Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > VEHICLE SPECIFIC FORUMS > Chevrolet Camaro 1967-2002
Old 10-29-2008, 02:33 PM   #1
Trader Rating: 0
Default Few probelms with 01 Z28
I have an Automatic 01 Z28 and im having a couple of issues...
The First....
When I start it cold, It makes a tinkering sound kinda like it is low on oil. The sound will quit after i take off and get going, but it will not make this sound while idoling.
The Second Probelm....
It seems like it doesnt want to shift into 1st gear. It kinda shifts hard. When I first got the car it shifted very smoothly. Could this be Transmission fluid? Im scared to put to much in it. I dont really understand how to read the dip stick.
Third Probelm...
I hear a groaning sound that seems like its coming from the dash or under the dash while driving or taking off quickly. It kinda sounds like something is loose.
Any help is appreciated.
cheefzboy is offline   Reply With Quote
Old 10-29-2008, 04:25 PM   #2
blk/slvr02ss's Avatar
Trader Rating: 4
Your first problem sounds like the LS1 tick alot of them do that.#2 sounds like it may be low on fluid.Check it .If low add some a little @ a time.#3 they creek and groan so try to move it yourself to find out where and if you can tighten it up.
blk/slvr02ss is offline   Reply With Quote
Old 10-29-2008, 07:47 PM   #3
JustWannaGoFast95's Avatar
Trader Rating: 2
Send a message via AIM to JustWannaGoFast95
Quote:
The First....
Third Probelm...
ticking noise is somewhat normal could be a lifter though but either way not too serious
the trans probably just needs replaced/rebuilt low fluid could cause that but the 4l60e is known for problems
as far as under the dash i have no idea id have to hear it
__________________
2001 ford lightning
2000 a4 z28 y35 ---sold
1988 asc iroc vert
1986 toyota 4runner
JustWannaGoFast95 is offline   Reply With Quote
Old 10-30-2008, 01:08 AM   #4
waldershrek's Avatar
Trader Rating: 1
How many miles are on this car first of all? Sounds like it could be the famous LS1 tick
Secondly, if you can't read the dipstick do not add fluid. Ask somebody to help you that knows how to read it. Also, since it's an auto I assume you mean it doesn't want to shift out of first gear? You said in to first gear.
As far as the third issue I have no idea. These cars are noisy as he said above and make some creaks and groans.
__________________
2001 Camaro SS SLP #1354
waldershrek is offline   Reply With Quote
Old 10-30-2008, 07:41 AM   #5
Trader Rating: 0
It has 81k miles on it. I have put about 2k of those miles on it. Yes I meant it acts like it wants to stay in first. It will shift much smoother if i give it more gas. Would a Trans Flush possibly help?
Old 10-30-2008, 09:22 AM   #6
Trader Rating: 4
Yes, you should have the tranny flush done @ 60,000 so i would say your do for one.They make a big difference in the life of your tranny.
Old 11-05-2008, 11:42 AM   #7
quik01ss's Avatar
Trader Rating: 6
Send a message via AIM to quik01ss
all ls1s tick. i have 2 of them... to read the dip stick get the car warm and check the level on the stick when its running....how many miles on it??
__________________
2001 Camaro SS SLP..
Old Setup: STS Turbo 524rwhp/557 rwtq 12.2 at 126
New Setup: MTI X1 Cam, Comp Cams Push Rods, Hooker 1 3/4" Headers, Hooker ORY Pipe, Magnaflow Catback, FAST 92mm Intake and 92mm TB, Volant CAI, TR55 Plugs, Taylor 10.4 Wires, SLP UD Pulley, SLP 85mm MAF, Centerforce Clutch and Flywheel, PRC Dual Valve Springs, Spohn Reloc. LCA Brackets, Lakewood LCA's, TA Rear Cover, Motive 4.10s, Tick Perf. Adj. M.C...
http://www.cardomain.com/ride/2444302
quik01ss is online now   Reply With Quote
Old 11-12-2008, 10:39 PM   #8
Trader Rating: 0
My 01 Z28 ls1 M6 makes a tinkering noise when its idleing and it has 33k miles on it and as far as the trans that might be sediment blocking a port in the valve body not allowing the trans to shift right, or that could just be the way it is. Also look into if the previous owner had added a shift kit or and trans modifications, or even messed with the computer and shift points/rpm.
