Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
LSX Engines in Non-LSX Vehicles
Sponsored by
Don Hardy Race Cars
Old 06-27-2009, 09:01 AM   #1
98Camarod's Avatar
Trader Rating: 25
Default Taurus fan wiring
I'm installing a Taurus fan in my fbody and I'm stuck at the wiring portion of it. I bought a 75amp relay, I just can't seem to find anything that is useful to me. I have a Griffin radiator that is stood up, that's why the stock fans don't work. I only want the high speed wired up, which is the reason for the 75amp relay. I'm assuming that an inline fuse would be useful, but what amperage should I go with? What gauge wiring should I use and what pin for a 98 is for the fans? I have hp tuners so I can adjust when they come on without any problem. Thanks for the help!
__________________
Ebay Turbo Kit l Cam l Moser 9" l th400
98Camarod is online now   Reply With Quote
Old 06-27-2009, 10:56 AM   #2
98Camarod's Avatar
Trader Rating: 25
30 is constant power 8awg
87 goes to power the fan 8awg
86 is for fan control 16-18awg
85 is ground 16-18awg
and then use 8awg for ground straight from the fan.
What size inline fuse?
How does that sound?
__________________
Old 06-27-2009, 11:06 AM   #3
Trader Rating: 6
http://forums.hybridz.org/showthread.php?t=99700
__________________
'99 B4C Police Camaro (1 of 18 Mystic Teal '99 B4C's)
'96 9C1 Police Caprice (daily driver)
LSX swaps I've done:
http://s704.photobucket.com/albums/ww41/aknovaman/
aknovaman is offline   Reply With Quote
Old 06-27-2009, 11:07 AM   #4
1995 Chevrolet Camaro
the_merv's Avatar
Trader Rating: 38
That sounds like it will work..put a 15A Fuse on the 86 Wire for safe measure. Also try to get that Wire for that 86 to some from an Ignition wire..one that is hot with the Key on.
For the 85 wire make that come from the Fan Control Wires in the PCM.
__________________
1995 CAMARO Z28 HARDTOP M6
BUILT 408 IRONBLOCK | L92/L76 TOP-END | COMP CUSTOM CAM
MOSER 9" | BUILT T56 | EIBACH PRO KIT | BILSTEIN SHOCKS | 3" TD's WITH X-PIPE
SWAP-->>ENGINE BUILD/T56 BUILD/LSX WIRING<<--THREAD
the_merv is offline   Reply With Quote
Old 06-27-2009, 03:47 PM   #5
98Camarod's Avatar
Trader Rating: 25
Why would it matter if it is switched or not? It won't come on until the computer tells it to right?
__________________
Old 06-27-2009, 05:56 PM   #6
the_merv's Avatar
Trader Rating: 38
I don't understand what you mean..for the Computer to control it you will have to have the 85 wire coming from the control Wire that is from the PCM.
__________________
Old 06-27-2009, 08:05 PM   #7
98Camarod's Avatar
Trader Rating: 25
I was talking about the constant vs. switched power. I just put pin 30 on a switched source on the front fuse box.
I thought the 86 was the pin that uses the PCM and 85 was a ground.
__________________
Old 06-27-2009, 08:14 PM   #8
98Camarod's Avatar
Trader Rating: 25
Here is the schematic I found. Instead of using the controller, just use the pcm in it's place.
__________________
Old 06-30-2009, 04:11 PM   #9
the_merv's Avatar
Trader Rating: 38
Other way around.. 86 is the power from the IGN..85 is the side from the PCM. The PCM grounds it out and activates it.
__________________
Old 07-01-2009, 05:24 PM   #10
98Camarod's Avatar
Trader Rating: 25
I got it wired up the way the schematic shows and it works.
The fan kicks ass BTW
__________________
Old 09-15-2009, 09:33 PM   #11
Trader Rating: 14
Send a message via AIM to blazin Send a message via MSN to blazin Send a message via Yahoo to blazin
Using the stock fan plugs wont work? I used them on my flex alites and never had a problem.
__________________
96 Z28. Stock
99 Silverado
blazin is offline   Reply With Quote
Old 09-16-2009, 12:05 AM   #12
98Camarod's Avatar
Trader Rating: 25
Quote:
They draw too much current
__________________
Tags
fan, relay, taurus, wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
