Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-30-2009, 11:27 AM   #41
garretthes's Avatar
Trader Rating: 0
I'm still stuck with not knowing what to wire my stick too. Is it a wire from the tac module, the pcm? 2004 5.3 with factory harness/pcm
garretthes is offline   Reply With Quote
Old 10-30-2009, 04:39 PM   #42
DutchmanZ's Avatar
Trader Rating: 3
Quote:
Cruise switch wires to the TAC module. Send me your email and I'll send you the wiring diag.
__________________
Monteray Maroon Met, LQ4 6.0L, M6, Pacesetter LT & ORY, Hooker Aerochamber Exhaust, Ported TB, LS6 intake & injectors, 85mm MAF, SLP Lid, Speartech Tuned
DutchmanZ is offline   Reply With Quote
Old 10-31-2009, 07:11 PM   #43
Trader Rating: 0
Unhappy cruise
I have my lt1 cruise all wired (correctly) im pretty sure. It still doesent work.
Im not sure on the meaning of terminal G seeing a ground thru the chmsl bulb.
What does that mean> Connect G to the brake light '12v' or to the grounded side( which is always grounded)?? I dont get it.
lasstss is offline   Reply With Quote
Old 11-02-2009, 06:38 PM   #44
DutchmanZ's Avatar
Trader Rating: 3
It (term G) needs 12v when the brakes are applied. Just pull it of the brake light switch.
__________________
Tags
06, 25315091, 89, accel, cable, chmsl, control, cruise, gm, input, low, ls1, module, pulled, resume, wiring
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
