Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > VEHICLE SPECIFIC FORUMS > Corvette Performance
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 03-22-2009, 11:52 PM   #41
2000 Chevrolet Corvette
allngn_c5's Avatar
Trader Rating: 3
^^^ You said it brother, now I am just waiting for my tires and rims that I left at LGM to be dropped off by UPS
I am going to swap the Run Flats that aren't as bad as everyone says, just need to get them up to temp before you try anything more then a gentle roll. Cold they suck.
First I'll throw my 295 35r18 Michelin PS2 on and test them out. Second I'll swap the Michelins for my Nitto Drags 305 35r18. I already know the DRs will hook the best, but I want to go have some fun and need the PS2's for what I want to do. Anyways the PS2's will be a nice step up from the run flats, and the DRs will be a step up from the PS2's, so I am just trying to learn how to drive the car again with more traction each time.
__________________
2000 FRC LS2 402 - 541 rwhp 505 rwtq Tuned by Vengeance Racing
TFS 215's (59cc) Custom Cam, 1 7/8 ARH, Ported FAST 92, UD Pully, EWP
RPS Street Twin Lite, and Pfadt Coil overs, Sways, bushings kit, RPM Stg III
For all your Performance needs:Vengeance Racing 678 513 7105
http://www.ls1tech.com/forums/dynamo...s-results.html
allngn_c5 is offline   Reply With Quote
Old 03-23-2009, 08:09 AM   #42
Sigforty's Avatar
Trader Rating: 0
Send a message via AIM to Sigforty
You think the drag radials will hook, lol!! I can say with the power and torque numbers you are going to have a rough time at the DRs hooking even at the track. Hell, on the street I can even spin my ET Streets all the way through first gear.
Sigforty is offline   Reply With Quote
Old 03-23-2009, 09:31 AM   #43
allngn_c5's Avatar
Trader Rating: 3
Quote:
Mark, I never said anything about hooking, I only mentioned that each tire provides a little better grip then the previous. Worst runflats, DRs Best and ps2's in the middle. I know the DRs won't hold if I come out of the hole with any kind of rpms, so I'll simply roll 1st gear and hope she holds 2nd and so on.
Back to my comments on the run flats, when they are cold you can't get shit from them. If you warm them up a bit by driving and/or spinning them to heat them they do act better. Not much, but better then when they are cold. I have found that 1/3 to 1/2 throttle is all you can use in first gear. 1/3 throttle and as you get some momentum gradually go to 1/2, anymore and all she does is spin. 2nd gear can handle 1/2 throttle or a bit more, 3rd gear will hold from 1/2 to 3/4 but WOT spins, and when you get 4th gear the heated runflats finally grab. Hope that clarifies things Mark. Hopefully the PS2's will perform marginally better then the runflats, and then for some real street fun the DRs should grab 2nd on up making her feel even quicker. JMO's
__________________
Old 03-23-2009, 10:50 AM   #44
scramblerman's Avatar
Trader Rating: 11
can't believe you even have runflats on your car, lol.
The Ps2's will be a bit better than the runcraps. Bring the pressure down a few pounds and try it out. The drag radials will be a helluva alot better, run about 26 psi in them. I have driven to denver and back on drag radials, not one problem other than the rough roads in colorado eating them up.
__________________
02 Z06 cammed
scramblerman is offline   Reply With Quote
Old 03-23-2009, 11:02 AM   #45
allngn_c5's Avatar
Trader Rating: 3
Sorry bro, but I was nervous about driving 1200 miles on DR's. Anthony at LGM was a bit concerned as well. I really don't like the mushy (soft) feeling of the DR's when going around curves. Besides my Run flats were shipped in the trailer with the car so it just seemed logical. If I lose air pressure with the RF's then I can baby it to a service center. I get a flat with the DR's and I am stuck. Now you see the logic. NO AAA either. Just out there winging it. I've made the trip several times and its easy but damn is it a long trip when riding solo.
__________________
Old 03-23-2009, 11:35 AM   #46
Trader Rating: 11
Yea it had to of been a long ass ride for you. I'm sure alot of it was tons of fun.
I have autox'ed my vette once before with the nitto drag radials and car felt planted to the ground. Even in the rocky mountains it was a blast. Was nice to have the ass end of the car stick to the ground than worry about it breaking loose.
I can understand worrying about getting a flat tho.
I'm sure it will be great to get a set of tires that hook so you can really feel the power of the new motor.
__________________
02 Z06 cammed
Old 03-23-2009, 11:37 AM   #47
Trader Rating: 11
can't wait to see the video's of the car doug!
How do you like the sound of the Big 3 catback?
__________________
02 Z06 cammed
Old 03-23-2009, 12:16 PM   #48
allngn_c5's Avatar
Trader Rating: 3
I like it just fine, it has a much smoother refined vs wild sound. I have to admit I miss the nascar sound of the bullets a little, but prefer having better flow. Also the big 3's sound doesn't wake my neighbors up like the bullets did, but then again I haven't come home late, or left early yet so we'll see.
To be perfectly clear though, the Big 3 is rather tame at idle, and does get wild at WOT. Kind of the best of both worlds. I think that's what LGM was trying to offer the customer.
