Yesterday was a good day for sure. I built my sister a footbrake car to race. Its your typical stock internal/bolt on type car. It started out as a bone stock 00' ss. By the end of the day I ended up getting a 11.039@120.00 out of it.
a huge thanks goes out to the following:
-Hank Hill's Hooked Up and Gone Race Car Technology
-The crew at Robbie Dowdy Race Cars
-Virginia Speed. Ed gave me a killer tune. Thanks a lot man!
Like I said this car started out bone stock when the build started. The first pass off the trailer yesterday it went 11.101 @ 119. Made some front and rear suspension changes and a slight shock change all the way around and at the end of the day we ran 2 11.039's in a row!
car weighs 3085 and those times are through a full x pipe exhaust I built. Had 3 1.45 60ft's in a row at the end. the best part is we learned a few things about the car and theres some more left in it! Im shooting to get it in the 80's, then do a nice heads and cam deal for it.
heres 2 pictures of the car. I've got some HD video of the car once i figure out how to put it on the computer.
wow,i knew that car would run,but that is incredible-good job Robbie
glad we could help out
__________________ www.virginiaspeed.comcustom engines for street or race,tuning,installs,fabrication. check our our online store-i'm adding new products every day http://shop.virginiaspeed.com/main.sc757-468-5101 1979 Z28 Outlaw 10.5-670bbc twin promod 94's Crew Chief,engine builder,tuner of Phil Thomas's
LSX powered Mustang"The Renegade" 7.29, 198mph-best 1/8 et.4.70 @ 164mph 315 radials at 3275lbs
That's pretty Cool Man !!! You should put a 100 shot to if you can get in
The mid 10's with stock Int.....
__________________ Money Shot Motors --- I got The Big Mac 3.8
Money Shot Motors CAI, Ported Upper&Lower Intake,
Zex Nitrous Kit, 2800 Stall ,BMR Goodies,13.23@108
Old Set up !!! Rear Mount TURBO Is comin Soon ....
haha Ed! After beating the dead horse about making it consistant you followed through!
Shawn thanks for letting me pick your brain through this build. You helped me out for sure. End of the year we need to have a talk about an all out heads and cam combo.
i am guessing -1000+...you east coast guys get all the great DA lol...nice times and build...what converter are u using
__________________ 02 z28 A4 Stock Internal with SS3600 11.558 at 116.24 MPH 1.546 60ft DA -832 11/25/07 Cam Only and SS4000 10.617 at 124.66MPH 1.356 DA -870ft Race weight 3250lbs
ram air info with ac http://www.ls1tech.com/forums/genera...r-install.html
without ac see post 5, pm me if you need one
__________________ Larry @ Speed Inc. 97 Z/28 396, LT1 H/I, LE H/R, FLT4 w/SS4000, S60, UMI, BMR, Nitrous Outlet 10.62@126 BEST NA (testing PT4000) 10.05@132 / 150 SHOT GM High Tech cover car April 2009 Follow us on Facebook for Project updates and Exclusive Specials http://www.facebook.com/home.php?ref...4984839?ref=nf www.speedinc.com
What RPM did you trap? I think it was at the top of 3rd @ 120 and 6000. I could probably lock the converter in third and get you some more MPH.
Ed that was right at what it was. According to the factory tach it was like 6100 ish. Im always down for some more MPH!
TA1364 heres a list of mods
bone stock 00' motor
LS6 intake
ported throttle body
QTP headers
I made the x pipe exhaust
asp underdrive pulley
I changed the whole fuel system but thats realy for later down the road
front:
afco front shocks
burkhart k-member and lca's
Travel limiters I built
rear:
bmr lca's
bmr panhard bar
wolfe torque arm
strange coil overs
anti roll bar i built
theres a ton of things I've done to it, but thats a basic break down of it.
Things I may change is go to an ATI balancer. Might also change the burkhart k-member/ control arms and go to a design I've got in my head but don't have the time right now to do as im already super busy with work right now. Its a more cost effective version of what I'm doing on my outlaw 10.5 car.
The biggest thing is not what parts you use, but how its setup and works together.
__________________ 02 35th Ann. LE SS A4 #1651
Best ET w/ TCI 3k stall [STOCK INTERNAL/Bolt-Ons]:11.82@114.16mph w/1.58 60ft +708 DA 3600lb RW
PSI Tuned: 316whp & 309tq unlocked
Best MPH: 115.5mph
<<Built trans, FTI 4k stall and Cam only: ET coming soon>>
<<380whp & 320tq unlocked "Cam Only">>
