I got a new direct from GM CTS-V pan for US$150 complete with pickup and it is an EXCELLENT fit when used with the Edelbrock adapter plates. There were 3 weird bosses sticking out of one side that I milled off, but you could probably just hacksaw them off if they were in the way...
What car did you install it on? Do you have stock linkage? Im going to be ordering The Edelbrock setup in about a week and just started looking into pan options.
guys sorry to wake a dead thread, but I have one more question - this would not even come up except that I called autokraft and champs and neither have the pan in stock- so I started looking.
here is my question -I am doing a turbo setup and it looks like with the autokraft Im gonna have to drill and weld send and return and pressure gauge fittings into the pan
with a remote oil filter setup, can I have the turbo oil supply and oil pressure fittings right at the remote oil filter setup? how does that work? as I think that would be the deciding factor for me.
or, if I order the autokraft, is it easy to tap the pan for oil supply, drain, etc for the turbo?
__________________ Numbers don't Lie. Yet, numbers don't tell the truth..
If running a turbo setup, you are gonna be low on room already, and finding a place to run oil lines and mount a filter is gonna be a pain. The Autokraft pan allows for the filter to be in the stock location. I think it uses a billet adapter that sandwiches between the pan rail and the filter, so you might be able to drill your turbo supply line there and then do something in the pan for a return.....drill a hole and weld a bung, or use a bulkhead fitting....whichever you are more comfortable with or whatever your sanctioning body will allow.
To more directly answer your other question...you CAN use a remote filter supply line and T off it to supply your turbo, but your turbo would need a place to go thats at 0 pressure, like your pan, NOT the filter return line. So what this really means, is you use the filter OUTLET line ( cuz its clean oil) to supply your turbo, and return it to the pan.
__________________ Sleepy at the wheel??...GO FASTER!!!
thanks man. I ordered the champ pan from carshopinc. tim over said I can tap the engine block above the oil filter area for a pressure supply for the turbo.
talked to autokraft... they should have their pans out of plate early next week, but there seems to be a small line of customers on the waiting list already.
71 - which pan did you order from carshopinc? i could only find this one, which is a tad spendy for not having an oil pickup and requiring a remote filter setup.
I always grab my oil feed for turbo stuff at the back of the block up top where the oil pressure sender is. Autometer adapter for metric to 1/8NPT, then a T-fitting, one side going to the sender for your gauge and out the top goes to the turbo.
