Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > RACING DEPARTMENT > Drag Racing Results
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 04-21-2009, 08:39 PM   #61
IH8FORD's Avatar
Trader Rating: 1
Quote:
Originally Posted by N2RACINGLS1's View Post
Nice times Lemons!
Not really sure what all is going on here. For what it is worth let me sure share something with you all. When I had my stock 92K mile engine in the car with a weight of 3,665 lbs. It only had long tube headers and 3.70 gears with ET Streets it ran 1.54 60 foot 7.533 at 89.14 1/8 mile and 11.94 at 111.17 1/4 mile. The valve covers had never been taken off the engine and it even had an LS1 intake on it. You can see you ran faster then me at that time your car is making some power.
That same engine with the stock auto, converter and stock 10 bolt with 323 gears put down 329 HP and 350 TQ before I installed the TH400, stall converter and 9 inch rear which we all know only takes away HP and TQ so if my car can run a 7.53 1/8 ET and a 11.94 1/4 ET with lower HP and TQ numbers then I stated above yours will run better once you get traction.
Now change the torque arm and add the drag sway bar and put some ET Drags on the car and get the ET downs. I was running the above times with all stock parts on the front of the car minus the sway bar and stock sway bar on the back with air bag in right rear.
Good luck! You actually only need the right air bag!
N2
I think this is what JonCr96Z was trying to say. He is just more of a pennis about things.
__________________
1999 SS w/ L92 408 Best ET coming soon
1997 Z28 w/ 383 LT1 Best ET 7.04@98 1/8
2007 Silverado NNBS cam only 4.8 Best ET 13.74@97.64
IH8FORD is offline   Reply With Quote
Old 04-21-2009, 09:15 PM   #62
N2RACINGLS1's's Avatar
Trader Rating: 2
Quote:
Actually I am still not for sure what he is attempting to say.
Lemons had 94 MPH's on his runs so the car has some power. I was simply showing that if you put the power to the ground it can run a number.
That maybe the case for both cars not sure. If my car can turn a 7.53 1/8 mile ET with a stock engine with only headers and a lid through an LS1 intake at 3,665 lbs. I would think there should be no problem for 6.90's out of Lemons car once he puts the power to the ground. One thing is for sure if you spinning your are losing ET. If he installs a 26 inch ET Drag he will pick up a full tenth with just adding the slicks if not more.
I will add I never ran my ET Streets below 14.5 lbs. and I will never install them on my car again!!
N2
__________________
1998 Firebird Formula, 346CI
Best NA 1/4 mile, 60 ft. 1.394, ET 10.532, MPH 125.92
Best Nitrous 1/4 mile, 75 HP, 60 ft. 1.343, ET 10.254, MPH 129.51
Feature car in High Performance Pontiac Magazine February 2009, Hot 10-second LS Engine Shootout Combo!
http://www.youtube.com/watch?v=qSOhlXSh9Nk 10.53 NA Video
N2RACINGLS1's is offline   Reply With Quote
Old 04-21-2009, 09:34 PM   #63
2001 Pontiac Trans Am
My Garage
JonCR96Z's Avatar
Trader Rating: 11
No, that wasn't what I was trying to say. I really am not sure what that is saying.
I was saying that in January we was so sure that his car would be out of my league and as it turns out, it isn't/wasn't. It may be shortly but it wouldn't have been back then. Cold weather may have made more problems for him hooking and he could have been worse off.
__________________
JonCR96Z is offline   Reply With Quote
Old 04-21-2009, 09:51 PM   #64
Trader Rating: 2
I think I am pretty clear on what I am saying if you are not getting traction you are losing ET that is plan and simple.
As I stated if he wants to pick up ET the car needs to go down the track with the tires applying the power to the ground. I also stated you may have the same issue not sure since I no nothing about your car! What I gather is it must be slower then Lemons based on the post in this thread!
Not bashing anyone. I hope this helps clear up any misunderstandings.
N2
__________________
Old 04-21-2009, 10:16 PM   #65
1998 Pontiac Trans Am
lemons12's Avatar
Trader Rating: 17
Nice times Lemons!
N2
thanks man!
actually going thursday night to pick up a set of drag bags and installing them friday before i head to the track..
like you did, and like i have been saying.. if you look at the entire slip (not just the et) the car has a LOT more left in it...
im saving now for a TQ arm and a rear sway bar!
i dont think he has any point/direction in many of his posts..