__________________
Old 03-23-2009, 02:00 PM   #49
Trader Rating: 11
cool, that is what I like about the stock ti. At idle it is tame, even tho you can hear the lope. Cruising the car is really quiet till you lay in it. Then above 4500 rpms it gets loud.
__________________
02 Z06 cammed
Old 03-23-2009, 02:14 PM   #50
allngn_c5's Avatar
Trader Rating: 3
The big 3 is louder then the zo6 Ti system. I'd say around 2500-3000 rpms the DB's start coming up and continue to rise as the RPMS do.
__________________
Old 03-23-2009, 10:31 PM   #51
2004 Chevrolet Corvette
GMCHammer's Avatar
Trader Rating: 4
Good to see you made it home safe Doug. Sorry I could not make it out. I have been working non stop. Enjoy all that new found power and keep us updated!
__________________
2004 Z06 | LME 402
Tuned by Quality Motorsports
GMCHammer is offline   Reply With Quote
Old 03-23-2009, 11:35 PM   #52
allngn_c5's Avatar
Trader Rating: 3
Quote:
Thanks and no problem man. Your car is the one I wanted to line up against. Should've been a good run considering your gearing advantage, amd my extra torque.
Glad to hear you are working. I just put in 13 1/2 hours of OT the last 2 days on top of my regular shifts. Thank God I have a great job.
__________________
Old 03-24-2009, 03:50 PM   #53
L8terG8tererator
xfactor_pitbulls's Avatar
Trader Rating: 15
I don't know what Brandon's time slips look like, and Brandon did get out in front of me the first time. My tires were pretty warm after all the spinning, and after Sean put VHT on them there was a noticeable increase in grip.
Maybe Brandon can chime in. He rode with me and knows the car is fast, and we also "raced, for fun" twice. So I'll let him post his opinion on my car.
Doug's car pulls hard and its very linear. If he had anymore gear than the 3.42s there is no way it could have kept traction. I was running with the exhaust all the way out the back and cutout closed. No to mention granny shifting the gears due to lackluster hydraulics of late. Either way you look at it, he would probably start walking away from me at around 120 and not look back. Keep in mind my 416 is only 10.75:1 and meant to have the heads swapped, as we are going to soon for low compression. It makes around 515-520/490 with Dart heads milled down to 60cc. Not great for a big bore trying to move a bunch of air. Still undefeated in the ricer world of roll racing .
Brandon
__________________
1999 Z28 M6, C5R timing chain, K&N Filter, Spiffy Black Seats, 1OTL, BPU+++
2006 Duramax 3500 DRW Crew
Edge juice w/attitude, intake, magnaflow turbo back, trans go jr. shift kit
2007 Genuine Rattler 110, when you dont feel like shifting.
xfactor_pitbulls is offline   Reply With Quote
Old 03-24-2009, 03:53 PM   #54
allngn_c5's Avatar
Trader Rating: 3
Thanks for chiming in Brandon. Better tires would've helped too. Great pics you took and sent me. Appreciate it. Gotta hit the gym an get myself into shape for summer.
__________________
Old 03-24-2009, 08:22 PM   #55
GMCHammer's Avatar
Trader Rating: 4
Quote:
Brandon
Sounds like us ricers need to line em up!
__________________
2004 Z06 | LME 402
Old 03-24-2009, 09:18 PM   #56
Shorty Director
Trader Rating: 1
Good deal!!
__________________
2001 Chevy 3500 6.0L Crew Cab Dually
Basic Mods
1999 Chevy Corvette Fixed Roof Coupe
SW/BM 408ci w/AFR 225's 72cc
Patrick G 224/230 .609/.604 114LSA +2
TTi X kit with twin T3/T4's A/R .82
http://img.photobucket.com/albums/v2...car3-small.jpg
VINCE is online now   Reply With Quote
Old 03-24-2009, 10:01 PM   #57
V-seriesTech's Avatar
Trader Rating: 3
....lol... I couldn't believe that I was even able to hear you when I was talking to you on the phone while you were driving. That shit just isn't possible in my car without alot of "WHHHHATS...HUGHHHH'S....NO SPEAK UP,..I'M IN THE CAR".... etc. It seemed(your car with the new catbacl),..near stock/docile. Almost didn't think you were actually in a car. Thats pretty cool.
Glad you got your baby back man,... i know it's a great feeling. Gives you a chance to step away from reality once you hop behind the wheel. All our problems are still there while were driving these things but,...sure don't think a whole lot about them when were sporting 500 ft-lbs from all motor. The guys did a nice job, hats off to them all. Looking forward to some,...ah,.."testing" videos. Ya know, the kind you test against another vehicle?.... Yeah,.. looking forward to those homles.
Take it easy man.
__________________
The Fixed Roof Coupe
Coming to a runway near you
http://www.youtube.com/watch?v=kaWyNBMIsSE
Parts for sale
V-seriesTech is offline   Reply With Quote
Old 03-24-2009, 10:38 PM   #58
L8terG8tererator
Trader Rating: 15
Hollar shoot me a pm with your contact info.
__________________
Old 03-24-2009, 10:41 PM   #59
allngn_c5's Avatar
Trader Rating: 3
Brandon, you and Adam should be a good race.
__________________
Old 03-24-2009, 11:23 PM   #60
L8terG8tererator
Trader Rating: 15
Yeah, unless I get motivated and throw the dumped duals on it. About +15hp/10tq. Doubt I will though.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
