Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 08-03-2009, 10:09 PM   #1
Trader Rating: 0
Default 6.0 lq9 swap in 55 chevy
hi doing a lq9 swap in a 55 chevy. im using the 6.0 liter liter returnless fuel rail.
i am wondering if -8 to a walboro 255 is too much ? i have searched and most say -6 i fine, but i already have the car plumbed for -8 when it was a an na smallblock.
i have found these fittings and was going to use this pump and a vette filter.
basically what i am asking is -8 too big on a mostly stock 6.0? will it hurt anything?
primer55 is offline   Reply With Quote
Old 08-03-2009, 10:29 PM   #2
Bo185's Avatar
Trader Rating: 0
Should be fine as the vette filter/regulator will take care of the pressure.
Were you putting the vette regulator/filter at?
__________________
'73 Scout II 4x4 Vortec 5.3 4L65E np241
'01 VW Beetle TDI-50mpg or better!
'56 Belair 4 door hardtop*next LSx project* 5.3/4l60/3.08's (looking for 25+mpg!)
Bo185 is offline   Reply With Quote
Old 08-04-2009, 09:27 AM   #3
Trader Rating: 0
Tank is sumped so planning on putting pump on rear crossmember then running line down the side of passenger frame rail. Was goingto mount vette filter on frame rail even with front of tank and run return line back to stock return line on factory sending unit . After more checking I'm thinking I may just run 3/8 line or -6 black pushlock.
Old 08-04-2009, 10:58 AM   #4
Bo185's Avatar
Trader Rating: 0
Make sure to leave room for an exhaust piping. Its an easy mistake to have it to close!
__________________
Tags
1955, 55, 60, chev, chevy, frame, lq9, swap
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
