02-15-2005, 12:18 AM
#21 TECH Apprentice
So between the 2 of these owners still no posts about any major complications or what modifications were needed to make it all work =)
__________________
LVCFO.org - Club Leadership. 97 Special Edition Firebird. Lets just leave it at that I guess.
02-15-2005, 04:59 PM
#23 Teching In
On mine the only thing was i had to use a front sump pan off of a 05 trailblazer.ever thing else was the wiring.
02-15-2005, 08:37 PM
#24 Teching In
Quote:
Originally Posted by teamspank
If you could give some details about the swap that would be great. Details about the mounts you used being the most important.
__________________ '99 Z28 M6
02-15-2005, 09:28 PM
#25 Teching In
mounts were custom made,used half of stock mount.looks like old style 350 mount one long bolt in the middle.
02-16-2005, 01:14 AM
#26 Teching In
Were you able to keep the factory crossmember or was it modified? How was exhaust manifold clearance, especially on the driver side?
02-16-2005, 01:03 PM
#27 TECH Addict
1998 Chevrolet Camaro
nice conversion. Is that front end carbon fiber? MY buddy and i are planning a rb26dett with a rb25det tranny ina 96 240sx. I told him he could drop my old ls1 motor in it but he wanted to go more towards the skyline motor. Which is fine.... its gonna be quick either way!!!
have you heard of anyone putting a set of s15 silvia taillights on a 96 240sx?
__________________
98' ZXXVIII a4 vert:
410ci / S85 / 4l80e / 12 bolt / Stock? maybe the door sills. ... 3 yrs. and counting!!
09' Corvette Z06:
STOCK!!!! 4500miles and counting!
06' Hummer H2 SUV:
Traded
05' CTS-V:
THANK GOD!!!
02-16-2005, 02:57 PM
#28 Launching!
http://www.streetracinggallery.com/g...erry%20407.JPG
You didn't mention the fact it was the later bodystyle car. That makes it even cooler. Good work.
__________________ 2006 Corvette Coupe M6 Z-51
2001 F-250 Powerstroke 7.3
1984 Mustang LX
02-16-2005, 10:14 PM
#29 Teching In
SMcCarthy-both cars picturedare s14's.
I am very interested in the swap, as a matter of fact I thought I was original when I thought this up on my own a few months ago (I guess kind of since I want to use an s13).
So far between the both of you the only trouble mentioned was finding an oil pan that fit. But was anything done to the crossmember other than new mounts? Also, how did you set up the clutch? Did you just mount up the pedal and master/slave cylinders from an f-body?
teamspank-did you use a corvette LS1 and converte to a cable throttle body or did you simply put the corvette covers on an f-body LS1?
02-17-2005, 10:42 AM
#30 Launching!
S14/S13= greek to me
I just figured he'd used the 89-94 body since they are more comminly available for dirt cheap. Like I say, the fact it's a 95-up makes it that much cooler.
1984 Mustang LX
02-17-2005, 08:33 PM
#31 Teching In
no its a 99 z28 motor automatic.the front cross member was dropped about 5 inches.exhaust stock,clears fine on both sides.
02-17-2005, 10:14 PM
#32 Teching In
5 inches!!! How much ground clearance does it have? That must hang pretty low.
02-18-2005, 08:47 AM
#33 Teching In
about 6in .but it a front sump pan.if it was rear sump it would be normal.
02-18-2005, 10:22 AM
#34 Teching In
do you have any pics of oilpan???
02-18-2005, 11:30 AM
#35 Teching In
no.the car is being tuned at hawks third gen camaros right now in south carolina.
02-18-2005, 01:37 PM
#36 Teching In
I'm just glad to see someone else do this swap, hopefully this will become a common swap.
02-18-2005, 07:51 PM
#37 Teching In
someone does a swap for the older 240s.the guy emailed me to see how mine was done.he wanted me to send my car to new york.where are you at?NC here
02-18-2005, 09:26 PM
#38 Teching In
Is there any way that you guys could post pics of the modified crossmember and mount setup in your cars?
02-19-2005, 09:10 AM
#39 Teching In
I Will When I Get It Back.
02-19-2005, 07:19 PM
#40 Ginger Hater
thats pretty sweet.....
Tags 240 , 240ss , 240sx , 240sxls1 , conversion , kit , ls1 , lsx , manual , needed , put , sale , swap , tech , weight
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
