Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
LSX Engines in Non-LSX Vehicles
Sponsored by
Don Hardy Race Cars
Old 05-28-2009, 11:48 AM   #1
Trader Rating: 0
Default Mazda RX-8 LS-1 swap =VIDEO=
Here are a few pictures of our project.
It is running but there are few things that needs to be sorted out.
This RX-8 had a blown engine so this swap was the most obvious thing to do.
The engine comes out of a 2004 GTO.
Motorstilling is offline   Reply With Quote
Old 05-28-2009, 12:03 PM   #2
rao
rao's Avatar
Trader Rating: 8
Nice!
Those rotaries are always blowing up . The folks at www.v8rx7.com would be very interested in this swap.
__________________
Rob
Current - 1992 BMW 325i LS2 Stroker/T56
Old - 1995 BMW M3 LS2 Stroker/T56
Video
rao is online now   Reply With Quote
Old 05-28-2009, 12:43 PM   #3
383lt1impala's Avatar
Trader Rating: 27
Send a message via AIM to 383lt1impala Send a message via Yahoo to 383lt1impala
That's bad ass!!!!
__________________
1995 PIMPALA SS #419
MY TWIN TURBO LS1/TH400 SWAP THREAD!
383lt1impala is offline   Reply With Quote
Old 05-28-2009, 01:00 PM   #4
Convette's Avatar
Trader Rating: 0
Is that the stock rx8 rack and pinion? Also what drive shaft are you using?
Convette is offline   Reply With Quote
Old 05-28-2009, 01:08 PM   #5
KINTARO's Avatar
Trader Rating: 0
what headers and oilpan
KINTARO is offline   Reply With Quote
Old 05-28-2009, 01:11 PM   #6
1988 Pontiac Trans Am
firechicken76's Avatar
Trader Rating: 13
HELL YES, do you know how long ive waited to see this? any video?? how hard was it? how did the Renesis blow? I used to own one of these cars, they are guttless, glad to see something being done to fix that!!!
__________________
1988 Trans am GTA 02 ls1/t56
suspension, brakes, bolt ons
Fquick page
primer grey now...Pic is from Forza 3
firechicken76 is offline   Reply With Quote
Old 05-28-2009, 08:20 PM   #7
Trader Rating: 4
Does the shifter fall in the correct place? Were the mounts a add on to the existing subframe or a new subframe?
finiata is offline   Reply With Quote
Old 05-28-2009, 08:39 PM   #8
NemeSS's Avatar
Trader Rating: 71
dam that looks rigth at home
what oil pan, mounts, etc.? any more info?
NemeSS is offline   Reply With Quote
Old 05-28-2009, 08:47 PM   #9
Trader Rating: 13
probably gonna need a new rear end?
oh no, they threw off the 50/50 distribution, now it wont be able to corner jk
the rotards are gonna throw a fit when they see this.
__________________
Fquick page
Old 05-28-2009, 08:47 PM   #10
Trader Rating: 13
interested in the weight of the car also
__________________
Fquick page
Old 05-28-2009, 08:48 PM   #11
b005td's Avatar
Trader Rating: 8
werd
need more info
b005td is offline   Reply With Quote
Old 05-28-2009, 09:17 PM   #12
Trader Rating: 24
That looks fantastic! We must have more info though.
__________________
Contact me about fender roller rental. $50 for a week....
1987 Turbo 2 RX7+LS1/T56=
405whp/362tq cam only...
NMJ87T2 is offline   Reply With Quote
Old 05-29-2009, 08:45 AM   #13
Trader Rating: 0
We drove it for the first time yesterday.
It has plenty of power
The gearing is very low, we are using the stock 4,44 differential.
First gear is almost useless.
We are using a Camaro steering rack and oil pan.
And there are no gauges yet, the 8 uses CAN bus cluster so I think it is impossible to use it with this setup.
Old 05-29-2009, 09:01 AM   #14
Snyper's Avatar
Trader Rating: 21
Send a message via AIM to Snyper
Quote:
My 350z uses the same setup and Im using a CAN gateway. As much as I dont want to say this you should contact Hinson Super cars and see if they can help.
__________________
2004 Nissan 350z/LS2/PT88--Project 88 has begun.
Snyper is online now   Reply With Quote
Old 05-29-2009, 09:30 AM   #15
Trader Rating: 0
Quote:
You are using the LS2 wich has a CAN bus system, right ?
Old 05-29-2009, 09:40 AM   #16
MyLS1rx7's Avatar
Trader Rating: 1
Send a message via AIM to MyLS1rx7
Sweet! I have been waiting to see somebody do this for years...
__________________
LS1 FD
MyLS1rx7 is offline   Reply With Quote
Old 05-29-2009, 09:45 AM   #17
Trader Rating: 13
Quote:
Same here! This is indeed an obvious swap, hope you can kit this. This thing handles and has a useful back seat. May want to do something about the gearing to make first gear workable. The GTO tranny has different ratios, so that's only making first worse.
AWESOME SWAP! Video!!
jmilz28 is offline   Reply With Quote
Old 05-29-2009, 10:02 AM   #18
OMGWTFBODY's Avatar
Trader Rating: 5
Send a message via AIM to OMGWTFBODY
Baller.
__________________
http://www.ls1tech.com/forums/image.php?type=sigpic&userid=86670&dateline=123222  2196
OMGWTFBODY is offline   Reply With Quote
Old 05-29-2009, 10:16 AM   #19
Snyper's Avatar
Trader Rating: 21
Yes. But im not using the CAN lines for the readings. My speedo setup is independent. It takes readings right off the rear end. The tach had to be spliced in using the Can gateway though.
__________________
Old 05-29-2009, 12:42 PM   #20
Trader Rating: 13
need video!!!!
__________________
Fquick page
Tags
350z, bus, engine, hinson, kit, ls, ls1, ls2, mazda, motorstilling, nissan, rx, rx8, swap, tach
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
