Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 09-11-2009, 12:12 PM   #1
Trader Rating: 0
Default Dakota Digital Dash on Carbed LQ4 G-body Cutlass
I want to put a digital dash in my cutlass with an lq4 swap and msd box i figured it'll be a lil bit different installing the digital dash...
i need some help fellas chime in thanks
G'D_UPLQ4 is offline   Reply With Quote
Old 09-11-2009, 01:18 PM   #2
ssduane's Avatar
Trader Rating: 3
I have one in my 66 nova, LS1 swap, works great, what are your questions?
All functions of mine work, shift indicator, engine light etc......
__________________
66 Chevy II, 2dr sedan TCI MII front clip,
Wilwood 12" aluminum disc, Currie 9",
Detroit tru-trac, 3.50, Caltracs
00 LS1/4L60e, Comp XR281HR/918 springs, LS6 intake, Fuddle 3200 TC, March underdrive dampner,
1 3/4 longtube headers, w/x-over
ssduane is offline   Reply With Quote
Old 09-11-2009, 01:37 PM   #3
Trader Rating: 0
would i hookit up the same way as if it were a factory motor in it and is there anything else needed besides the dash itself..
Old 09-11-2009, 02:09 PM   #4
ssduane's Avatar
Trader Rating: 3
Quote:
hook up is simple either way, trans speed single is a simple wire up, oil pressure comes from the engine only, water emp comes from a sensor that you can put in the other head, opposite of the PCM sensor. One signal from the PCM to the engine problem dash hookup. Dakota will send you a LS kit with the dash for sensors and adaptors etc.... Just tell them what engine your using and the kit comes with it.
Download the manual on their site, the thing is easy to hook up. They even offer a trans that you can hook up to your shifter to give the gear indication on the dash.
__________________
Tags
body, cutlass, dakota, dash, dashes, diego, digi, digital, digtal, gbody, ls1, put, san, tech
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
