Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
Sign in using an external account
Register Forgot Password?
LSX Engines in Non-LSX Vehicles
Sponsored by
Don Hardy Race Cars
Thread Tools Search this Thread
Old 08-04-2009, 07:26 PM   #1
Garage is empty, add now
cash's Avatar
Trader Rating: 1
Default 5.3 wiring question
Where is the alternator plug? all I have is the hot wire connection, I pulled the harness out of 2005 silverado, cant find the plug
cash is offline   Reply With Quote
Old 08-04-2009, 07:36 PM   #2
vandejr's Avatar
Trader Rating: 12
do u mean where on the harness or on the ecu?
http://www.lt1swap.com/2004vortec_pcm.htm
it shows the gray wire on port 75 of the ecu on the green bundle and most alternators are one wire arent they?
__________________
my first fbody. 1994 lt1/8psi and only 106k original miles......
vandejr is offline   Reply With Quote
Old 08-04-2009, 09:12 PM   #3
cash's Avatar
Trader Rating: 1
On the harness
Old 08-05-2009, 05:21 AM   #4
Trader Rating: 0
Should be right next to the connector for injector 1 and the wiring for the IAC and TPS (with a cable TB)
Jones'n is offline   Reply With Quote
Old 08-05-2009, 07:46 AM   #5
1984 Chevrolet Monte Carlo
the_merv's Avatar
Trader Rating: 82
It has a Red Wire, 4-pin Connector.
__________________
1984 MONTE CARLO SS M6, 475 RWHP/406 RWTQ - 408, TEA PORTED L92's, EPS CUSTOM CAM
1991 S10 SINGLE-CAB SHORT-BOX - LS1 A4 DAILY DRIVER BEER/PARTS TRUCK
LOW 7's IN THE 1/8, FULL WEIGHT
the_merv is offline   Reply With Quote
Old 08-05-2009, 12:47 PM   #6
cash's Avatar
Trader Rating: 1
Thanx
Old 08-09-2009, 05:06 PM   #7
Trader Rating: 3
Send a message via MSN to busta9876 Send a message via Yahoo to busta9876
here's the run down.
LS1's used a single RED wire in a 4 position plug as pictured a few posts above.
Vortec 4.8/5.3/6.0 series used sometimes a single brown wire in the same location as the red above, and sometimes 2 wires, brown and gray. - 4 position plug.
Around 2005 or 2006 on the Vortec trucks, the PCM no longer connects to the alternator on some vehicles, and now there is a generator-battery control module, or GBCM for short. This monitors current draw on the negative battery cable, and controls the alternator its self. These alternators had a narrow 2 pin plug with two wires, gray and brown.
I have seen in some late model harnesses a 3rd blue wire, unknown what it is for, as it does NOT go to the PCM.
__________________
1967 Chevy Pickup, 5.3L 4L60E, ASA Cam, 3200 TCI Stall
1989 Chevy Caprice, 5.3L 4L80E Twin Turbo Project - moved back up to the front burner!!
1986 Chevy K5 Blazer, 5.3L TH400, 208, Dana 60/14 bolt on 38'' TSL's
2008 5.3L LC9 on the engine stand..where will it go?
busta9876 is offline   Reply With Quote
Old 08-10-2009, 04:33 AM   #8
fast400's Avatar
Trader Rating: 1
There are still two pins in the pcm that can be used in the 2006 pcm instead of using the battery control module. If you want to use the module instead, I have a new one you could have for $20.
fast400 is offline   Reply With Quote
Old 10-09-2010, 11:04 AM   #9
1968 Chevrolet Camaro
Trader Rating: 0
So if you are putting a 4 prong plug above into a two wire, would the grey and brown both tie to the one alternator wire in slot B on the 4 prong?
68Problemchild is offline   Reply With Quote
Old 11-05-2011, 10:23 PM   #10
jsafe's Avatar
Trader Rating: 6
__________________
99z, pro build-a4, 9" f-word w/3.80's, longtubes, off road y, no cats egr air,ls6 intake, jantzer TB, k&n, magnaflow c-back, slp smooth-b & lid,Walbro 255 w/36lbs injectors, lc-1 wideband, dual stage harris speed nos w/MicroEDGE. efi live. MT DR's. umi TT&Sub, texas spd 233/239.prc 5.3 heads, Yank ss3600, 8pnt. PB 11.18@123mph
jsafe is offline   Reply With Quote
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
2006, 53, alternator, connector, engine, gbcm, harness, pcm, pin, pins, s10, truck, vortec, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
