11-06-2009, 11:34 PM
#181 Teching In
knock sensors cover my question is besides using an aftermarket valley plate cover like the one edelbrock sells how do you cover up the knock sensors or can u just leave the holes exposed? appreciate the help
11-07-2009, 08:39 AM
#182 TECH Addict
Well you can just leave the knock sensors in there unhooked up or you can get a custom cover made like a member on here did for me.
__________________
1994 Z28 - 13.52@110mph 2.1 60ft T56, bolt-ons, suspension
1978 Datsun 2+2 - 6.0L LS1 swap in progress
1968 Firebird, 2820 dry- 2000 LS1, D&D Viper T56, RAM clutch/flywheel, 236/236 .651/.651 110+4LSA cam, victor JR EFI, 4150 TB, 42lbers, painless harness, Moroso 7qt pan, sfc, trac bars, 3" x pipe side exits, Telstars-30"MT streets/skinnies, mini-tub, 8.5" posi, richmond 4.56s, Hooker lLTs, Denny N20 DS, Fast dual wideband, Shotgun street scoop.
http://www.myspace.com/shawnmacananny
11-19-2009, 06:53 PM
#183 Registered User
Hi Guys
I've got a 5.3 from a 04 truck, and I'm going to put it in a 86 C-10. And I'm planning to run a carb on it. What would be the best choose for the intake? I've been looking at the performer, of the victor, but all I've seen has the performer comes with the Edelbrock controler, and all I'm reading says this is not the best one. I have the engine, and a Edelbrock 1411 carb. I plan the run the 400 trans, and do some pulling with it. Any ideal about the best ext. manafolds to use?
11-20-2009, 09:35 AM
#184 TECH Addict
Dont get the Edelbrock controller, it cannot be tuned like the MSD. You can only use the timing pills.
If you are doing any pulling with it i would reccomend the performer intake, The victor jr will give you a dead spot until about 2500-3,000rpm.
__________________
11-20-2009, 09:51 PM
#185 Registered User
Thank's. Now is the 750 cfm's too much for it?
11-22-2009, 03:45 PM
#186 TECH Addict
It's not too much. That's what i ran. I would definitely run a vac secondary car though.
__________________
Yesterday, 03:07 AM
#187 TECH Apprentice
i run a valley tray by wegner that has a breather welded to it.
Tags 04 , 53 , box , carb , carburetor , combo , convert , cruise , edelbrock , intake , jr , ls1 , ls1tech , timing , victor
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
