Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-17-2009, 02:04 AM   #1
Trader Rating: 1
Send a message via MSN to busta9876 Send a message via Yahoo to busta9876
Default wiring harness ??? and o2 sensors
Working on a wiring harness, appears to be a 2002, as NO EGR, and RED/BLUE pcm, pcm says GMC Truck 4.8L. Vin shows it was USA built.
The Bank 1 Sensor 1 has flat 4 pin, which is the CASE GROUNDED sensor
The Bank 2 Sensor 1 has square 4 pin, which is ISOLATED GROUND sensors.
Both REAR o2's are the ISOLATED GROUND sensors with square plug. Anyone run into this before with one case and one isolated ground o2 sensor in same harness?
GM shows both schematics in service information, but not One of each mixed together.
__________________
1967 Chevy Pickup, 5.3L 4L60E
1989 Chevy Caprice, 5.3L TH400, soon to get a turbocharger
busta9876 is offline   Reply With Quote
Old 10-17-2009, 10:46 PM   #2
Trader Rating: 0
Weird, I thought all USA built trucks had the flat connector and the square was for Canada trucks. Has it been spliced?
__________________
More Gen III conversions brewing...
How'd I know this stuff? 'sperience, son.
'sperience (aka experience) - learning from your successes AND failures.
gofastwclass is offline   Reply With Quote
Old 10-18-2009, 01:15 AM   #3
Trader Rating: 1
no evidence of splicing. Since the harness is wired as a isolated ground o2 sensor circuit, I am going to remove the flat connector, and replace it with the white square one, that way can run same part# on both sides. The harness has all 4 o2 sensor TAN wires going to a splice pack, then 5 wires to the PCM Blue pin 25,26,28,29,63.
I would guess in the 2003+ PCM's the pin 25,26,28,29 get the Ground reference inside the PCM, and the pin 63 which is a GROUND REFERENCE is no longer required.
__________________
Tags
53l, bank, chevrolet, gm, gmc, ground, harness, location, o2, oxygen, pickup, sensor, tan, wire, wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
