Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 03-20-2009, 10:24 AM   #201
Trader Rating: 0
I have no idea about the Z31 firewall. It depends a lot on where you position the engine. I've seen some 240 swaps where the engine was low enough and far enough forward that no hammering was needed. On the other hand, some people have had to cut their firewalls. You can't tell until the engine and trans are in there. Once you test fit it, hammer the tunnel appropriately or cut it out and make a new trans tunnel/firewall if you have the time/welder. It's not that big of a deal.
Quote:
Originally Posted by 91ZLS6 View Post
Did you do those rod bolts the "1 bolt at a time" method?
Please tell me you didnt! :O
About these rod bolts... The ARP instructions said to install the bolts, torque to 45 ft-lbs., loosen, torque to 45 ft-lbs., loosen, final torque to 45 ft-lbs. I also looked up the instructions for Katech bolts. It was exactly the same as ARP. Remove the stock bolts, and torque the new bolts three times. The only difference was the torque spec. There are several writeups on here saying to do the same thing.
I've also read some people saying that installing aftermarket rod bolts can change rod bearing clearance by 0.002" and that you shouldn't do it? WTF? So what are you supposed to do? Wait until your stock ones snap?
On the writeups, people are saying specifically to do it one at a time so the rod cap doesn't shift during installation.
So WTF dude. I'm not saying you're wrong. If you give me a valid explanation or documentation saying to do it differently, I'll take apart the motor and redo it. But it's kind of gay to come on here and suggest I fucked this up without giving any explanation.
miro is offline   Reply With Quote
Old 03-20-2009, 12:30 PM   #202
dark_dementshun's Avatar
Trader Rating: 2
Yep, that is what i heard too. Take one side out at a time, and torque it down 3 times. Then after the final torque down, take out the other rod bolt and do the same thing. The theory was that since you are never taking all the tension off the rod bearings, they don't have to be resized or replaced because they never leave that natural "groove" they have developed over time. Otherwise if you were going to take them both out at the same time, they could unseat and and not sit correctly... which equals a spun bearing. I did read a couple places that the Katech bolts were a direct drop in replacement, whereas the ARP's needed rebalancing or something. I'm really not sure though, and if the company didn't say anything about it i would think you are good to go.
__________________
Where all my money goes...
11.85 @ 120mph First time out.
dark_dementshun is offline   Reply With Quote
Old 03-20-2009, 12:52 PM   #203
V8Rumble's Avatar
Trader Rating: 6
Quote:
That's how I did mine as well - and I rather STRONGLY suspect that if it was really something to be concerned about, ARP would include a note to that effect with the rod bolts, or at least have a reference to it in their online directions. And since I didn't see either one, I'm not going to lose any sleep over this - especially since mine is a new engine & hasn't even developed any kind of "wear patterns" yet...
FWIW, I made a point to go onto ARP's site when I swapped my rod bolts out, & didn't see any kind of caution like that. (That's not to say that I couldn't have missed it, but I'm pretty confident that we'll be OK.)
__________________
(Shooting for 450 HP, AND 30 mpg!)
Shown on p. 51 of August 2009 "Popular Hot Rodding" magazine.
V8Rumble is offline   Reply With Quote
Old 03-20-2009, 03:09 PM   #204
Trader Rating: 0
Thanks for the feedback guys. I don't know what other way you would install the bolts. Maybe torquing two at a time in steps would be recommended, but I've never seen this specified in the FSM or in rod bolt installs.
I'm pissed about these ARP bolts though. ARP says that they're supposed to be resized. Some people are saying ARP only says that to cover their ass and that they don't need to be resized. Nobody has a straight answer whether these can be used with stock rods with no modification. So screw it. I ordered Katech bolts. Katech explicitly says no modifications are necesary. They also have a higher tensile strength than ARP. I'll change to the Katech ones while the engine is still on the stand. The clutch and flywheel still haven't gotten here, so it's not like my engine is going in the car in the next couple of days anyway.
Old 03-30-2009, 01:05 PM   #205
Trader Rating: 0
you still waiting on stuffs?
BFTII40 is offline   Reply With Quote
Old 03-30-2009, 03:48 PM   #206
Trader Rating: 0
I'll post some pics tonight... lots of progress in the last week.
Car is close to being together... just waiting for some more suspension parts to come in.
I got the new Katech rod bolts and will put them in tomorrow. Do I need to install a new oil pan gasket when I put the oil pan back on? The engine hasn't been run, so I don't think it would be a problem, but maybe the aluminum part of the gasket has gotten deformed and won't seal properly the second time?
I actually have a new gasket that I got as a spare, put I don't want to deal with drilling out the rivets on the oil pan to remove the old gasket if I don't have to.
