Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 01-18-2009, 08:52 AM   #61
LS1-450's Avatar
Trader Rating: 14
99 PCM needs the 2 wire 99 engine coolant sensor. 99-02 PCM & harness are the same, as you have noted.
__________________
LSX powered MUNSTER.....Mod's list? 5 lbs per HP with a sh!t load of low end torque...Friend to all car people...Thanks LS1Tech
LS1-450 is offline   Reply With Quote
Old 01-18-2009, 09:48 AM   #62
Trader Rating: 0
Why ditch the drive by wire?
Dan_W is offline   Reply With Quote
Old 01-19-2009, 12:36 AM   #63
dark_dementshun's Avatar
Trader Rating: 2
I have no desire to use it, and the engine didn't come with anything to support it other than the throttle body.
Dropped the subframe out today as well as stitch welded up the other side of the car. Probably going to start painting the engine bay tomorrow. Nothing special, just a satin black that will be easy to touch up later (since you always end up needing it). Ran into my first problem with the Boss Frog setup. The clutch master cylinder adapter isn't large enough to allow the cylinder to sit inside the plate. I could just make the hole larger, but i don't have anything that would do a nice, clean job of it. Going to call them tomorrow and see if it was just a random mistake or if i need to do some grinding.
Man do i love this build! Every time i work on it, i have a blast and don't want to stop.
__________________
Where all my money goes...
11.85 @ 120mph First time out.
dark_dementshun is offline   Reply With Quote
Old 01-20-2009, 03:59 PM   #64
Trader Rating: 2
Default Weekend photo update
There is not really much to add right now. I'm mainly just collecting parts to get everything going. The next big thing i need is a tranny. Still don't have quite enough saved up for it. Holiday season put a damper on the funds. Should be back up soon though!
Oh, the one thing i am trying is using spray on truck bedliner and painting black over that in the engine bay. In the past the paint alone has had a tendency to chip off after a couple bumps. I always like something that is easy to touch up.
I did pick up a new F-Body oil pan, windage tray, pickup tube, dipstick, and tube from a friend this weekend. The lip on the oil pickup is slightly dented in. I wonder if it would cause any problems?
__________________
Old 01-21-2009, 07:38 AM   #65
Trader Rating: 14
The BF kit probably uses the same clutch master cylinder as the v8roadsters kit. The v8roadsters kit however includes instructions on opening up the hole a bit. I uses some die grinder attachments on my cordless drill to open it up a bit. Only took about 5 minutes with the grinder.
Frank
fmowry is offline   Reply With Quote
Old 01-21-2009, 01:44 PM   #66
Trader Rating: 2
The V8Roadsters kit uses a 7/8" master cylinder, I do believe, while the Boss Frog kit uses a 3/4" that fits directly in the factory hole. I wonder what the difference in pedal pressure and engagement range would be. I would love to be able to drive my car for a while and then turn around and drive a V8Roadsters setup car.
__________________
Old 01-21-2009, 09:25 PM   #67
Trader Rating: 5
Looking good, nice engine! :-D
__________________
2000 Panoz GTWC Race car
LS1 Swap. Out with the Ford and in with the new!
eric1h is offline   Reply With Quote
Old 01-21-2009, 10:31 PM   #68
Trader Rating: 2
haha, thanks man. Congratulations again on getting yours today!
__________________
Old 01-22-2009, 06:40 AM   #69
LS1-450's Avatar
Trader Rating: 14
Quote:
A 3/4" adjustable master cylinder matches a stock GM master & is the correct master cylinder for the swap. I personally, would not be comfortable using a 7/8" master cylinder. IMO, it may cause a leaking slave cylinder in time. When guys document leaking or failing slaves, it's usually from double clutching or too much oil displacement that fatigues seals, all the while never realizing that it is the master or the double clutching that has caused the issue.
The key to a properly set-up hydraulic clutch is equal bore size & stroke adjustability.
__________________
Old 01-22-2009, 07:25 AM   #70
Trader Rating: 1
I dont know the ls1 rx7 guys almost all use the 7/8" and no one that I know of has had an issue, including myself
__________________
1989 Mazda Rx7 GTU
Bolt On Ls1/T56 Powered
Status: Running... Most of The Time
11.68 @ 120 1.73 60' 3rd time out
Stock Ls1 ported TB W/ Full exhaust
Slowhawk Tuned
sciff5 is offline   Reply With Quote
Old 01-22-2009, 09:33 AM   #71
LS1-450's Avatar
Trader Rating: 14
Quote:
Glad to hear it. It's still not something I would do.
BTW, not related to you, but mention of an rx7 swap reminded me of a few comments made to me that make me chuckle. Although, they are slightly different, many rx7's look like hard top Miata's & some share the same logo.
rx7 guy: Miata's are Gay, why didn't you just do an rx7 swap?
me: huh?
