Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 09-03-2007, 01:03 PM   #41
fouz65's Avatar
Trader Rating: 0
Quote:
Originally Posted by a13xf2oc
i'm using C4 IRS. you'd better be using more than a nissan rearend if you want that setup to last.
dont under estimate nissan rear ends.
fouz65 is offline   Reply With Quote
Old 09-03-2007, 01:44 PM   #42
Project GatTagO's Avatar
Trader Rating: 5
Send a message via AIM to Project GatTagO
Quote:
From what I understand the 230r has a 9" ring rear. I saw that rear swapped into an S2000 before. Not sure who makes the conversion.
Andrew
__________________
1970 GTO Version 2.0 in progress
V8TV Feature video
Popular Hotrodding feature
Car Craft feature
"You were the gun, your voice was the trigger, your bravery was the barrel, your eyes were the bullets."
Project GatTagO is offline   Reply With Quote
Old 09-03-2007, 02:40 PM   #43
Trader Rating: 0
Quote:
Originally Posted by jgonzales
Are you also building a LS1-swapped S2K too? If so, post some pictures of it and some more info for us in a new thread.
i've had one for awhile now. and i don't think he's done any mock fitting other than the engine itself. there's no way that shifter will line up if he in fact moved the engine 3.5in rearward. store bought headers will NOT fit on that car, and the nissan rearend is a ridiculous choice for an LS1, especially if he plans on running 315 rears.
right. did i hit a nerve?
would you put a nissan rearend on a GTO? didnt think so.
__________________
06 C6 Z06 - cam/headers/tune
00 S7000 - 427 LS1/7
06 Aprilia RSV-R Factory
a13xf2oc is offline   Reply With Quote
Old 09-03-2007, 02:54 PM   #44
wills55's Avatar
Trader Rating: 0
thats an awesome project, i dont see why the nissan rear wont work, you can build that rear to be pretty strong, i just get the feeling like S200+LS1=NO TRACTION. really cool project though, keep us posted with updates.
wills55 is offline   Reply With Quote
Old 09-03-2007, 02:59 PM   #45
Trader Rating: 5
A GTO is 3800 pounds. The S2000 is barely 3000, maybe less. I would never put a Nissan rear end in a GTO, but in an S2000 with limited traction I really don't see a problem. A cobra 8.8 would be better.
Andrew
__________________
V8TV Feature video
Car Craft feature
Old 09-03-2007, 03:54 PM   #46
getready's Avatar
Trader Rating: 0
Send a message via AIM to getready
Not trying to hijack... Just thought some other people should do this project, too.
Cruisin around ebay today, found this:
Its an s2000 shell that someone is selling, for like $500
Thought someone could be interested
getready is offline   Reply With Quote
Old 09-03-2007, 05:18 PM   #47
Trader Rating: 11
ahh another person that claims to have done the swap. and just registered today to boot!! well, welcome i guess... the trans IS in the car and im not using the weak t56, im using a tko600 that is much shorter and the shifter lines up a little short, even after bringing the engine back. i will show all my pictures and will be happy to be #2 in line after you if you provide some of your pics... and actually that nissan rear end has been known to support 9 sec passes reliably...
hboy7777 is offline   Reply With Quote
Old 09-03-2007, 05:28 PM   #48
Trader Rating: 11
hey hboy. what computer are you going to use?
what issues did you have with aligning the shifter? my car uses the T56 and we had to move the engine forward to get the shifter in the right spot. you moved your engine back 3.5 inches?
have you mock fitted any headers yet, or are you just going to throw parts at it? i ended up putting a front clip on the car, simply to accommodate the custom headers. at the time, there were no off-shelf headers that came even close to fitting.
what size radiator are you going to use? it doesn't look like you have much room left in there, with the stock radiator core support. are you removing the A/C? are you using the OEM multi-belt accessory setup?
and because this is ls1tech, what mods on the engine?
i'd recommend keeping the ABS. if anything, get a standalone ABS unit.
--computer will be stock gm unit reflashed with standalone harness
--headers will be made 1 3/4 to 1 7/8 stepped long tubes
--nissan r230 is going to be used untill i find something better
--custom radiator, and yes there is plenty of room since the engine is pushed back, it is behind the frame cross support-has not been moved, debating on keeping ac, plenty of room for it.
--no mods yet, getting everything in and when its done engine goes to machine shop, forged shortblock, intake,heads, cam. 450-500whp n/a then some nitrous
--abs is gone due to engine bay shave, for looks only, i want a very clean engine bay with only a very clean/polished engine. why should i keep it? it only lets you turn/keep control in slippery conditions-it wont be driven in any of those.
Old 09-03-2007, 07:23 PM   #49
GMmexican's Avatar
Trader Rating: 7
Send a message via AIM to GMmexican
Quote:
I woudlnt call the t-56 weak, there are a few guys running those here making up to 500rwhp....just with an upgraded clutch/flywheel.
But either way the stronger tko600 is a great upgrade
__________________
All men are free if they chose to be....the biggest fear of humanity is that nothingness will take away your freedom.
GMmexican is offline   Reply With Quote
Old 09-03-2007, 08:08 PM   #50
Gen3Benz's Avatar
Trader Rating: 4
I thought the r230 diff was pretty indestructible.
Do you have one laying around you can use?
