Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > VEHICLE SPECIFIC FORUMS > Cadillac CTS-V 2004-2009
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-06-2009, 08:46 PM   #1
nikon's Avatar
Trader Rating: 0
Default Gotta adjust the ebrake...
It's a pretty simple adjustment (mini drum) just wondering as I don't want it to drag. How tight should I make them...only way I can measure it is how far I can push the pedal down....so how far down should I adjust the pedal? I was thinking half way? Right now it's bottomed out and I don't really trust it. Any input is appreciated...I do remember reading something where you needed a special tool...can't imagine what for, it's just a star wheel.
__________________
http://i107.photobucket.com/albums/m...n858/Vblur.jpg
"Money can't buy me happiness, but I'm happiest when I can buy what I want"
05' CTS-V
00' Camaro
nikon is offline   Reply With Quote
Old 10-06-2009, 10:11 PM   #2
SkullV's Avatar
Trader Rating: 2
There is an auto adjustment feature built in, it has something to do with pushing the brake down and releasing it 3 times while sitting parked in gear, I don't remember for sure though...
__________________
Ted/SkullV
2005 Redline CTS-V
SkullV is offline   Reply With Quote
Old 10-07-2009, 10:32 AM   #3
nikon's Avatar
Trader Rating: 0
I'll give it a shot, thanks....cause I think I bumped the wheel a little while installing the axle....used to be a little tighter.
__________________
05' CTS-V
00' Camaro
Old 10-07-2009, 11:02 AM   #4
Trader Rating: 0
when i got my assembly replaced under warranty, it was stopping right at halfway, and holding well. over time it worked itself to the floor again. i adjust mine by holding the handle, push about halfway, release. push about halfway, release. do this 3 or 4 times or until you feel it tightening up, and it will now grab much higher. i do this about once a week or when i notice it wont grab well..this may not be textbook but it works.
luckily it is relatively flat here....or i would not be happy with this flaw i the car. i cant see how anyone who uses ebrake daily as a need can tolerate it...
Cadzilla is offline   Reply With Quote
Old 10-07-2009, 01:20 PM   #5
Trader Rating: 0
had my ebrake shoes changed at 30k cause they were trashed from previous owner... gotta do them again i believe... (or maybe the drum is fucked... )
SoJersey05V is offline   Reply With Quote
Old 10-07-2009, 02:49 PM   #6
SkullV's Avatar
Trader Rating: 2
Quote:
The drum is the rear rotor. So if the drum is "fucked" as you so eloquently put it, then you need new rear rotors.
__________________
Ted/SkullV
2005 Redline CTS-V
Old 10-08-2009, 04:11 PM   #7
CORNER CARVER's Avatar
Trader Rating: 0
Quote:
The tool is a caliper that transfers the measurment from the inside of the rotor hat to the outside of the shoes so they cane be adjusted out.
Quote:
There is supposed to be an auto adjustment feature. But me thinks its failed alot of lads.
__________________
A V IS THIS PLANETS BEST DD!
I smile everywhere I go in my Caddy.
CORNER CARVER is offline   Reply With Quote
Old 10-08-2009, 04:21 PM   #8
nikon's Avatar
Trader Rating: 0
^^^ ah, special tool I guess your supposed to use that special tool when doing regular drum brakes too I figured it would be something like that.
__________________
05' CTS-V
00' Camaro
Old 10-09-2009, 01:20 PM   #9
Trader Rating: 0
yea thats what i was getting at.. next brake job has got to include rotors!! front and rear pads... front and rear rotors.. new ebrake shoes... add them to the list!!
Tags
adjust, adjusting, adjustments, brake, cts, ctsv, drum, ebrake, grabs, high, read, tighten
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
