LSX into Porsche 928 Completed
Old 09-22-2010, 10:48 AM
dhknox's Avatar
Default LSX into Porsche 928 Completed
I just finished up the final installation and have driven my 1985 Porsche 928 with a 2003 LM7 engine out of a Silverado. Had to re-do the accessory brackets and locations and install an intake from a Corvette - but other than those mods it bolted right in. Bought the kit from Renegade Hybrids. Used the factory PCM, with a slight modification to the program, and had to modify the wiring harness some.
Hoping to get to a dyno in the next 3 or 4 weeks to set a baseline and then start thinking about mods to drive toward my goal of 400 hp!
Attached Thumbnails LSX into Porsche 928 Completed-photo_070609_002-1-.jpg   LSX into Porsche 928 Completed-928-1.jpg   LSX into Porsche 928 Completed-000_0340.jpg   LSX into Porsche 928 Completed-000_3142-1-.jpg   LSX into Porsche 928 Completed-000_0295.jpg
Old 09-22-2010, 03:03 PM
KenV's Avatar
Allow me to be the first to both congratulate you and ask what the deal is with that dual-cable-bracket arrangement.
Old 09-22-2010, 04:58 PM
rwb
rwb's Avatar
Did you keep the stock trans?? Curious if it will hold up to your engine.
Old 09-22-2010, 06:11 PM
eviltwin_1987's Avatar
got any better pics? those show us pretty much nothing
Old 09-22-2010, 06:27 PM
99MUSTANG5.3L's Avatar
+1 on the pics! What's your recipe for 400hp?
Old 09-23-2010, 08:54 AM
dhknox's Avatar
Thanks! Dual cable bracket is the stock arrangement from Porsche. It is the throttle cable and the kickdown cable for the transmission. I kept the stock transmission. It is a Mercedes transaxle that is good up to around 500 hp. The biggest worry for me will be the torque convertor.
I will post more pictures soon.
Old 09-23-2010, 09:02 AM
KenV's Avatar
Neat that you made it all work as if it was factory.
Videos would be cool if you ever get the chance. There's a 928 in the parking garage at work running aftermarket mufflers and it's a head turner. Yours takes that to a whole new level.
Old 09-24-2010, 08:54 AM
garys 68's Avatar
What year is the 928?
I was looking at doing a 6.0 swap into a 928 as well. The one issue was the auto trans and TV cable with the DBW TB. Looks like you used the 928 TV linkage to actuate the 5.3 manual TB.
I've been looking for a 5 speed to avoid the issue.
Also, what rear end ratio are you running? The 83-88 models have a 2.2:1 which should work well with the 6.0s torque.
Are you running the 5.3 power steering pump?
And are you running AC, if so, which compressor and does it fit in the stock location?
Old 09-29-2010, 07:38 AM
dhknox's Avatar
Hi Gary. This is a 1985 928S. The 6.0 swap would work very well, this 5.3 came up at a very good price and I jumped on it. This motor came with the DBW throttle body which I removed and replaced the intake and throttle body from a 2000 Corvette. In our local Porsche Club this is the 3rd conversion and the first with an automatic transmission. Also the other 2 were converted to an LT1 motor. I like this conversion the best. Running stock rear end. I am running the stock 5.3 power steering pump and so far everything is working great. I do not have the AC hooked up at the moment, but, when I changed the truck accessory configuration over the the current configuration the AC compressor is now located at the passenger side lower mounting position like a camaro/firebird. The truck compressor will not mount in that location, so sometime over the winter I will be looking around for a new compressor and getting that set up. The Porsche system works well with the GM compressors.
Good luck with your conversion. I would recommend a 5 speed. They are out there since most folks aren't interested in a $10,000+ engine rebuild cost and sell them for low prices.
Old 09-29-2010, 09:11 AM
Nashty's Avatar
I really like that conversion as well. May I ask a couple of questions?
What does the 928 weigh?
I think I read somewhere that it's best to get ones (if they are available for the right price that is) that are newer than like 88-90 (??) Is there any particular reason?
Why did you pick the 928 over a 944?
What is an S4 vs. a standard 928?
Chassis wise, what should I look for in a good donor car? What are the trouble areas? they seem kinda complicated.
Old 09-29-2010, 09:59 AM
jonathan_ed3's Avatar
They're not too terribly light...I believe around 3200-3400 lbs.
The S4 is a later model (86 or 87)with more HP with a 5.0l motor (around 315hp if I remember correctly) and slightly more aggressive styling.
Cool project! looks factory!
Old 09-29-2010, 10:55 AM
jojomanx's Avatar
Great project! I will be starting on my 1980 928 in a month or so. LS1 is already bought but I will make my own adaptors since the kit is way over priced.
At 3200lbs this 928 should be a DEPENDABLE sleeper.
Please place more pics out here for us enthusiasts!
nolo200's Avatar
I like this!! I'm working on a BMW swap now.
Old 09-29-2010, 10:58 AM
garys 68's Avatar
Very nice looking, and great solution to the TV cable.
I have not decided if I'm going to do the 928 or 944. I do a lot of hiway driving so I'm looking at the 944 turbo with a 3.28 rear end (with early 5th gear) or a 5 speed 83-88 928 with the 2.2 rear. I'm guessing a 6.0 400hp motor will move the 928 pretty well. My 68 vette weighs about the same and my LQ9 can break the rear end loose in most gears.
A couple questions, which exhaust manifolds did you use? I've seen modified shortys for the 944 but nothing on the 928.
Do you know if the bell housing/torque tube adapter is the same for the 944 and 928?
It looks like RH uses an Autokraft pan with a notch. I was wondering if the LH8/Hummer H3 pan would fit, unmodified. It looks a little deeper but about 1 1/2" shorter.
Old 09-29-2010, 06:54 PM
dhknox's Avatar
Hi Gary.
I have a close friend who is just getting started on his 944 Turbo LS1 conversion. It is a 5-speed. I am looking forward to getting together once his is complete to see how the two cars compare.
I used stock 2000 Corvette exhaust manifolds, for now, just because of cost. I plan to have a set built to fit. I live in NASCAR country and there are several highly skilled header builders I plan to talk with. A friend had a set made for his Supra with a LS3 Lingenfelter motor and it screams. 450 at the rear wheels! The 944 Turbo is fitted with a set of modified shortys.
I will check out the bell housing and see if there are differences. Obviously the first difference I am aware of is that his car is a 5-speed and mine is an automatic.
Not sure about the oil pan. I can tell you it is a tight fit whatever it is. And you MUST run a oil filter relocation setup which is PITA!
BTW-I just installed a Scangauge II unit to monitor all the engine parameters which are very solid. 187 degree thermostat is working well with the stock 928 radiator.
Dan
Old 09-30-2010, 07:58 PM
rao
rao's Avatar
Looks great!
Quick Reply: LSX into Porsche 928 Completed