That noise under the dash does it happen only when the blower is on ?
YounggunZ28 is offline   Reply With Quote
Old 11-13-2008, 12:26 PM   #9
fast01z28's Avatar
Trader Rating: 3
Send a message via AIM to fast01z28
it ticks when the oil is cool. once its warmed up it will stop ticking. i HIGHLY recommend not pushing the car hard while its ticking. i usually let it sit idle or if i do drive it while its ticking i coast, dont hit the gas at all. it will greatly decrease the life of the engine if you push it hard when the oil is cold still.
Its not hard to check the tranny fluid. Follow the instructions in the owners manual (if you have it) or do what was said earlier. drive the car for a little bit to warm it up, then check the fluid with the engine on. if you check with the engine off or cold, it will say its lower than it is, and youll add too much and blow out the tranny.
__________________
2001 red Granatelli Signature Series Camaro: for sale
http://www.ls1tech.com/forums/vehicl...21k-miles.html
PHK original member #4
fast01z28 is online now   Reply With Quote
Old 11-15-2008, 04:53 PM   #10
EnfuegoZ28's Avatar
Trader Rating: 0
Try adding an oil additive like Lucas Oil. It sticks to the metal in the engine better and will help with those cold starts to keep everything lubed up and prevent metal to metal contact. Get the transmission flushed, fluid and filter changed. And f-bodies just sqeek and rattle thanks to GM's build quality.
__________________
EnfuegoZ28 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Alphabetical sponsor list
Xtreme Horsepower
Scoggin-Dickey Parts Center
Maryland Speed
Quick Time Performance
World Products
Rapid Motorsports
Spohn Performance
Kooks Custom Headers
Speed South
Wolfe Racecraft
Performance Oil Technology
Performance Auto Fabrication
LG Motorsports
Circle-D Converters
Full Throttle Speed
Discount Tire
Finish Line Transmissions
Mast Motorsports
Harris Speedworks
West Coast Cylinder Head
Slowhalk
Livernois Motorsports
Trifecta Performance
Kee Audio
Speartech Fuel Injection Sys
VFN Fiberglass
Redline Goods
Air Flow Research
Cunningham Motorsports
SLP
School of Automotive Machinists
Auto Parts Firm Online
Speed Engineering
Canadian Performance
Midwest Chassis
LSx Tune
PerformaBuilt Transmissions
Burkhart Chassis
ByunSpeed
Cartek Racing
Pavlock Performance
Straightline Performance
Racetronix Fuel Systems
Painless Performance
MPH Motorsports
G-Force Motorsports
Tick Performance
Tropi-Care
Nitrous Express
Lonnies Performance
Vengeance Racing
New Era Performance
Late Model Racecraft
Specialized Stainless
American Racing headers
Nitro Dave's Nitrous Outlet
Diablo Sport
Strano Performance Parts
Century Transmission
LM Performance
Late Model Engines
Exotic Performance Plus
Dyno Tune
Speed Tweekerz
Patriot Performance
Car Shop Inc
Southern Car Parts
TomZ Wheels
Nitrous Oxide Systems
Madman Racing
Forced Inductions
Race Proven Motorsports
Advanced Induction
CarsDirect
Competition Clutch
UMI Performance
Race Engine Development
EFI Alchemy
Nano Nitrous
WS6 Store
TT Performance
SJM Manufacturing
Fast Toys
Texas Speed & Performance
Speed Inc.
Finish Line Performance
Yank Torque Converters
BMR Suspension
Katech Engine Development
Faster Proms
Nasty Performance
Total Engine Airflow
Futral Motorsports
Afterthoughts Auto
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
