/234 cam, Kooks longtubes, Magna flow catback, BMR bushings, B&M shifter,BFG Drag 295/35s inda rear, H/C 414rwhp, Nitrous Outlet brand X kit 150 pills(waiting on injectors and tune)<still waiting
Capown is offline   Reply With Quote
Old 11-04-2008, 12:41 PM   #6
jonecap's Avatar
Trader Rating: 0
I noticed the exact same thing you are describing at the dragstrip on the 3-4 shift. It's a delay after you come off cluth before it get's going again. Probably about .2-.3 sec.
__________________
'05 CTS-V - stock for the moment
'06 Impala SS - 13.75 @ 101 stock
'96 Vette LT4
- LT4 Hotcam, 4.10 gears, exhaust, and a little nitrous...
7.012...1/8
102.9...1/8 mph
10.88...1/4
128.0...1/4mph
Motor only pass 11.79 @ 117.97 at Rockingham http://www.youtube.com/watch?v=4nF_Y5SVw-4
jonecap is offline   Reply With Quote
Old 11-04-2008, 01:18 PM   #7
CTSV_510's Avatar
Trader Rating: 0
Its probably the V gods trying to save your diff from exploding.
__________________
05 CTS-V / maggie 2.8 / b&m shifter / kooks lts 1 3/4 + cats / magnaflow / k&n cai / fg2 shocks / hotchkis sways / hawk hps
CTSV_510 is offline   Reply With Quote
Old 11-04-2008, 01:22 PM   #8
Trader Rating: 0
Quote:
agree, and i was never a fan of downrev powershifting. I have yet to see someone who can pull it off effectively as fast as I can clutch, and Ive seen enough transmissions come through vehicle floors that I wont do it even if there was a gun to my head.
__________________
05 Raven / Chrome CTS-V
custom cat back exhaust with magnaflows and Xpipe + FFV-K&N + 275/40/18 rear + KARS III + Ported & Polished Throttle Body + TPIS Long Tubes + Hi Flow Cats + Tuned by EFI-Tuning
Looking for online exposure?
www.FullMontyMarketing.com
Cts-Voodoo is offline   Reply With Quote
Old 11-04-2008, 02:12 PM   #9
Trader Rating: 0
Quote:
I guess I'm not going crazy. It doesn't seem to be a problem just a glich thats annoying.
After driving it during lunch break and trying the 2-3 power shift I came to the quick conclusion that regardless of the quirks of the CTS-V I really LOVE THIS CAR!
I have longed for this car since it came out and raced in 2004. Its a perfect blend of luxury and badass. So I guess I will have to live with its minor pitfalls.
Old 11-04-2008, 02:16 PM   #10
Trader Rating: 0
Quote:
By this do you mean shifting with no clutch only a blip of the throttle?
Old 11-04-2008, 02:42 PM   #11
Trader Rating: 0
full throttle, let off for a 1/10th of a second to allow engine to start down reving, slam shifter into next gear. Apparently it works, but Ive only watched terrible things happen lol
__________________
Old 11-04-2008, 02:46 PM   #12
Trader Rating: 0
and this one time, at band camp,
i stuck a flute im my turbo. ({!})
GT67METHV is offline   Reply With Quote
Old 11-04-2008, 04:54 PM   #13
pcf_mark's Avatar
Trader Rating: 0
There was a delay in the F body slave hydraulic circuit that caused some delay in the bleeding off of the pressure. On a brutal power shift you could slip the clutch because the hydraulic had not let all the fluid out.
On my V I have done a few abusive shifts and noticed a whole lot of drivetrain twist. I think this is the motor mounts squishing around and it feels like a delay.
__________________
'05 CTS-V Platinum, stock
'68 Corvette 427 (ok really it is 468" without a single stock part), six speed, custom headers & side pipes, etc.
www.performancecarfactory.com
pcf_mark is offline   Reply With Quote
Old 11-04-2008, 04:59 PM   #14
Trader Rating: 0
Something at times feels like a delay.
Old 11-04-2008, 07:42 PM   #15
jonecap's Avatar
Trader Rating: 0
Here's one of my passes on my ol' C4. In the video in my sig, I shift at 6,500 rpm, never lift and the car doesn't seem to mind a bit. I can guarantee my V would not like it though (wheel hop). You've got to have your shifting nailed to pull it off though.
