Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 06-11-2009, 07:34 PM   #21
Bo185's Avatar
Trader Rating: 0
Quote:
Originally Posted by dmaxben View Post
4L80 would have to be massively built to withstand even a MILDLY tuned duramax, and even then the overdrive in it is still weak.
ben
The fullsize vans have the d-max and 4l80 stock! The d-max's were detuned alittle!
A built 4l80 will hold that. Some have put 1000hp and tq though them with a turboed LSx. Plus they are smaller than the allsion anyway.
__________________
'73 Scout II 4x4 Vortec 5.3 4L65E np241
'01 VW Beetle TDI-50mpg or better!
'56 Belair 4 door hardtop*next LSx project* 5.3/4l60/3.08's (looking for 25+mpg!)
Bo185 is offline   Reply With Quote
Old 06-11-2009, 07:56 PM   #22
Trader Rating: 6
Send a message via Yahoo to Black FormulaLs1
i was wondering about the weight issue myself...but can you honestly argue with 1K ft lbs of torque on command? my question would be wtf rear end you gonna put in it..
__________________
346 Forged bottom end,P&P 241's, Lunati cam, Ram VDS Pkg, Stage 2 TICK PERFORMANCE T56, moser 12 bolt...sooon #'s and 200 shot
old times with just exhaust and Dr's..
12.56 @ 110 - 1.85 60ft
Black FormulaLs1 is offline   Reply With Quote
Old 06-11-2009, 07:58 PM   #23
Bo185's Avatar
Trader Rating: 0
Quote:
14 bolt or a 9 inch. It only matters if it hooks though!
__________________
Old 06-11-2009, 08:46 PM   #24
Trader Rating: 1
it's kind of the wow factor. it's mostly just having an insanely fast car that's still drivable. sure, you can put a twin turbo aluminum short block to 1000 hp, but it won't have much more torque. diesel engines are more efficient. they'll make more power with the same fuel. i'll have great mileage and street manors on the road, and insane track times. what more could you ask for?
as far as trying to get the car to hook i'll run 3.08 gears (to compensate for the stock 3200 rpm red line), i'll have to run huge slicks/drag radials, and the Henessey viper adds more power as speed increases to help with traction, i could probably get a progressive tune like that.
__________________
2000 ecsb: intake, custom slp loudmouth exhaust, cat delete, e-fans
to do list: headers and true duals, tune (waiting to go in)
"A true hotrodder wouldn't be content until he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
jeforton is offline   Reply With Quote
Old 06-11-2009, 08:52 PM   #25
NemeSS's Avatar
Trader Rating: 71
sounds like a neat project
im currently 508rwtq n/a, and its hard to find traction in 1st or 2nd, even with dr .
im sure that tq will take its toll on the chassis if u dont upgrade all susp.
NemeSS is offline   Reply With Quote
Old 06-11-2009, 09:27 PM   #26
Trader Rating: 1
ya, i'm sure i'm going to have to do some awesome suspension mods to it. the cool thing about diesels though, is because of the injection system you can keep several tunes on hand. if i want to just cruise town, i can load up a really mild tune and not have many traction issues, or if i want to haul ass i can load up a powerfull tune and pickup a huge amount of power. even a heavily built diesel can be detuned to not make much power, and then in two minuets bet tuned for full power.
bo158, do you mean the 14 bolt 3/4 ton truck axle?
__________________
Old 06-11-2009, 10:02 PM   #27
Bo185's Avatar
Trader Rating: 0
Yep! The 14 bolt FF thats out of the trucks. Might stick out the wheel wells alittle though! Air bag it to handle the weight.
__________________
Old 06-11-2009, 10:20 PM   #28
zstripper2k's Avatar
Trader Rating: 0
In diesel power mag there was a duramax powered mid to late 90's model mustang so i would most definately say it would work. Full cage and lots of fab to keep the chassi shraight.
__________________
2000 Z-28 1SC/1SZ
2002 SS 35th LE CME (Wife's Ride)
zstripper2k is offline   Reply With Quote
Old 06-12-2009, 12:40 AM   #29
Trader Rating: 1
Quote:
Originally Posted by Bo185 View Post
The fullsize vans have the d-max and 4l80 stock! The d-max's were detuned alittle! .
I realize that. They are detuned a LOT...more than 100hp and 200ft lbs less torque than the pickup versions.
I think you are severely underestimating the way a diesel engine delivers power and how it is so much more brutal on drivetrain parts than a gasser. A 4L80 that Joe Tranny Builder runs problem-free behind his 1200hp big block wouldnt last 2 passes behind a 500hp duramax (which can easilly be obtained on a 100% stock motor, all you have to do is dump a good tune in it and add a 250 dollar extra fuel pump).
You can build a 4L80 all you want, but you are still going to blow the overdrive out of it as soon as it shifts into 4th on a WOT pass, depending on how heavy the vehicle is, what sort of traction you get on launch, and how hot the tune is.
There is a reason all the 7,500 pound 11 second pickup trucks are running allisons and the only guys running 4L80's behind duramax's are the lowly Express vans.
ben
__________________
-2005 silverado 2500HD, duramax diesel, 7680lbs race weight, low 12's.
