Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 04-28-2009, 10:43 PM   #21
1FastBrick's Avatar
Trader Rating: 9
Quote:
Originally Posted by LQ9CHEVELLE View Post
THIS IS EASY.....look at the flexplate (i cant see it clearly, but i know its on there from the pics) If it is a 4l60/65E flexplate, its a LQ9. LQ9 motors only came in 1/2 ton chassis applications (escalade, GMC Denali AWD trucks, etc). If it is a 4l80E flexplate (flat with the detachable steel spacer between flexplate and crank, and longer flexplate bolts, that means it came out of a 2500/3500 chassis truck, Van or Hummer, which definetly makes it a LQ4. This, of course, is correct as long as the flexplate on the motor is the original flexplate! BUT.......ya could always check a piston if all of the above fails! Any signs that the motor had the full plastic cover (valvecover to valvecover 3-piece cover, such as the "MAX" cover or the cadillac cover" can tip u off as to the motors origins. The oil filler cap will have a short, 1" - 11/2" plastic spacer tube between the cap and the valvecover, so it sits at the correct heigth with the LQ9 escalade engine cover. If it has the taller 3-4" plastic angled riser, it most likely is a LQ4, and didn't have a escalade or "maX" SS engine cover. BUT....you cold always take a peek at a piston if all else fails
Also some very good tips!
1FastBrick is offline   Reply With Quote
Old 04-29-2009, 12:08 AM   #22
71 chevelle's Avatar
Trader Rating: 5
Well from what I gather
I103 means September 10 of 03 with 317 alum heads dbw. Now to find out if its a lq4 or Lq9
Since I was told this was a 06 looks like it was 3 years off.
__________________
Project Syckness 71 velle 6.0L
ATS, Rushforth wheels, PRRC, Edelbrock/Russell, Autometer, UMI, Hotchkis, QA1, hood-latches.com, comp cams
71 chevelle is offline   Reply With Quote
Old 04-29-2009, 12:14 AM   #23
1FastBrick's Avatar
Trader Rating: 9
Looks like possibly an 04 model vehical and probally an LQ9 since thats the same style fly wheel used behind a 4L65E pull out the spark plugs and look for a piston that's close to TDC you will either see a slight dish or completely flat across.
LQ4= Slight Dish
LQ9= Flat top
Old 04-29-2009, 12:16 AM   #24
1FastBrick's Avatar
Trader Rating: 9
It does say 6.0 Behind the Fly Wheel under the casting number or under the water pump correct???
Old 04-29-2009, 12:20 AM   #25
Trader Rating: 5
Quote:
yes it does.
__________________
Old 04-29-2009, 12:24 AM   #26
1972 Chevrolet Malibu
Trader Rating: 2
Thats a 4l60/65E flexplate, so probably a LQ9. Just pop a plug and check it out though!
LQ9CHEVELLE is offline   Reply With Quote
Old 04-29-2009, 12:24 AM   #27
1FastBrick's Avatar
Trader Rating: 9
Quote:
Originally Posted by 71 chevelle View Post
yes it does.
Just checking... I dont have a list of casting numbers in front of me but after searching your casting number, 12551364, it looks like that block is a 6.0L casting used roughly from 99-04 applications. Being that it was cast in September, I would figure by the time it was assembled and installed in a vehical it was most likely an 04 model Vehical.
Old 04-29-2009, 10:10 PM   #28
pdsq98gt's Avatar
Trader Rating: 0
The flexplate theory doesn't work bexause the h2 has a lq4 and a 4L65e. The easiest way is to pull a spark plug out and look at the piston.
pdsq98gt is offline   Reply With Quote
Old 05-04-2009, 11:28 AM   #29
Bo185's Avatar
Trader Rating: 0
Quote:
Originally Posted by eviltwin_1987 View Post
now you need to figure out if its an lq9 or lq4. the escalade had the lq9. look on the back of the manifold to see if there is a plug where the brake booster hose would go. if there is a plug it will be an lq4.
Thats not the case some LQ9s had hydroboost as well.
