Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Conversions & Hybrids
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 06-18-2008, 06:15 PM   #101
Trader Rating: 0
Thanks for the info ls1 miata.
LSX-PWR is offline   Reply With Quote
Old 06-24-2008, 10:46 PM   #102
Trader Rating: 0
I should start working on my Miata by the end of July.
Old 06-25-2008, 12:46 AM   #103
NemeSS's Avatar
Trader Rating: 70
Quote:
miata
__________________
www.morrismotorsports.net
427CID shortblock 4500$
NemeSS is offline   Reply With Quote
Old 06-25-2008, 09:26 AM   #104
LS1-450's Avatar
Trader Rating: 14
[quote=ls1_miata;9582521]
Yes and no. My assumption was that the MAF table was off so I would basically be correcting it to account for the different flow vs. frequency curve my custom intake has. [quote]
Yah, you are correct. I am relatively new to PCM tuning, am learning as I go.
After asking in the EFI forum & hearing from a few guys here in the tuning section, learned that my MAF flow vs frequency was off by 26.5%.....WOW!
Re-scaling the MAF table ended all of my other related tuning issues & made a huge difference.
The car had been proffessionally tuned after the intake, head, cam. Having tuning software revealed that the tuner only tuned for WOT & had also not modified the MAF table. The non PE tune was way off & I'm sure that @ WOT she was leaner than commanded. Thank goodness for knock sensors. A dissapointment, but, also a learning experience. Having tuning software is a blessing. The modified tune is nearly complete & the car loves it.
PS: Not a knock against proffessional tuners; most are top notch.
__________________
LSX powered MUNSTER.....Mod's list? 5 lbs per HP with a sh!t load of low end torque...Friend to all car people...Thanks LS1Tech
LS1-450 is offline   Reply With Quote
Old 07-05-2008, 02:19 PM   #105
Trader Rating: 2
Here are a couple new pics with my race set of tires/wheels. They are 15x7 Motegi Traklite's with 35mm offset (weigh 10.5 lbs) with 225/45 Toyo RA-1's. Enjoy.
__________________
FOR SALE: 1991 Mazda Miata with 328whp/355wtq LS1/T56, Ford 8.8 3.55 diff, Ohlins coilovers, Hard Dog 6-point roll bar. Drivetrain mounted with racingconcepts.net kit.
Build-up website: www.swaptastic.net
Other car: 2009 Pontiac G8 GXP 6spd
ls1_miata is offline   Reply With Quote
Old 07-07-2008, 08:17 PM   #106
Trader Rating: 0
Good looking wheels.
Old 07-07-2008, 10:08 PM   #107
Trader Rating: 0
Looks good...I like the tag!
Just started my own LS1 swap into a 91 Miata!
984mulals1 is offline   Reply With Quote
Old 07-20-2008, 11:35 PM   #108
Trader Rating: 2
Got some more videos. Trying to get better (both quality and content) videos. More will come.
Me vs my friend's 300whp turbo 325i:
http://videos.streetfire.net/video/N...25i_172772.htm
Me wearing down my tires some more:
http://videos.streetfire.net/video/N...ing_172930.htm
Me trying to race a vette, vette didn't want to go:
http://videos.streetfire.net/video/N...ing_172923.htm
__________________
Old 07-21-2008, 12:31 PM   #109
travailrx7's Avatar
Trader Rating: 0
Have you been to the track yet!
travailrx7 is offline   Reply With Quote
Old 07-21-2008, 06:55 PM   #110
Trader Rating: 2
I fixed the video links
I have. Went to Talladega Grand Prix back in May. It was more of a lets go out and see what goes wrong so I can fix it rather than an all out race. Had a CV boot bust (wasn't vented properly) and diff case was found to be defective (junkyard part..) so replaced both of those and all good.
Also been to a couple autocrosses. Its fun.