Does the fab required look minimal?
Im sure you've looked at alot of differentials, does the r230 look easiest?
Like GatTagO said an aluminum 8.8 cobra diff would probably be the best choice.
'03+ explorers have an aluminum independent 8.8 with a different housing and rear cover.
a13xf2oc,
Nice to hear of your project. Any pics or a website?
Very interested to see the C4 rear setup.
LS2000 swaps are sweet.
Gen3Benz is offline   Reply With Quote
Old 09-03-2007, 08:20 PM   #51
NoRotor88's Avatar
Trader Rating: 5
Send a message via AIM to NoRotor88
Andrew
You and your crazy 8.8 rear swaps...
__________________
http://i29.photobucket.com/albums/c2.../RPMrotor2.jpg
-Jesse-
1988 Mazda RX-7
2000 LS1 T56
Cobra Rear
NoRotor88 is offline   Reply With Quote
Old 09-03-2007, 08:23 PM   #52
Moderator
Trader Rating: 0
Send a message via AIM to OKcruising
Cool swap, should be wicked badass.
on a side note: if you've ever driven a car extensively with no ABS, then understandable no ABS same with just for a show car. Anything else though and I just have to laugh.
__________________
2004 Z06 Victory Red---The evil one
Nukeproof driveline, PFC brakes, ARE drysump, Moton suspension, safety eqpt, slicks,etc you get the point.
2007 Z06 Artic White---The graceful one
2004 Avy 2500---The beast
2005 LS430---The daily appliance
1998 Supra--- The Green Monster.
OKcruising is offline   Reply With Quote
Old 09-03-2007, 08:30 PM   #53
Trader Rating: 0
Send a message via AIM to Kamin
you know nothing about how strong nissan rear ends are.
__________________
-Joe
1997 Nisssan 240sx - LS1.
2005 Nissan Titan - Tow bitch
Kamin is offline   Reply With Quote
Old 09-03-2007, 08:38 PM   #54
Trader Rating: 11
i meant in terms of a 700hp setup. i know that you can get them built to handle the increased hp but i got such a good deal on the tko i couldnt pass it up.
Old 09-03-2007, 11:06 PM   #55
Trader Rating: 0
R200 = 200 mm ring gear (25.4 mm/") = 7.87"
R230 = 230 mm ring gear (25.4 mm/") = 9.06"
Heavy85 is offline   Reply With Quote
Old 09-03-2007, 11:29 PM   #56
Trader Rating: 3
Should be very cool when completed. If you can get some corner weight scales many would be interested in the final tally.... especially front/rear bias.
A T56 with a few hundred dollars worth of parts can handle 700rwhp in a 3500lb F-body. Steel shift forks, carbon blockers, upgraded synchros. They are the basics of any rebuild.
With upgraded gears, Viper output shaft and a few other tricks they can handle 1400rwhp+. They have proven their strength by running them in 3400lb twin turbo 522ci Vipers running (2) T88 turbos into the 7's with IRS!
__________________
'87 RX-7 w/ Buick GN driveline 2725lbs 11.76@115mph stock GN turbo R.I.P. http://www.wrongmotor.com/gallery/mark_c/index.htm
'93 RX-7/LS1/T56 18x10.5" CCW's,1.13g's! 439rwhp/385rwtq 2800lbs 11.42@127.4mph n/a SOLD http://209.177.55.37/scc.htm
New Project: RX-7/FD/LS7/T56 575rwhp and 140mph n/a goal http://www.v8rx7forum.com/v8-rx-7-bu...-5-08-a-6.html
gnx7 is offline   Reply With Quote
Old 09-03-2007, 11:44 PM   #57
GMmexican's Avatar
Trader Rating: 7
I think most honda styling is boring but the s2000 has a very sleek european roadster look.....its only problem was it was 2 slow to compete with most euro's, i guess you solved that problem.
__________________
Old 09-04-2007, 12:19 AM   #58
fouz65's Avatar
Trader Rating: 0
no, i wouldnt put one in a GTO. who would. i have had my ls1 in my 240sx for almost a year with a j30 diff with no problems. if you look around at some of the stuff people are running with nissan rears you will see they are pretty tough. axles will break before the rear does.
Old 09-04-2007, 01:22 AM   #59
cnichols's Avatar
Trader Rating: 15
Send a message via AIM to cnichols
Like these guys have said, you will not need anything better than an R230. I would be amazed if you broke it.
Very cool swap...have always loved the S2Ks.
__________________
11.85@122.7 | Cam Only | Stock 98 Heads | M6 & N/A
-Chris
cnichols is offline   Reply With Quote
Old 09-04-2007, 12:08 PM   #60
owen v8litew8's Avatar
Trader Rating: 0
more pics!
!!!!!!!!!!!! less bickering!!!!!!!!!!!!!!!!!!
lol.
__________________
my cardomain '87 FC RX7 widebody 2750 lbs w/ LS1T56 swap <---SOLD project pics
Not sure when or what the next project will be... LS1 RX8? LS1 240sx? LS1 3series? LS1 Miata? LS1 S2000?
owen v8litew8 is offline   Reply With Quote
Tags
build, conversion, honda, kit, ls1, ls2, ls7, lsx, powered, s2000, s2k, spd, swap, thread, widebody
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
