Nice build. As mentioned before you really should support that turbo somehow. Off of the engine preferably since there are no flex joints in your hotside piping. It would suck for any of that stainless to crack.
__________________ 86 Regal: Iron block LS2, T-56, Custom cam, 8.8 Diff, supporting mods, and a Custom 700cfm Fuel Metering Device (shhh its a carb)
Great fab work!! I too moved the radiator to the very front just for run for my turbo set-up. I can now have a good idea of how it is going to look and its a silver Fd like mines too.
For those wondering the turbo I am using is a borg warner s475. I plan to use a 44mm tial wastegate and am going to make equal length tubular manifolds from stainless steel.
Very nice work! What happened to the plan to use equal length manifolds? No room?
That shit is weaksauce. If your goal was to go fast, you should have swapped in a rotary and made some real power.
Also, your welder is a piece of shit, Lincoln is where it is at. Any true fabricator would know that. Borg Warner sucks too. Yep, you're just full of fail all around.
nice build OP! you have some fab skills too. DIY always gets it done the right way! save alot on labor too.
that has to be a joke LSZero. the vid below your post explains alot.
__________________
Late Model Specialties
1994 Camaro- 6.5L Diesel-HX35W-4L80E-ATA cooler-Transgo-Racor R90S-UMI-TCI-SSBC-DB2 4974-Walbro LP-EGT-LS1 brakes-fuel cell-roll bar
Nice build OP. One day I'll be able to weld like that...one day... lol
__________________ 1995 DCM SS - 6.0L LQ4, intake, Headers, Vogtlands, Billets and some other -ish
Next Up: Custom Cam, "832" Valvesprings,3.73s & TuTrac Posi
