Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 09-10-2009, 08:01 AM   #41
hotrodscrap's Avatar
Trader Rating: 8
I'm gonna go with the BRP's and install kit. I'm not looking forward to it considering they are built by Hedman and have multi-piece flanges, primaries and bolt on connector. I dealt with that crap on my SBC/ S-10 swap PITA!
-SS
__________________
1925 Ford roadster p/u build in work/1985 Chevy S10 race truck, back halfed w/ 9", LSx swap in work, | 1993 S10 Daily driver | 1994 9C1 (Cloned) Impala SS, 6-speed, bolt on's | 1995 T/A vert. project | 2005 Cummins 3500, hauler
hotrodscrap is offline   Reply With Quote
Old 09-10-2009, 04:53 PM   #42
Trader Rating: 8
Sweet, just got of the phone with a salvage company. How's $1,500.00 for a complete 23,000 mi., LY6, w/ harness, pedal, and alternator? Do I need anything else with it? It's still in the truck/van. I believe it's an 08 Express 3500. Is the tac module attached to the pedal? Any help would be appreciated. I hope to have it picked up within a week. Got the old SBC and turbo 350 out last night.
-SS
__________________
Old 09-10-2009, 05:04 PM   #43
NemeSS's Avatar
Trader Rating: 70
Quote:
-SS
just grab everything that u can. bring the flexplate too.
__________________
LS1 SS
LoneStar1nnovationSS
NemeSS is offline   Reply With Quote
Old 09-10-2009, 05:48 PM   #44
Trader Rating: 8
I'd like to just take the whole damn van, so I know for sure, that's not gonna happen for that price though. What about hte TAC module, is it on the DBW pedal?
Flexplate - check
dbw pedal- check
Tac(hopefully)
I want to get everything I can so later if I want or need to go back to EFI I have all the stuff I need.
-SS
__________________
Old 09-11-2009, 09:14 PM   #45
Trader Rating: 8
Where is the TAC module located? I know I'm going carburated but want all elec. stuff needed to go EFI in the future? He says I can take what I need out of the truck for cheaper!
-SS
__________________
Old 09-14-2009, 12:42 PM   #46
Trader Rating: 8
Bump for location of TAC module to remove and purchase with motor.
-SS
__________________
Old 09-17-2009, 10:06 PM   #47
Trader Rating: 0
-SS
I've read that the ly6 has no tac module.
here:
LY6 Swap need help with Dbw pedal
Quote:
Originally Posted by LS1 Racing View Post
As I recall, there is no TAC module on the 08's. After 2007, the PCM handled all of the DBW functions. It seems that there should be a connector in the main harness that connects straight to the pedal. Are you sure that the TAC module is from the same vehicle?
Quote:
Originally Posted by alocker View Post
LS1 is correct, there is no tac module with an e38 ecm. It should be a flat 6 pin connector that plugs right into the pedal.
This should help with the pinouts. Scroll to post #7
http://www.ls2.com/forums/showthread...hreadid=405808
rongstad is offline   Reply With Quote
Old 09-17-2009, 11:04 PM   #48
Trader Rating: 0
the LY6 has no TAC module. All throttle related controls are handled by the e38 ecu. The e38 ecu does a good deal of consolidating it seems.
__________________
i own a 4th gen f-body
pillagenburn is offline   Reply With Quote
Old 09-18-2009, 05:50 PM   #49
Trader Rating: 8
Sweet man, I just wanted to get everything with it, just in case I wanted to run EFI later. Thanks!
-SS
__________________
Old 09-19-2009, 03:06 PM   #50
Trader Rating: 0
-SS
yeah man, get absolutely everything you can - you never know what you might need in the future (maybe not even for this swap) - that's what i did. I still have the LY6 oil pan, oil cooler lines, pickup and windage tray plus a bunch of other stuff left over. I've just been way too lazy to list all of it, so I need to get on it.
I'm working out odds and ends with my LY6 Firebird... hopefully in the next few weeks I'll have a dyno chart available. Crossing my fingers!
__________________
Old 09-19-2009, 03:27 PM   #51
Trader Rating: 8
Cool, I plan on grabing everything I can! Keep me posted on your LY6 swap progress. When I get everything I'll start a build thread or post here. Thanks man!
-SS
__________________
Old 09-29-2009, 12:54 PM   #52
Trader Rating: 0
My LY6 swap is done for all intents and purposes. I'm just working on getting my Tach and Speedometer working.
My mod list is as follows:
LY6 engine (stock)
Hooker LT headers
True Duals/Bullets with dumps at the axle
ram air intake
35mm Strano hollow front/22mm solid UMI rear swaybar
UMI 3-point subframe connectors
BMR shock tower brace
Energy poly a-arm bushings (PITA)
UMI adjustable torque arm
UMI adjustable rear-lower control arms
BMR adjustable panhard rod
M12 t56 from a 2004 GTO
LS1 driveshaft
Pro 5.0 shifter/short stick
Harwood ram air fiberglass hood
stock Pontiac Ram air intake box
L76 intake
Poly engine/trans mount
stock 90mm drive by wire throttle body
DBW gas pedal out of a 2005 Impala
here are the pics I have of it so far - I'll have a video of it running and a write-up before long.
http://photos-h.ak.fbcdn.net/hphotos..._1216105_n.jpg
http://photos-a.ak.fbcdn.net/hphotos..._6252752_n.jpg
All I can say is that the VVT was 100% worth it. I have never felt low-end like this and it pulls hard all the way into redline. Not even my F13 cammed 2001 SS Camaro that made 422rwhp peak felt like this car does. On 315 street tires there's no traction all the way through third gear.. This car would eat my old cammed SS alive in a straight line or cornering.
__________________
Old 09-29-2009, 05:21 PM   #53
Trader Rating: 8
Engine bay pic's please?
-SS
__________________
Old 09-30-2009, 12:32 PM   #54
Trader Rating: 0
of course! I'll have those up tonight. I'll try to get a good clear pic of the cam phaser area on the timing cover. Maybe even a video!
__________________
Old 09-30-2009, 10:13 PM   #55
Trader Rating: 0
ok, here's a video:
__________________
Old 09-30-2009, 10:16 PM   #56
Trader Rating: 0
thanks again to my brother, mr220v, for the wiring - he really knows his sh*t
__________________
Old 10-02-2009, 02:52 PM   #57
Trader Rating: 8
Well, I wish I could watch it here at work, youtube is banned!
-SS
__________________
Old 11-02-2009, 11:41 PM   #58
carrsls1_camaro's Avatar
Trader Rating: 3
http://en.wikipedia.org/wiki/GM_Vort...e#cite_note-18
Scroll down and find the LY6 in the chart it'll tell you exactly what to look for. Hope this helps.
carrsls1_camaro is offline   Reply With Quote
Old 11-03-2009, 12:33 PM   #59
Trader Rating: 8
I'll check it out when I get home, can't access it here from work. There aren't a lot of these hanging out in wrecking yards yet. I'm still determined though!
-SS
__________________
Tags
350, 400, 72, car, drag, engine, fuel, harness, impala, injection, ls, ly6, motor, purchase, return, ss, swap
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