-1968 vw beetle, 4x4, 34" swampers, LSx 4.8 vortec still in the rear...
dmaxben is offline   Reply With Quote
Old 06-12-2009, 12:43 AM   #30
Trader Rating: 1
nodular 9" would probably do the trick, depending on how heavy the vehicle is...
just my opinion.
__________________
Old 06-12-2009, 12:46 AM   #31
Trader Rating: 1
or, if you want something smaller and lighter than the allison that will still take the power of a tuned up duramax, run a dodge 47re.
__________________
Old 06-12-2009, 02:31 AM   #32
Trader Rating: 1
ya, i'll go with the 3/4 ton axle. be the first car in 8 Lug Magazine, lol. if i go with that, and i just might, i'll probably take it to an axle shop and have them cut it down and narrow it some so it'll fit.
well, to end the tranny war going on here, i'm going to use a lly/lbz with an 06+ style 6 speed allison. i'll probably start out with a suncoast stage IV kit, and when/if that goes, i'll jump up to an ATS stage 6 tranny.
i'll keep the dodge tranny in mind for the future, but i figure the best way to do this is to buy a donor truck, like a roll over or something with frame damage, and jerk the duramax/allison/rear end right out of it. that way i have everything and won't need to worry about aftermarket stand alone engine/tranny computers.
__________________
Old 06-12-2009, 03:28 AM   #33
Trader Rating: 0
Quote:
Originally Posted by 68Hybrid View Post
I did find tho that the V-10 turbo diesel from the Audi LeManns car which is the same aluminum block and archetecture as the V-10 turbo diesel available in the top of the line Toureg (i was hopin to find a wrecked one) weighs about the same as an iron headed small block. Trans aint too heavy either...
Put that in ur pipe n smoke it.
actually you are wrong! the Audi Le Mans engine was a Ally V12 twin turbo. And the only thing it had in comon with the V10 engine was the fuel used......
Intresting project. would love to see it done!
Chris.
PS. the VW racing Toureg used the Audi V12 engine (mid mounted driving rear wheels) and not the V10 also. V10 is still a greate engine but i bet its about as big as d-max's and probably weighs as much as it is an IRON block...
chuntington101 is offline   Reply With Quote
Old 06-13-2009, 10:42 AM   #34
383lt1impala's Avatar
Trader Rating: 27
Send a message via AIM to 383lt1impala Send a message via Yahoo to 383lt1impala
I think that its an awsome idea!!!! I'm also thinking of swaping a 5.9 into my impala. If they can put them in old corvettes and monte carlos I can do the same. And I keep reading around that about 1000hp and 1900ftlbs is quite doable on the 24v's with just turbo and fueling upgrades. I would have to spend about 40+grand to hit that on gas. And you gotta admit the black smoke looks bad ass!!!
__________________
1995 PIMPALA SS #419
MY BUILT LS1/TH400 SWAP THREAD!
383lt1impala is offline   Reply With Quote
Old 06-13-2009, 11:20 AM   #35
Trader Rating: 1
Quote:
haha not quite..................
ben
__________________
Old 06-13-2009, 11:34 AM   #36
NemeSS's Avatar
Trader Rating: 71
good luck
Old 06-13-2009, 01:08 PM   #37
Trader Rating: 27
ben
I'm taking it that u don't read the diesel power magazine? There's a 2500 dodge in the latest issue that makes over 800hp and 1500ftlbs. Stock internals. Just with a cam, turbo and fuel.
__________________
Old 06-13-2009, 04:03 PM   #38
Trader Rating: 1
true, but a cam doesn't count as "turbo and fuel". and that's still a fair bit short of 1000 hp and 1900 torque.
__________________
Old 06-13-2009, 04:25 PM   #39
Trader Rating: 1
If Diesel Power could get 1/8 of the tech crap they post in their magazine accurate/correct, I would read it.
If you think 800+ rwhp is as easy as you are making it sound, you are dreaming. Plus, 800rwhp is scary enough in a 7,200+ lb truck, wtf do you think you are going to do with an 800rwhp diesel in a car? I guarantee a diesel in an f-body with "only" 500-525rwhp would be more than enough to scare the crap out of you. 2wd starts being useless above 450rwhp on a diesel anyways. You cant compare HP levels of diesel engines to gas engines. I know that "hp is hp, doesnt matter which engine", and I cant explain why it is completely different with a diesel engine....but it just is.
Just my opinion.
ben
__________________
Old 06-13-2009, 04:58 PM   #40
Trader Rating: 1
i think the word you're looking for is torque.
besides, it's not like i'm going to try to launch with that much power. i'm pretty sure i could get a progressive tune, kind of like the viper venom. and even if i can or can't do a progressive tune, i'm going to have several tunes. true, 450-500 rwhp would be plenty most of the time, there's a few times when it won't be enough. i don't want a duramax with just a tune. i'm going to stroke it(mostly just because i want to), cam it, injectors, and twin turbo it, all later down the road. true, i'm never going to need that much power. and i'll probably only use it a few times. but it's there if i ever want it. i'm going to keep a very week street tune on hand so i don't waste my tires every time i try to take off from a stop light. but if i ever want more, it will be there. your signature says you have a 12 second truck. do you need all that power? probably not, but you still have it anyway.
__________________
Tags
66, 9365, allison, chevy, diesel, dt466, duramax, find, fit, indiana, injection, methanol, transmission, truck, turbo, wreck
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
