Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 05-21-2009, 09:41 PM   #1
Trader Rating: 0
Question Hooker swap headers and mounts
Hooker's got a bunch of ls swap headers and mounts available, but its prooving pretty tuff to figure out what pan fits with these. All this header/mount/pan homework is fuckin annoying
I'm runnin an LQ4 in a 68 A-body. Any body try these swap headers and mounts? if so what pan did you use? I called hooker and they couldn't give me an answer. The guy thot their parts were based on the F-body LS pan, but wasn't sure. I'd like to be sure (obviously) before i buy.
Anyone?
Thanx
68Hybrid is offline   Reply With Quote
Old 05-22-2009, 08:57 PM   #2
Trader Rating: 4
I had the Hooker swap mounts and headers on my 68 Chevelle. The pan I used is a Street & Performance modified f-body pan. A stock f-body pan will definitely not work with this combo. I would think that many of the aftermarket swap pans (Moroso, Milodon, Autokraft, Canton) should work as well, but I have no first hand knowledge of this.
68Chevells1 is offline   Reply With Quote
Old 05-23-2009, 08:06 AM   #3
mred's Avatar
Trader Rating: 0
i was told it would work and i was told it will not work.
bottom line is i believe the f-body pan will work with the hooker mounts and headers,you may have to use a tall and narrow factory motor mount,if i am not mistaken there are several different factory motor mounts.
short and wide and tall and narrow and the 6 cylinder. need to do some checking on that.
there is alot more stuff you need to know as far as making the motor fit, i will leave the rest up to you, to figure out. Research SKILLS
i had a minor set back to where i had to stop with my build.
good luck
mred is offline   Reply With Quote
Old 05-23-2009, 08:12 AM   #4
forcd ind's Avatar
Trader Rating: 1
im running a 69 chevelle, using the Hooker headers & mounts-i used the caddy CTS oilpan, minor bump with the tie rods on lock to lock, but its been on there a year, no problems, and its factory piece
forcd ind is offline   Reply With Quote
Old 05-23-2009, 08:16 AM   #5
mred's Avatar
Trader Rating: 0
which mounts did use,and could you have added come shims to clear the tie rods? another words raise the motor a bit
Old 05-23-2009, 12:36 PM   #6
Trader Rating: 0
Get a LH8 pan they are factory from the H2 ( I think) and are only arpund $250
http://www.brphotrods.com/Oil%20pan.html
Phat69 is offline   Reply With Quote
Old 05-23-2009, 01:33 PM   #7
forcd ind's Avatar
Trader Rating: 1
i used the 350-454 frame mounts, some guys have raised the engine, i fig if it really bothered me i would just notch the pan a little when i do my stroker swap-i "tweaked" a pitman arm and idler arm a tiny bit to lower the drag link and it cleared, nothing noticable in the bumpsteer area, but didnt change it when i installed new front end parts-that other pan looks interesting, but think the same tie rod clear. would be there, would have to meas the pan depth in the same location-must be some kind of Hummer pan or Holden, or something
Old 05-23-2009, 04:51 PM   #8
Project GatTagO's Avatar
Trader Rating: 5
Send a message via AIM to Project GatTagO
Raising the engine is a super bad idea.
Andrew
__________________
1970 GTO Version 2.0 in progress
V8TV Feature video
Popular Hotrodding feature
Car Craft feature
"You were the gun, your voice was the trigger, your bravery was the barrel, your eyes were the bullets."
Project GatTagO is offline   Reply With Quote
Old 05-26-2009, 09:33 PM   #9
mred's Avatar
Trader Rating: 0
Quote:
Andrew
"Y" in some applications a raised motor can benefit.
weight transfer is going to be better and clearance is going to be better.
Old 05-27-2009, 02:01 AM   #10
RYU
Trader Rating: 0
Andrew
if the pinion angle is fine i don't see why raising a motor is such a bad idea
RYU is offline   Reply With Quote
Old 05-27-2009, 02:22 AM   #11
Trader Rating: 0
Quote:
How low does the pan hang compared to ur crossmember?
Old 06-05-2009, 07:55 PM   #12
Trader Rating: 0
Back to the top
Any one else?
Forced ind: How low does ur oil pan hang? Any pics available?
Tags
chevelle, frame, hooker, lh8, ls1, motor, mounts, oil, pan, raised, raising, swap
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