__________________
Old 01-27-2009, 02:55 PM   #72
Trader Rating: 2
I didn't get a lot done this weekend. All I really did was take some measurements and do some planning; mainly about what radiator i am going to use. Double pass radiators appeal to me mainly because of the inlet/outlet locations both being located on the passenger side. Then i was reading about the increased pressure they cause (roughly 16 times?), and wondering about wear on the water pump. Some people were saying more pressure would cause more water molecules to come in contact with the fins which would remove more heat from the coolant too. All i know is if i don't go with a double pass setup, i am not looking forward to routing the coolant line from the drivers side to the passenger.
Either way i did cut out the radiator support after taking these photos. I want to push the radiator as far forward as possible, and still leave room for some future plans.
__________________
Old 01-27-2009, 03:54 PM   #73
Trader Rating: 3
Looking forward to your rad selection. I still have not yet decided on mine.
Are you planning any mods to get the hot air out from the engine compartment or are you going to see how it turns out after the things running?
JDishong is offline   Reply With Quote
Old 01-27-2009, 08:31 PM   #74
Trader Rating: 2
I'm really liking the Simpson design hood. I think between that and some turn signal vents, it would be a decent start. Really, i'm going to wait and see how it does.
I'm more worried about how the radiator will cool with an intercooler in front of it... Then again that is a ways down the road.
Tomorrow i am going to be paying for my SECOND engine harness thanks to THIS GUY. (Payed him over 3 weeks ago. Now his phone is suddenly disconnected, and no response on here despite seeing him online everyday.)
__________________
Old 01-27-2009, 09:57 PM   #75
LS1-450's Avatar
Trader Rating: 14
dark, don't put up w/ that sh!t. Go to the Parts classified section; at the bottom is a negative trader feedback section where you can file a dispute. Also, send a PM to a moderator in that "Negative Trader Feedback" area. Mod list is always to the right of the link. Also, hopefully you used Paypal or a Credit card. Paypal will recover your money if you used them & you already know about a credit card payment recovery, I'm sure. Good-luck.
BTW, am glad you posted. I was suffering from LSX Miata build withdrawl.
__________________
Old 02-02-2009, 05:54 PM   #76
Trader Rating: 2
Test fit time.
I wanted to wait for the tranny to be here before dropping the engine in, but that might be another month or so away at this point. This is of course just a temporary thing. Engine should come back out by next weekend or so to make some necessary changes.
I already have an F-body oil pan that i know will fit. I was curious to see if the "batwing" Corvette pan fit though. It barely touches the subframe on the passenger side. The oil drain is on the front though, right at the cross section of the subframe. Would have to cut a hole if i ever wanted to use it.
Also the alternator is directly in the way of the drivers side headlight motor. I figure it would be easiest to just mount it in the F-body location, but farther back so i don't have to use a different alternator or accessories. Oh, and in case you didn't notice, good luck ever trying to run this setup with power steering. Now having seen the Corvette accessories in here first hand, i have to say i think the F-body setup is the way to go.
Even though it isn't there to stay, it sure makes me happy to finally see the engine in it's new home!
__________________
Old 02-02-2009, 09:12 PM   #77
Mr. Camaro19's Avatar
Trader Rating: 3
looking good man, keep the good work up
__________________
Mr. Camaro19 is offline   Reply With Quote
Old 02-03-2009, 12:12 AM   #78
V8Rumble's Avatar
Trader Rating: 6
Dang man, that thing's gonna run like a raped ape when you're done!
__________________
(Shooting for 450 HP, AND 30 mpg!)
Shown on p. 51 of August 2009 "Popular Hot Rodding" magazine.
V8Rumble is offline   Reply With Quote
Old 02-03-2009, 01:55 AM   #79
NoClassic's Avatar
Trader Rating: 23
Send a message via AIM to NoClassic
Great project.
Is the BF crossmember the only bolt in mounting solution for the miatas right now.
Its construction seems a bit questionable.
NoClassic is offline   Reply With Quote
Old 02-03-2009, 02:13 AM   #80
Trader Rating: 2
Thanks guys.
No, this is one of 3 companies (well maybe now just 2) that offer a bolt in solution for the LS in a Miata. The other 2 companies subframes are a tubular design with very little reinforcement. Although they have been used in cars with up to mid 400's horsepower wise, i wanted a little peace of mind. If anything, this subframe is overbuilt in my opinion. Questionable construction? Maybe a couple rough edges, but nothing questionable about it in my opinion. It should be able to hold as much power as the chassis and rest of the car can take.
__________________
Tags
302, boss, conversion, engine, frog, hattiesburg, ls, ls1, lsx, miata, mississippi, swap, trader, turbo, v8
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