The TBSS is an LS2 with a 90mm TB truck intake.
__________________
'73 Scout II 4x4 Vortec 5.3 4L65E np241
'01 VW Beetle TDI-50mpg or better!
'56 Belair 4 door hardtop*next LSx project* 5.3/4l60/3.08's (looking for 25+mpg!)
Bo185 is offline   Reply With Quote
Old 05-04-2009, 08:45 PM   #30
BORN2FLY's Avatar
Trader Rating: 52
Guys,
In 2003 the LQ4's were updated with better rods and coated piston skirts which helped to minimize the piston slap. Also, if it was manufactured in Sep 03 wouldn't it had to be installed in atleast an 04 model?
FYI: 99-06 Trucks, Vans & SUV
4.3L, VIN X or W(03+) (8th digit)
6.0L, VIN U (8th digit), (LQ4) Trucks, Vans and Denali
6.0L, VIN N (8th digit) (LQ9) Escalades & SS Silverado
4.8L, VIN V (8th digit)
5.3L, VIN T (8th digit, opt LM7)
5.3L, VIN Z (8th digit, opt L59)
5.3L, VIN B (8th digit, opt L33 05+ HO aluminum and iron block with 243/799 heads)
FYI: 07+ Trucks
classic style (crease in center of door skin), 6.0L, VIN U (8th digit, opt LQ4), CNG: natural gas and gasoline
new style (smooth door skin), 5.3L, VIN 0, 8th digit, opt LMG
new style (smooth door skin), 5.3L, VIN J, 8th digit, opt LY5
classic style (crease in center of door skin), 6.0L, VIN N (8th digit, opt LQ9))
new style (smooth door skin), 5.3L, VIN 3, 8th digit, opt LC9
new style (smooth door skin), 5.3L, VIN M,8th digit, opt LH6
new style (smooth door skin), 6.0L (VIN Y, 8th digit, opt L76)
classic style (crease in center of door skin), 4.3L (VIN X, 8th digit, opt LU3)
new style (smooth door skin), 4.3L (VIN X, 8th digit, opt LU3)
new style (smooth door skin), 4.8L (VIN C, 8th digit, opt LY2)
classic style (crease in center of door skin), 4.8L (VIN V, 8th digit, opt LR4)
classic style (crease in center of door skin), 5.3L, VIN T (8th digit, opt LM7)
classic style (crease in center of door skin), 5.3L, VIN Z (8th digit, opt L59)
classic style (crease in center of door skin), 5.3L, VIN B (8th digit, opt L33)
FYI:
5.3L: 2003-4 GMC Truck Envoy XL, 2003-4 Isuzu Ascender , 2003-4 Chevy TrailBlazer EXT (all with VIN "P", 8th digit) & 05-06 (all with VIN "M", 8th digit)
BORN2FLY is offline   Reply With Quote
Old 05-08-2009, 07:59 PM   #31
Trader Rating: 0
Why don't you just look at the VIN Derivative stamped in the block and then ask someone to look it up?
06 Escalade would be
66Rxxxxxx
Quote:
The vehicle identification number (VIN) is located on the left side rear of the engine block (1) and is typically a 9 digit number stamped or laser-etched onto the engine at the vehicle assembly plant.
• The first digit identifies the division.
• The second digit identifies the model year.
• The third digit identifies the assembly plant.
• The fourth through ninth digits are the last 6 digits of the VIN.
__________________
The answer man
GM World Class Technician
ASE Master Certified since 1988
L1 ASE Certified
CalEditor is offline   Reply With Quote
Old 05-20-2009, 02:11 AM   #32
Trader Rating: 0
I'm still confused on this one.. I will pull a spark plug tomorrow to look at the piston, but perhaps someone can shed some light on this for me.
Plus, I have pictures of two different motors that might help someone else in the future.
1.) 99/00 LQ4 motor. Notice the cable driven throttle body.
It has Iron Heads (though I don't see an actual casting number printed anywhere.. they are clearly iron heads).