__________________
Old 07-22-2008, 07:27 PM   #111
Trader Rating: 1
Here is mine from 1 month ago and some days! I just modded the car again looking for more power!!!!! Was 423rwhp and 434rwhp in the video on regular!!! But swapped cams and a few other changes. Here is my site too. www.ls1miata.net
http://videos.streetfire.net/video/9...ata_163123.htm
__________________
Ls6 383 powered miata, t56, 3.27:1 T-bird rear, 2650lbs, and alot of other goodies.
turbotacoma is offline   Reply With Quote
Old 07-22-2008, 07:28 PM   #112
Trader Rating: 1
Read the comments the Z is pretty fast and making some power! Now i am finding some!!!
__________________
Old 07-25-2008, 02:09 PM   #113
Trader Rating: 0
Who has the most powerful Miata out there right now?
Old 07-25-2008, 02:22 PM   #114
LS1-450's Avatar
Trader Rating: 14
Who knows........It's more about how much power & early torque one can drive on a short wheel base & limited rear tire width. If you like top end, I have seen a 650RWHP turbo Miata, but, it doesn't have the low end torque of an LSX. The highest low end torque & over 400WHP Miata that I have seen is turbotacoma. There is another known LS2 as well, but, am thinking that he won't set-up to make the power that turbotacoma has. I personally can't drive much more than low 400's HP & TQ. For this reason, my car will never get there. Although, I do think that I could handle a 650 HP/350 TQ turbo set-up. So, it's a matter of preference & driving skill.
__________________
Old 07-25-2008, 02:51 PM   #115
Trader Rating: 0
The reason I am asking is because I was thinking of putting a LS7 427 engine that I am building in to my 1991 Miata. I am also worried about the size of tire and the traction problems I'll be having with a power plant of this nature. By the way LS1-450 which long tube headers did you use to fit?
Old 07-25-2008, 03:45 PM   #116
LS1-450's Avatar
Trader Rating: 14
They're custom made from Diamondmotorsports. Diamond is now out of business. There is the comapny that ls1miata used, that makes a swap header, but, I don't think it's a long tube design. ls1miata will have to say for sure. The key to traction is gear ratio & tire size. If you tub the rear, you can get larger wheels in, but, then will need a 5 lug hub, in order to find wheels wide enough, which is another story. Although, I think there is now a company making a 15"x9", 4x100 wheel. Am thinking that this was discussed earlier in this thread as well.
Anyway, turbotocoma is better suited to help with traction related to your higher powered set-up. I am not really sure what will work. Your car will be bad ass for sure.
__________________
Old 07-25-2008, 08:23 PM   #117
Trader Rating: 0
LS1-450 do you have any pic's or videos of you're build?
Old 07-25-2008, 10:17 PM   #118
LS1-450's Avatar
Trader Rating: 14
A few here & there. No web site or anything like that. Really, the key areas are the front k-frame w/ steering location & the locating & proper supporting of the rear end. There's a lot more to it, but, these two are most important. Am happy to send you pics of areas in question (if I have them) & answer questions. As stated though, your building a Miata w/ power levels that I am not familiar with. In a Miata, the higher one gets above the 400/400 mark, the more challenging the build.
I was thinking about your build this afternoon. For sure, I would suggest 31 spline differential & carrier. Also, would consider an alloy &/or hardened half shafts. Just doesn't seem to me that a 28 spline is gonna hold up as well to your power.
__________________
Old 07-25-2008, 11:04 PM   #119
Trader Rating: 0
I'll post some picks of my top end you are going to freak out. Sheet metal intake with direct port injection, C5R heads flowing over 400cfm, Accufab 105mm tb.........
Old 07-26-2008, 10:30 AM   #120
scv8's Avatar
Trader Rating: 0
Haha, great tag!
__________________
944 LS2
scv8 is offline   Reply With Quote
Tags
ground, heavy, install, kit, ls1, ls1miata, mazda, member, miata, modified, seam, stiffening, swap, weight, welding
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
