Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
Old 11-17-2008, 08:56 AM   #1
Trader Rating: 0
Default LQ9 flywheel/clutch/starter compatibility???
I've got an 02 LQ9 that originally had an automatic trans Escalade.
I'm mating it to a manual trans, so I'll need a flywheel and clutch.
Are there any incompatible flywheels that will not work on an 02 LQ9?
Can I buy any LS1/2/3/7 flywheel/clutch combo? ie. F body, vette, GTO...
How about the starter, any incompatibility issues with the original auto LQ9 starter?
Thanks,
Gary
garys 68 is offline   Reply With Quote
Old 11-17-2008, 08:33 PM   #2
Trader Rating: 1
Doing this myself right now. What tranny are you hooking up?
69importkilla is offline   Reply With Quote
Old 11-17-2008, 10:42 PM   #3
Bo185's Avatar
Trader Rating: 0
Thanks,
Gary
The 4.8 and LQ4 had manuals trans available on them. But they have a longer crank flange or had a spacer for they flywheel for the NV trans. S0 you might can use the flywheel and clutch for them. But, what trans? If if a LS T56 then the LS stuff will work.
__________________
'73 Scout II 4x4 Vortec 5.3 4L65E np241
'01 VW Beetle TDI-50mpg or better!
'56 Belair 4 door hardtop*next LSx project* 5.3/4l60/3.08's (looking for 25+mpg!)
Bo185 is offline   Reply With Quote
Old 11-18-2008, 06:38 AM   #4
Trader Rating: 0
I'm going with a Tremec TKO 5 speed or Richmond 6 speed.
My understanding is that only the early (00,01?) with iron heads had the longer crank.
I did a search and it seems the LS engines are not a problem but cant find a drfinite answer on the LQ4/9 motors.
I was planning on just getting an 02 F body flywheel/clutch.
Old 11-18-2008, 09:36 PM   #5
Bo185's Avatar
Trader Rating: 0
The 00/01 had the longer solid crank the later ones had a removable spacer used for the manuals, that way GM didn't have to make two cranks for the same engine and all the 4.8s were like this as well.
If its just for a TKO 5 then sine you have an LQ9 it will have the standard LSx short crank and will work with the LS1 flywheel/clutch. No if they will work with the TKO I can't say.
__________________
Old 12-18-2008, 03:18 AM   #6
Slow5.0.'s Avatar
Trader Rating: 2
Wasnt this spacer on the flexplate itsself? I just put in f body t56 and flywheel and i dont think the starter is lined up correctly.. sounds like its just spinning. I did not see any spacer in there to be removed. I was even warned about this.. so I am not sure what to do.
__________________
I envy the LSx power.
Slow5.0. is offline   Reply With Quote
Old 12-18-2008, 03:26 AM   #7
the_merv's Avatar
Trader Rating: 24
^^How does the end of the Crank look, does it stick out past the Rear Main Seal by about 1/4"?
__________________
1995 CAMARO "STRIPPER" Z28 HARDTOP
WEIGHT: 3300 | 402ci LQ4/L92 STROKER | MOSER 9 INCH
COMING SOON: T56 | TEXTRALIA OZ 700 | B&M SHORT SHIFT
the_merv is offline   Reply With Quote
Old 12-18-2008, 04:12 AM   #8
Slow5.0.'s Avatar
Trader Rating: 2
I cant remember, its a 2003 lq motor. The flywheel is already bolted up andeverything.. I would assume its 1/4 inch away because the flywheel would need some space away from the engine right?
__________________
Old 12-18-2008, 04:24 AM   #9
the_merv's Avatar
Trader Rating: 24
Not with these newer Engines. You have one of the later ones judging by the year, so your Crank Flange is the normal one.
To the OP..
As long as you have one of the Engines where the Crank doesn't have the Flange, which I think you don't have the Flange, all the LS stuff will bolt on to it without a problem.
__________________
Old 12-18-2008, 08:10 AM   #10
Trader Rating: 0
I just bolted up an 02 LS1 flywheel to my 02 LQ9. The starter is on but I have not tried to crank it yet. I'll hook up a battery and see if it engages later today.
Old 12-18-2008, 08:16 AM   #11
68 RS Convertible's Avatar
Trader Rating: 1
I am running an 02 lq4 block with a crank out of an 07 LS2 (58 tooth wheel). I am running a Tremec 5 speed. I mocked everything up out of the car and had no problem with fitment. My pilot shaft bushing is not quite all the way in the end of the crank, it sits out maybe 1/16th or even less, maybe as little as 1/32nd. This allowed my imput shaft to set all the way in the pilot shaft bushing. The only thing that pilot shaft bushing is really doing is keeping your imput shaft from "walking around" when your clutch is disengaged. Sorry I dont have any pics to show you.
68 RS Convertible is offline   Reply With Quote
Old 12-18-2008, 08:26 AM   #12
Trader Rating: 0
Did you use the LQ or LS starter?
Old 12-18-2008, 11:43 AM   #13
Trader Rating: 1
starter was for an ls1 and an after market flywheel for an ls1. I used the old style bellhousing that i had bolted up to my old gen I 350. I had to take a little off the area of the bellhousing that the nose of the started goes to get it to fit good. the started fit in without having to grind on the bellhousing, but it was real tight fit. it drags afor a second or so after start, but from the research I have done its because I am still running the ford external selonoid and those dont work to well with the new perminant magnet starters. these are all new terms to me so if i sound like i know what i'm talking about its because i got the info from the other smart people on this site!! good luck.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Alphabetical sponsor list
VFN Fiberglass
LM Performance
WS6 Store
Dyno Tune
Competition Clutch
Race Proven Motorsports
Redline Goods
SLP
Kee Audio
West Coast Cylinder Head
Harris Speedworks
Southern Car Parts
Lonnies Performance
Racetronix Fuel Systems
World Products
Late Model Engines
Air Flow Research
Futral Motorsports
New Era Performance
CarsDirect
Speed Inc.
Madman Racing
Speartech Fuel Injection Sys
Cunningham Motorsports
Xtreme Horsepower
Fast Toys
Pavlock Performance
TT Performance
Finish Line Performance
EFI Alchemy
Circle-D Converters
Speed Engineering
Speed Tweekerz
Canadian Performance
Car Shop Inc
Nitrous Oxide Systems
Texas Speed & Performance
LSx Tune
Midwest Chassis
MPH Motorsports
Auto Parts Firm Online
Slowhalk
SJM Manufacturing
Century Transmission
Quick Time Performance
Mast Motorsports
Nasty Performance
LG Motorsports
Speed South
PerformaBuilt Transmissions
Trifecta Performance
G-Force Motorsports
Nano Nitrous
Wolfe Racecraft
Yank Torque Converters
Strano Performance Parts
Scoggin-Dickey Parts Center
Painless Performance
Straightline Performance
Patriot Performance
Vengeance Racing
Katech Engine Development
Finish Line Transmissions
Rapid Motorsports
Diablo Sport
Race Engine Development
UMI Performance
Forced Inductions
Tick Performance
Kooks Custom Headers
Maryland Speed
Faster Proms
Nitrous Express
Exotic Performance Plus
Specialized Stainless
Livernois Motorsports
Total Engine Airflow
ByunSpeed
Late Model Racecraft
Full Throttle Speed
Spohn Performance
School of Automotive Machinists
TomZ Wheels
BMR Suspension
Performance Auto Fabrication
Advanced Induction
Discount Tire
Burkhart Chassis
Cartek Racing
Nitro Dave's Nitrous Outlet
Afterthoughts Auto
Performance Oil Technology
Tropi-Care
American Racing headers
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
