Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 07-13-2009, 05:38 PM   #101
Trader Rating: 0
i have a whole truck a 2001 chevy w/6.0 4l80e what do i need to keep off of it for a future motor motor swap thanks great write up
MUD MANIAC 44 is offline   Reply With Quote
Old 07-18-2009, 03:01 PM   #102
Trader Rating: 3
Is there any link to the $350 wire harness on ebay ?
attilahooper is offline   Reply With Quote
Old 08-08-2009, 03:21 PM   #103
1996 Pontiac Firebird
velox65's Avatar
Trader Rating: 5
Quote:
X2. I have a outdated link and the seller has no relisted items. However he did have a website but I can't find it anymore. Any one have a link. Needing a custom harness for my 6.0 swap into my 96 bird v6. Heard the body harness is different between the years and engine type on camaros but not the birds?
velox65 is offline   Reply With Quote
Old 08-08-2009, 04:34 PM   #104
BSmiff's Avatar
Trader Rating: 0
Send a message via AIM to BSmiff Send a message via MSN to BSmiff
What junkyard do you find your motors in? And how much did you spend on that turbo setup?
__________________
Just A Small Block
94 Camaro Z28 A4
BSmiff is offline   Reply With Quote
Old 08-08-2009, 05:03 PM   #105
velox65's Avatar
Trader Rating: 5
Looked through my history and found his home page, it's who Im going to get my harness for my 96 swap from. http://www.sspwiring.com/LS1_Wiring_Harness.php
Old 08-10-2009, 09:00 PM   #106
velox65's Avatar
Trader Rating: 5
Quote:
Highly recommend this guy! Gave em a call tonight and set me up nicely for my setup, knows his stuff and is very considerate. And cant beat the price.
Old 08-13-2009, 05:08 PM   #107
67Firebird455's Avatar
Trader Rating: 23
Send a message via AIM to 67Firebird455
Techrods looks like they have a nice unit on ebay.
__________________
Cen-Cal Racing
67 Firebird - S480 @ 19psi, 408, Custom Comp Turbo Cam, 9" w/3.89's, 3800 stall, TH400 on the way!
06 LBZ Duramax (360hp/650lbs-tq) 2500HD ECSB 4wd Pro Comp 6" Lift, Pro Comp 16" Xtreme Wheels + 35" Tires, PPE STD @ LVL 4 (225hp/335lbs increase), Transgo Jr. !EGR/!Resonator/!CAT 4" Mandrel Exhaust w/Coffin
67Firebird455 is offline   Reply With Quote
Old 08-14-2009, 12:09 AM   #108
Trader Rating: 1
I have some questions:
I will be picking up a truck 5.3 but I want to use my camaro style injectors and I already bought a car intake.
1- will the truck waterpump and pulleys etc work with an ls1 intake?
2- what is the bracket in the pics for the fuel regulator
3- which rail kit are you using?
4- in some of your pics I dont see coils on the valve covers. where have they been relocated to?
71 chevy is offline   Reply With Quote
Old 08-14-2009, 07:39 PM   #109
Trader Rating: 0
glad i found this randy! now u dont have to explain it to me over Fbook Chat! hahahaha
ParkerTPIz is offline   Reply With Quote
Old 08-16-2009, 08:40 PM   #110
vandejr's Avatar
Trader Rating: 8
if i wanted to mate the 5.3 engine with a th400 or 700r4 setup. what flywheel will i need to purchase . the 5.3 flexplate, and the convertor thats ment for the 700r4? just buy the spacers or what not? also i hear there are two different types of flexplates, one is dish and one is something else. if my 5.3 came out of an 03 tahoe can i just put whichever one that wont require the spacers for the convertor or the one ment for the year make and model?
__________________
my first fbody. 1994 lt1/8psi and only 106k original miles......
vandejr is offline   Reply With Quote
Old 08-19-2009, 03:25 PM   #111
BSmiff's Avatar
Trader Rating: 0
If you have questions, email him. He responded right back same day to mine.
__________________
Just A Small Block
94 Camaro Z28 A4
Old 08-25-2009, 11:39 AM   #112
Trader Rating: 1
i saw the link to the trans dapt motor mounts.......are those for an a body swap or just a universal mount.....what about the ones on ebay....o found them......1 of them is for a 1inch set back? which ones would work best for a 1970 elcamino....originally had a 350........also tryin to use the stock truck intake so clearance is an issue...anyone used them?
70cartruck is offline   Reply With Quote
Old 08-25-2009, 11:49 AM   #113
MeanYellowZ's Avatar
Trader Rating: 10
My best recommendation for motor mounts is to set the engine and trans in together and get it where you would like it, all while sitting on the FACTORY upper and lower mounts, minus the adapter plates. Then you can look and visualize by the bolt holes/ bosses in the block where you would need the adapter plate to go to get you closest to where you need to be. In other words set it all in the just sitting on your stock mounts and take a few good pics and someone can help direct you to what adapter plates you need.
__________________
www.YatesEFI.com
MeanYellowZ is offline   Reply With Quote
Old 08-26-2009, 03:05 PM   #114
Trader Rating: 0
So glad I found this thread. I have a 73 vette that I am restoring and wanted the LS1 swap but thought it was too expensive, now I know better. Thanks again.
__________________
'01 Formula,M6,Air lid,Lts,230/232 comp cam,custom tuned by Force Fed Performance,adjustable lower control arms, subframe connectors,adjustable panhard bar,magnaflow catback= 400rwhp!
Tooslowbirdman is offline   Reply With Quote
Old 08-31-2009, 08:33 AM   #115
Trader Rating: 0
good write up you hit all key points, To all member yes you can do this on a budget, I am doing a 1985 el camino Engine Cost $125 with wiring,,intake $50 off e-bay,,transmission 4l60e (no 2nd gear) $ 100,, transmission kit $ 79, fuel pump $120, ecm flashed $75= total cost $ 549,,, need
need help on TCC and brakes if someone can advise what wire or how shoul and unlock the over drive when I apply the brakes, i have not cut any wire from the harness
thanks in advance for any help
cmforte is offline   Reply With Quote
Old 09-11-2009, 04:22 PM   #116
Trader Rating: 1
What did you do for oil pan and waterpump?
T TA 355 is offline   Reply With Quote
Old 09-13-2009, 06:07 PM   #117
Trader Rating: 0
Default 73 vette
Glad to see this. Would like to go the ls route in a 73 vette. I had considered a full take out with accessories, but the price is always a little high. I like the idea of an aluminum or cast iron truck block. Someone clue me in on what I should look for or stay away from. Thanks
dfolse62 is offline   Reply With Quote
Old 10-01-2009, 10:12 PM   #118
Trader Rating: 0
Default Best ECM
Any suggestions for which is the best ECM to get for this swap. I should be picking up my motor and other parts over the next couple weeks so I'd appreciate the feedback. I'm getting either the LM7 or the LM4 version and I have an intake manifold set-up from an 04 GTO. I'm most likely going to keep this stock aside from headers and exhaust, and I will be running my th350 or a new th400. Thanks.
krh0003 is offline   Reply With Quote
Old 10-07-2009, 02:10 PM   #119
Trader Rating: 0
If I get a Lq4 engine and install a ls1 intake do I have to use the ls1 injectors and fuel rails? What engine harness do I use? The ls1 harness or the truck harness? Thanks.
bronx_peanut is offline   Reply With Quote
Tags
53, 67, aftermarket, c10, cell, difference, engine, fast, fuel, l33, lm7, ls, make, motor, year
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