Here's the back of the intake manifold for the port that is plugged on this one.
Here's the back of the crank.. note the big flange.. which is what prevents you from hooking this up to a T56... which is why I bought a new motor.
2.) LQ4 or LQ9.... I'm not sure???!?!?
It has an electronic actuated throttle body.
It has aluminum 317 stamped heads.
It has an open tube on the back of the intake manifold.
No big flange on the end of the crank.
All this talk about codes stamped on the blocks... I'm at a loss on this topic. The newer motor seems to have a K#00 on the front above the water pump. But the old motor also has something ending in 00. So that doesn't help me. The laser etch on the back is 12559287.
It's missing the oil filler neck.
I'm confused... Clearly it's a 01 or newer LQ4 or LQ9 motor because it's got 317 aluminum heads, the right crank flange, etc... But is it an LQ9... it's got the open tube on the intake manifold? Can anyone help me???
Eikon is offline   Reply With Quote
Old 05-20-2009, 09:36 AM   #33
topher455's Avatar
Trader Rating: 6
Pull a spark plug and feel across the top of the piston like I detailed above. You'll be able to feel if it is dished or not. Dish = lq4 no dish = lq9
__________________
86 Regal: Iron block LS2, T-56, Custom cam, 8.8 Diff, supporting mods, and a Custom 700cfm Fuel Metering Device (shhh its a carb)
My build: http://www.ls1tech.com/forums/conver...ion-again.html
topher455 is offline   Reply With Quote
Old 05-21-2009, 12:29 AM   #34
1FastBrick's Avatar
Trader Rating: 9
Any chance you could get a picture of the date code on the front??? also the casting number on back??? I have never seen laser etched numbers on the back of the block. Only casting numbers wich are cast in. Unfortunitally, I was not able to find any thing based on the number you provided.
Old 05-22-2009, 07:45 PM   #35
Trader Rating: 1
The VIN is laser etched on the heads and should tell you everything you need to know. (There are numerous VIN decoders on the Web) Also, the '06 LQ4/9's have aluminum (317) heads and the hydro-boost style vacuum ports on the rear of the intake don't mean much, the primary difference is in the pistons.
Good luck.
__________________
WTF-J
LQ9/4L65e/ETC/Atlas 2-Sp/D60s w/ARBs F&R/Bobbed Alu CJ8 w/TJ Airock susp. It rocks now that it rolls!
TomH is offline   Reply With Quote
Old 05-22-2009, 08:00 PM   #36
Trader Rating: 12
The motor pictures here is a 2002 LQ9. It's the same as what I got. Note the corvette style electronic TB. 2002 was the only year to get this style TB on the 6.0. It's also got EGR which went up to 2002.
GMCtrk is online now   Reply With Quote
Old 05-23-2009, 08:09 AM   #37
mred's Avatar
Trader Rating: 0
Something I picked up that very few people seem to know. Thought I would try and help out and share that Information. There is so much false information on this just this site alone...
"YES" finally someone has "confirmed"
mred is offline   Reply With Quote
Old 10-09-2009, 07:14 PM   #38
DutchmanZ's Avatar
Trader Rating: 3
Quote:
Good luck.
Can anyone tell me where this VIN info is on the head? I know this is an old thread, but I wanted to see if my 6.0 is an LQ4 or LQ9.
__________________
Monteray Maroon Met, LQ4 6.0L, M6, Pacesetter LT & ORY, Hooker Aerochamber Exhaust, Ported TB, LS6 intake & injectors, 85mm MAF, SLP Lid, Speartech Tuned
DutchmanZ is offline   Reply With Quote
Old 10-09-2009, 08:26 PM   #39
NemeSS's Avatar
Trader Rating: 71
Quote:
physically check top of piston by removing spark plug and verifying if piston has dish or smooth top.
i use old popsicle sticks, since there flat and thin
__________________
LS1 SS
LoneStar1nnovationSS
NemeSS is offline   Reply With Quote
Tags
12551364, block, casting, denali, etched, gm, laser, number, numbers, vin
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
