Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 05-21-2009, 08:00 PM   #121
beertestr's Avatar
Trader Rating: 4
Quote:
Originally Posted by 1991ls13 View Post
what am i suppose to get from this? are you askin me what year is mine??
in this case its a 2004 gto
DOH!! I mean 2 posts before it.
Check your power and grounds, there are several of each going into and out of the controller. Decode you codes, and look start checking those sensors.
__________________
Mike
93 GMC Sierra Gen-III V8 Swap DONE!
95 Caprice - LT1/T56, ported Al heads, Hot Cam, 3.73, Hotchkis bars, Eibach's, Bilsteins, 18x10 Enkei's
53 Ford F-100 Street Rod GT40'd and Carb'd 5.0/T5, IFS/IRS F-303 Cam,
beertestr is offline   Reply With Quote
Old 05-22-2009, 05:02 AM   #122
Trader Rating: 1
hey bro, I'm actually facing a money problem, and am not being able to work things out... so I have the car on hold, I haven't fixed any problems on the car, I actually got a new problem, while I was cursing in my car, I heard a small pop, and my transmission isn't shifting anymore, its stuck in N all the time, not matter where I put it, it revs with no car movement...
I'm still a student, and am graduating soon, then I'll refocus on the car, cause now I'm literary BROKE!
Don't hesitate to hi-jack this thread its ok, the more solutions you find it will help me too, since we have similar problems...
THANKS
wajouba is offline   Reply With Quote
Old 05-22-2009, 01:33 PM   #123
screaminChick-n's Avatar
Trader Rating: 0
Probabaly the cable just poped because it got too tight.....easy cheap fix.
I know a car it happened to once.....it got stock in nutral
screaminChick-n is offline   Reply With Quote
Old 05-25-2009, 05:41 AM   #124
Trader Rating: 1
it got stuck in neutral even when he shifts by himself, or only when the car was on OD?
Old 08-28-2009, 03:15 PM   #125
Trader Rating: 1
This thread died along time ago... anyhow, just for the record, Im going with an th400 now, screw the 4l60e, I took one hose out of the cooler and no oil was comming out so I guess that small pop sound was the pump...
Old 08-28-2009, 04:15 PM   #126
jfg455's Avatar
Trader Rating: 2
Quote:
yup. If the toque converter isn't seated properly it will just break the ring in the pump that holds the vanes. An easy fix but if it a th400 in a dead thread then screw it.
__________________
69 Chevelle SS 396, 70 chevelle frame off started, LQ4 T76 waiting to go in, 89 Pontiac Formula TPI 5 SPD SOLD, 74 Datsun 610 (soon to be 5.7LS1 TT TH400 w/brake)http://www.ls1tech.com/forums/conver...cide-fate.html
www.giffinsshop.com
jfg455 is offline   Reply With Quote
Old 08-28-2009, 06:05 PM   #127
NemeSS's Avatar
Trader Rating: 70
if your car is gonna stay n/a, i reccomend going with th350, 6.0 flexplate and spacer, sbc 10" tq converter, arp flywheel bolts. th350 are genarally cheeper than th400 and more efficient n/a. lighter.
__________________
LS1 SS
LoneStar1nnovationSS
NemeSS is offline   Reply With Quote
Old 09-09-2009, 11:36 AM   #128
Trader Rating: 0
if your coolant temp senesor si f'd it could be giving it SO MUCH FUEL that you could permanently damage your engines rings... borewash baby...
at -40 an engine uses like 3x as much fuel if not more, have you ever tuned a car? this is the truth, either that or it could be dangerously lean
another thing to check is if your tstat is stuck shut or open
buy yourself an hp tuners console if you can get around emmisions and delete the pcv and delete the 2nd o2 sensors etc... my car has all of these things and works great...
but yea, replace the CLT sensor first and foremost...
mxman is offline   Reply With Quote
Tags
14, 240, 240sx, change, gear, issues, ls1, mini, mode, mpg, obdii, port, put, rearend, timing, tubs, youtube
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