__________________
'96 Vette LT4
7.012...1/8
102.9...1/8 mph
10.88...1/4
128.0...1/4mph
Old 11-04-2008, 07:43 PM   #16
Trader Rating: 14
Here's one of my passes on my old Corvette. I shift at 6,500 rpm, never lift and the car doesn't seem to mind a bit. I can guarantee my V would not like it though (wheel hop). You've got to have your shifting nailed to pull it off though. http://www.youtube.com/watch?v=4nF_Y5SVw-4
If i drive mine like that, it just spins... no hopping.
__________________
Old 11-04-2008, 07:59 PM   #17
Trader Rating: 0
I gave my brother a ride the other day and he thought he felt the tires spinning in every gear (through fourth). I dont know if he felt spin but it was definatly moving. We came up on 90 and traffic in a hurry. He was very impressed with the V. I think he was more impressed when I ran it up to 35 and slammed on the brakes!
Old 11-04-2008, 08:25 PM   #18
Trader Rating: 0
I know the 09 V has the NO Lift Shift... BAD ASS!!
CtsVrod is offline   Reply With Quote
Old 11-05-2008, 02:51 AM   #19
Trader Rating: 5
Send a message via Yahoo to rippenhard
Honestly your not doing anything but hurting your trans my not using the clutch. It has been proven that you will not gain any e.t. from doing this. Actually in most cases you will run a slower e.t. at the track.
__________________
http://i36.photobucket.com/albums/e4...nhard/rip2.jpg
05 CTS-V all stock for now.
08 Silverado lowered on 22's
2000 Camaro SS
Speedtek W1 cam (227/232 578/586) lou's short stick, Pacesetter LT's, 3" True dual w/dynomax bullets dumped, K@N FIPK, TNT F2 150 Shot, TT2's, (SOLD)
rippenhard is offline   Reply With Quote
Old 11-05-2008, 08:15 AM   #20
Trader Rating: 0
I think that not using the clutch is just a bad idea.
If it were a good idea, the manufacturers would have been all over it along time ago.
Use the clutch, its there for a reason.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Alphabetical sponsor list
Trifecta Performance
TomZ Wheels
Kooks Custom Headers
Nasty Performance
Exotic Performance Plus
SLP
Race Proven Motorsports
Painless Performance
Speed South
Kee Audio
Nitrous Express
Slowhalk
School of Automotive Machinists
Diablo Sport
Total Engine Airflow
Patriot Performance
Performance Auto Fabrication
Nano Nitrous
G-Force Motorsports
Katech Engine Development
Straightline Performance
BMR Suspension
Air Flow Research
Performance Oil Technology
Mast Motorsports
Xtreme Horsepower
Fast Toys
Afterthoughts Auto
Cartek Racing
Advanced Induction
Competition Clutch
Pavlock Performance
Finish Line Transmissions
World Products
Speed Tweekerz
Discount Tire
New Era Performance
Nitro Dave's Nitrous Outlet
Faster Proms
CarsDirect
Tick Performance
Texas Speed & Performance
WS6 Store
Scoggin-Dickey Parts Center
Nitrous Oxide Systems
Strano Performance Parts
Midwest Chassis
Futral Motorsports
Finish Line Performance
Lonnies Performance
LG Motorsports
SJM Manufacturing
Yank Torque Converters
Forced Inductions
Harris Speedworks
UMI Performance
Canadian Performance
Madman Racing
LM Performance
VFN Fiberglass
Redline Goods
Specialized Stainless
Livernois Motorsports
PerformaBuilt Transmissions
Auto Parts Firm Online
Race Engine Development
Late Model Engines
ByunSpeed
Speed Inc.
Southern Car Parts
Racetronix Fuel Systems
TT Performance
Cunningham Motorsports
Vengeance Racing
MPH Motorsports
Circle-D Converters
Speed Engineering
Full Throttle Speed
EFI Alchemy
LSx Tune
Wolfe Racecraft
Dyno Tune
Century Transmission
Quick Time Performance
Rapid Motorsports
Tropi-Care
Speartech Fuel Injection Sys
Maryland Speed
Burkhart Chassis
American Racing headers
Car Shop Inc
West Coast Cylinder Head
Spohn Performance
Late Model Racecraft
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