N2
6.9s isnt a problem.. but like i have stated, huntsville is not known for its times... cars run slower than they "should"... 6.9s is screaming there.. and like i told jon he wouldnt be seeing his o so precious 7.4s there..
i am also going to a slick ASAP... wont be this track visit, but probably the next..
im saying that in January i would have still drug you down the track.. just like i would now... just like i would in 6 months..
N2
yes, his car his slower....... but i need nitrous to beat him... go figure..
again, thanks man.. and to everyone else contributing to the thread..
__________________
00 Pewter T/A A4 - Full Weight DD - 7.40@91.7mph NA 2400DA Enough to bitch slap Ls1killer!
00 Onyx Black T/A A4 (girlfriends car) - 8.4@85.5mph NA 2400DA Converter in! New times coming!
98 Artic White T/A A4 - DD - SOLD - 7.20@95.7mph NA 2000DA spinning/no tune
Past Rides- 02 954RR, 02 F4i, 98 Z28 M6, 99 3.8 V6 Firebird, 95 3.4 V6 Camaro
lemons12 is offline   Reply With Quote
Old 04-21-2009, 10:39 PM   #66
LS1Z28-00's Avatar
Trader Rating: 7
how did this shit fight start anyway? 1/8th mile is all about gearing, traction and stall. A less powerful car wont start getting drug until the end of the 1/8th. Lemons has a easy 100RWHP on him id say and the farther the race goes the more he will win by. Im sure i could get my LT1 to run in the 7s with enough gear,stall,slicks, weight reduction but it would fall on its face after the 330 mark but still do a reasonable time, its not rocket science.
__________________
03 MG Cobra-z06s taste like chicken- 190RWHP 220RWTQ
2000 z28-6.82@@100 1/8th 1.45 60ft-RIP
95 z28-Slow as balls 8.93@80
LS1Z28-00 is offline   Reply With Quote
Old 04-21-2009, 10:42 PM   #67
lemons12's Avatar
Trader Rating: 17
Quote:
i dont even remember dude.. some old thread.. he felt that i need to spray to beat his car.............
your exactly right... the farther we went, the fuglier it would get...
it would be uglier than he thinks also with me running that 7.2 the other night.. he thinks he would run his little 7.4 at huntsville.... he would be upset after a pass or two..
__________________
Old 04-21-2009, 10:49 PM   #68
My Garage
JonCR96Z's Avatar
Trader Rating: 11
Huntsville Dragway DA @ 4:40 (hottest time of the day) on 4/17/09. DA=1569'
http://www.dragtimes.com/da-density-...time=4:40%20PM
Piedmont Dragway @ 5:54 (around the time 7.444 pass) on 4/16/09. DA=1098'
http://www.dragtimes.com/da-density-...time=5:54%20PM
And again at 9:54 (last pass of the night, 7.441 pass). DA = 410'
http://www.dragtimes.com/da-density-...time=9:54%20PM
So I saw roughly a 600' drop in DA as the night went on and gained .003 off of it. Rule of thumb is usually one tenth per 1000' of DA. Maybe my first run was great and my last run wasn't, so it ended up being the same.
I think I could manage a 7.4 at Huntsville in decent weather, such as the weather you have last Friday.
I also enjoying hearing great advice, such as N2RACINGLS1s, saying to over tire the car because you're suspension doesn't work. Whatever you have to do, I guess.
__________________
Old 04-21-2009, 11:08 PM   #69
My Garage
JonCR96Z's Avatar
Trader Rating: 11
Yes, 4 MPH in the 1/8 = 100rwhp. Had I driven to race this kid, I would have had a set of ET streets on my borrowed DragLites. This would have given me a few advantages over my current setup of 17" DRs on my stock wheels. It would have guaranteed that I hooked dead, dropped about 15-20lbs per wheel and given me a little bit taller tire so I could run out 2nd in the 1/8 instead of changing to 3rd just before the traps (as I do now). At my track that would be worth at least a tenth (probably more). I also cut a pretty good light when I try, seeing as I go to the track about twice a month.
He has the faster/more powerful car, but I outrun cars like that all the time.
__________________
Old 04-22-2009, 01:14 AM   #70
2000 Chevrolet Camaro
Kingc8r's Avatar
Trader Rating: 17
damn I can feel the love in here
__________________
2000 Arctic White Z-28 A4: A little of this & that...
Any car can be an SS, but only a Camaro can be a Z/28
Kingc8r is offline   Reply With Quote
Old 04-22-2009, 08:47 PM   #71
lemons12's Avatar
Trader Rating: 17
[quote=JonCR96Z;11472124So I saw roughly a 600' drop in DA as the night went on and gained .003 off of it. Rule of thumb is usually one tenth per 1000' of DA. Maybe my first run was great and my last run wasn't, so it ended up being the same.
