Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > VEHICLE SPECIFIC FORUMS > Chevrolet Camaro 1967-2002
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 06-27-2009, 03:18 PM   #1
Trader Rating: 0
Default gas capacity question
I have a 02 Camaro Z28 and I was wondering how low the gas needle goes before the tank is really empty? When I fill up the car completely it goes a good amount above the full tank mark so I'm wondering if the same is true for an empty tank? Like when the car is off the needle rests well below the empty mark. And my gas light or the "check gages" doesn't come on until right before the empty mark.
Money is tight and gas is expensive I need to know how far I can go before I run out of gas lol.
__________________
02 Camaro Z28 M6 - SLP intake, kooks LT's, kooks catted y, borla catback, custom tune, bilstein/strano shocks, baer drilled/slotted rotors front only, baer sport touring pads front and back
my fquick
ncfastls1 is offline   Reply With Quote
Old 06-27-2009, 05:27 PM   #2
Moderator
davered00ss's Avatar
Trader Rating: 4
Not a good idea to do that intentionally. $3 for a gallon of gas should not break the bank.
__________________
2000 SS M6, Kooks Headers w/Magnaflow cats & y-pipe, Magnaflow Cat-Back, SLP Lid, TSP ported TB, Ported FAST 78 Intake, Spec 3F w/ billet flywheel, 4.10's, UMI DS Loop, panhard rod, LCA's, BMR STB, Adj TQ Arm, Tubular SFC's, Rear QA1's, TR 224, AFR 205's milled .030, Double roller timming chain, SLP pulley, built T56, LS1 Edit by Slowhawk
http://www.slowhawkperformance.com/
davered00ss is offline   Reply With Quote
Old 06-28-2009, 12:00 AM   #3
Trader Rating: 0
When my "check gauges" light comes on, I'd say I have roughly 4 gallons of fuel based on how many miles I average per gallon. I've driven 50-60 miles after the check gauge light comes on and I have always had at least 1 gallon of fuel left. I just try to see how many miles I go after the check gauge light comes on, and then see how many gallons it takes to fill up.
The f-body gas tank is shaped someone like a "V" and the gauge will drop exponentially faster the lower you get. But once you get right on the empty line, you may have 3-4 gallons left.
01 F-body LS1
Z28 Bacon Evader is offline   Reply With Quote
Old 06-28-2009, 01:32 AM   #4
Trader Rating: 0
$3 a gallon does break the bank for someone who got laid off...
But thank you I figured there was a bit more below the empty line I just didn't want to test it out and be wrong. I also wondered why the gas seems to drop faster the lower it gets...makes sense now
__________________
my fquick
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