Old 03-31-2009, 12:48 PM   #207
Trader Rating: 0
So I was installing the NISMO Power brace on the car, and while tightening one of the bolts, the anchor (nut thing) inside the frame rail that the bolt goes into snapped off. This was truly an FML moment. I couldn't get the bolt out or in, couldn't remove the power brace, and couldn't reach the bolt to cut it off.
So I cut a hole in the frame rail, welded the nut back on, and patched the hole in the frame rail. Sweet.
Valvetrain parts.
Comp Cams 7-degree valve lock vs. 10-degree valve lock. Big difference.
Crane Cams valve compressor.
Stock stuff looks relatively clean and not broken. Yeah, I forgot to take pic of new stuff installed.
Spark plugs all look normal. Yay.
UPS found wheel.
Nasty coilovers.
Subframe bushing sleeves out. Big hammer was useful.
Nasty subframe.
Subframe and dash bar primered.
Clean coilovers.
Steering rack cleaned and painted.
Wing.
Diff painted.
Wing with wing-ends.
Old 03-31-2009, 12:54 PM   #208
Trader Rating: 0
Front suspension almost together.
Engine bay ready for... AN ENGINE.
Pedals, steering column, dash bar, hydro e-brake, cable e-brake, accusump installed.
Wing side.
Painted subframe. Yes, I realize the arms are on backwards. Eulises and I had a brain fart apparently.
Old 03-31-2009, 02:29 PM   #209
Trader Rating: 2
Yeah, that is quite a bit of progress! Looking good! I can't wait to see it up and running.
__________________
Old 03-31-2009, 04:24 PM   #210
Trader Rating: 12
I kinda like the pink with the black top. Black wheels would tie it all together nicely
__________________
2001 SS M6
G5X3, TSP true duals, QTP HVMC LT's, ported 241's/TB, Spec 3+, 17x11 black ZR1's, !maf, Flaming river manual rack, stock 10bolt
Jenson is offline   Reply With Quote
Old 03-31-2009, 04:46 PM   #211
Trader Rating: 6
Quote:
x2 black wheels would look sick on it
__________________
2001 zq8 ex cab s10
extremetoy is offline   Reply With Quote
Old 03-31-2009, 06:38 PM   #212
Trader Rating: 0
OMG thats some sexy shet!!
Old 04-01-2009, 11:54 AM   #213
_kirk_'s Avatar
Trader Rating: 1
I love your build man! All of the pictures are a great help!
I'm sure I'll be using your build as a reference in the future... I pick up my '04 GTO LS1/T56 this Saturday for my S13 coupe!!!
Keep up the nice work!
_kirk_ is offline   Reply With Quote
Old 04-01-2009, 03:31 PM   #214
Trader Rating: 0
Hey what's up guys, my name is Eulises. I'm been helping Miro w/ the build. I'm the one w/ the other stripped chassis you may have seen in the other pics. Figured better late than never to chime in. Thanks to everyone for all the kind words. Miro is definately motivated. As for wheels, we have a set of WHITE Work XD-9's staggered coming from Japan. Hopefully some more parts will be in this week to give you guys more updates. Enjoy!
EDT007 is offline   Reply With Quote
Old 04-02-2009, 05:48 PM   #215
Otto-813's Avatar
Trader Rating: 0
Good progress! How wide is that wing?
Otto-813 is offline   Reply With Quote
Old 04-03-2009, 12:40 AM   #216
Trader Rating: 0
It's 69".
Old 04-03-2009, 04:58 AM   #217
Trader Rating: 0
This build is gay Miro is gay ulysis is gay and I'm gay!!! LOL
UsJdmtuner is offline   Reply With Quote
Old 04-03-2009, 02:13 PM   #218
Trader Rating: 0
I see you're getting used to your new work schedule nicely... posting weird shit at 5am... haha.
Old 04-06-2009, 07:58 PM   #219
raymer626's Avatar
Trader Rating: 0
Just my opinion but I think it would look better with a smaller, well a lot smaller wing. I this one is only good for pulling up a barstool and eating food at the track. haha. Other than that, I think I'm getting used to the pink, NOICE!!!
__________________
82 Chevy Silverado 4x4 long bed stepside 383 stroker TH400.
71 Pontiac LeMans 350-TH350 needs brakes..and other stuff..
02 GMC CC D-Max
raymer626 is offline   Reply With Quote
Old 04-06-2009, 10:23 PM   #220
Trader Rating: 0
Quote:
girls like it bigger SON!!!
Tags
240, cats, dipstick, drift, filter, fuel, hose, list, ls1, miros, pressure, radiator, regulator, shooting, tires
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