I also enjoying hearing great advice, such as N2RACINGLS1s, saying to over tire the car because you're suspension doesn't work. Whatever you have to do, I guess.[/QUOTE]
i would put big bucks on it you wouldnt touch a 7.4 at huntsville..
n2racings car runs very good.. no matter his advice.. i know what i need to do... and am doing it..
you do remember in the thread i said i would run you how my car sat, and how your car sat.... not changing tires/adding things/taking weight out... like i said in the thread, i know you wuold have ended up doing it.. exen though the outcome would still be the same..
yes i do... i dont know what i have been thinking... i have the FASTER, MORE POWERFUL car... you have the SLOWER, LESS POWERFUL car... i have ran FASTER TIMES you have ran SLOWER TIMES... why the fuck would i be able to beat you!? makes no sense.. i see the point you have been trying to make the whole time.. my bad man... congrats on being right about everything..
Quote:
to everyone but one..
__________________
Old 04-22-2009, 08:50 PM   #72
My Garage
JonCR96Z's Avatar
Trader Rating: 11
A fresh set of tires is hardly changing things up.
__________________
Old 04-22-2009, 08:56 PM   #73
tim99ws6's Avatar
Trader Rating: 22
Send a message via AIM to tim99ws6
Lots of puffed out chests in this thread...Should have known old lemon-drop was at the bottom of it! hahaha. See you tomorrow!!!
__________________
1999 Trans Am
Tatershack Performance
I need a motor sponsor that can handle 25psi
A3--Full Suspension--347--S480--6.0 manifolds--A2W
http://tnfbody.com/forum/showthread.php?t=9537
Special Thanks to: Tatershack Performance/AEIcnc.com/Speed Engineering
tim99ws6 is offline   Reply With Quote
Old 04-22-2009, 09:06 PM   #74
chrs1313's Avatar
Trader Rating: 8
Send a message via AIM to chrs1313
Quote:
haha this shit is funny...i wish you guys lived closer to me
__________________
02 z28 A4
Stock Internal with SS3600
11.558 at 116.24 MPH 1.546 60ft DA -832 11/25/07
Cam Only and SS4000
10.617 at 124.66MPH 1.356 DA -870ft Race weight 3250lbs
ram air info with ac http://www.ls1tech.com/forums/genera...r-install.html
without ac see post 5, pm me if you need one
chrs1313 is offline   Reply With Quote
Old 04-22-2009, 09:17 PM   #75
My Garage
JonCR96Z's Avatar
Trader Rating: 11
Quote:
You don't want none of that 7.2@94, you wouldn't run that at Huntsville.
__________________
Old 04-22-2009, 09:24 PM   #76
lemons12's Avatar
Trader Rating: 17
your right again! dont know what i was thinking.. it wouldnt have affected what your car ran at all..... right?
i learned from my uncles how to puff out my chest.... (chris/jason/bobby/chad)
i was just about to come on over and see if i had a message.. sounds good man... planning on being at sonic around 6:00ish..
no... chrs1313 would run about mid 13s@178,000mph... huntsville would kill his 60 foot.. but i think he would breath pretty good up top..
your so smart man.. im jealous..
__________________
Old 04-22-2009, 09:34 PM   #77
My Garage
JonCR96Z's Avatar
Trader Rating: 11
As it set was with a 295/50/15 street radial. I wouldn't run anyone on that, although those cheap radials have seen a 7.57 on my car.
By you own admission you have a 10 second car. Chrs1313 is barley in the 10s. You should be able to slaughter that. He runs a 6.8 in the 1/8 in good DA. You should have that easily with a 6.9 at your track, right? I mean there has to be some reason why your car runs so shitty for what it is.
__________________
Old 04-22-2009, 09:35 PM   #78
chrs1313's Avatar
Trader Rating: 8
60ft.........1.3861
1/8 E.T.....6.8061
1/8 MPH....98.05
__________________
02 z28 A4
Cam Only and SS4000
Old 04-22-2009, 09:36 PM   #79
My Garage
JonCR96Z's Avatar
Trader Rating: 11
60ft.........1.3861
1/8 E.T.....6.8061
1/8 MPH....98.05
Not at Huntsville.
__________________
Old 04-22-2009, 09:37 PM   #80
lemons12's Avatar
Trader Rating: 17
i posted what i think he would run t hunstville.. and thats spot on i bet..
__________________
Tags
18, 22s410s, 4k, 74, a4, car, engine, faster, gears, ls1, mile, ms4, tech, time, times, tune, up, weight
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
