Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > RACING DEPARTMENT > Drag Racing Results
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-23-2009, 01:07 PM   #21
Magnet's Avatar
Trader Rating: 33
Quote:
Originally Posted by lemons12 View Post
It pisses me off so bad I didn't get to see it run (one of the main reasons I went) and sucks also that I didn't get to check the setup a little bit longer.
For anyone curious this does not look as hacked up / gutted as a lot of cars I see at a much heavier race weight.
Congrats TSP!
I didn't get to see it run either
__________________
Black 2002 SS A4 345hp CME
1/4: 11.699 @ 115.38 w/ 1.59 60' STOCK INTERNAL
2001 MMM Z28 M6 12.18 @ 116.8 w/ 1.87 60' STOCK INTERNAL
Magnet is offline   Reply With Quote
Old 10-25-2009, 07:43 PM   #22
2002 Chevrolet Camaro
tripblackls1's Avatar
Trader Rating: 4
i would like to know more about this ms5 camshaft and when it will be available
__________________
ls1 awaiting new parts and umi suspenion moser 9inch 3300#s t56 4 speed
Quote:
Originally Posted by fast01z28 View Post
catfish: they move fast but dont taste too good because they eat poop (ie mustangs). lol
tripblackls1 is offline   Reply With Quote
Old 10-25-2009, 07:55 PM   #23
MATTREDSS's Avatar
Trader Rating: 2
Wow congrats!
__________________
02 35th Ann. LE SS A4 #1651
Best ET w/ TCI 3k stall [STOCK INTERNAL/Bolt-Ons]:11.82@114.16mph w/1.58 60ft +708 DA 3600lb RW
PSI Tuned: 316whp & 309tq unlocked
Best MPH: 115.5mph
<<Built trans, FTI 4k stall and Cam only: ET coming soon>>
<<380whp & 320tq unlocked "Cam Only">>
MATTREDSS is offline   Reply With Quote
Old 10-26-2009, 06:28 AM   #24
Giving PSJ a reacharound
The Juggernaut's Avatar
Trader Rating: 6
Quote:
Originally Posted by Jon@Texas-Speed View Post
We do run race gas in the car. It isn't a pump gas motor.
So it's a stock bottom end that isn't a pump gas motor?
__________________
*SOLD*
2001 Z28 Camaro
Heads and Cam (N/A)(stock short block) 9.900@134.27(1.261) DA +500
Cam only (N/A)(stock long block) 10.295@128.48.(1.38)
Cam only/150 shot(stock long block) 9.643@138.39 (1.364) DA +1178
Finishline Performance
Behind Bars Race Cars
http://www.juggerland.com/jugger.gif
The Juggernaut is offline   Reply With Quote
Old 10-26-2009, 08:12 AM   #25
1999 Chevrolet Camaro
Trader Rating: 21
Quote:
Yes tho the fact it probably has a good rod bolt in it and notched pistons will get some around here burnt up over the "stock bottom end" claim. Personally I could care less 346 inches GM piston,rod,crank 9.66 enough said.
__________________
, Factory LS2 (364) crank, rods, pistons, N/A , A.S. 5.3 heads, LG G5X4 camshaft, FAST 90/90, Performabuilt level 3 4L60E, ARH 1 7/8's, Circle D 230mm converter, full lineup of Spohn hardware out back -- P.B.= 9.87@134.8 - 60'= 1.30 10/19/09
Speed Density Tuned by Kaltech tuning on Long Island
www.kaltechtuning.com
Did this with a GM head and pump gas!
JFM-jr is offline   Reply With Quote
Old 10-26-2009, 09:44 AM   #26
gator's 99TA's Avatar
Trader Rating: 2
Send a message via AIM to gator's 99TA
why would notched pistons have anything negative towards a stock bottom end? and who has said there are aftermarket rod bolts. there maybe, buti havent seen it posted.
as for pump gas vs race gas - again, who cares. if you mill down a set of 5.3L heads and a thin gasket, you could definately run into issues with higher compression.
__________________
- John
1999 Pontiac TA - 404" LQ9|N2O|TH400|Radials|3600 lbs|Pump gas street car
2003 GMC Yukon 4wd - Baby Car Seat
gator's 99TA is offline   Reply With Quote
Old 10-26-2009, 01:36 PM   #27
Magnet's Avatar
Trader Rating: 33
I'm pretty sure when I talked to him at the shootout he said it had aftermarket rod bolts...I could be wrong but Im pretty sure. I couldn't care less though, rod bolts don't make it not "stock bottom end"
__________________
Old 10-26-2009, 02:47 PM   #28
Trader Rating: 21
Quote:
OoOoh wait until the stock bottom end police pay this thread a visit. There are members here that adhere to the strict letters of the law I obviously could give a shit about flycuts and rodbolts as well but I am biased because I have done those to both my LS series motors. It was for this reason my signature has things spelled out a bit more.
__________________
Old 10-27-2009, 09:06 AM   #29
chrs1313's Avatar
Trader Rating: 8
Send a message via AIM to chrs1313
what compression are you guys around...very nice results
now throw a 200 shot on it
__________________
02 z28 A4
Stock Internal with SS3600
11.558 at 116.24 MPH 1.546 60ft DA -832 11/25/07
Cam Only and SS4000
10.617 at 124.66MPH 1.356 DA -870ft Race weight 3250lbs
ram air info with ac http://www.ls1tech.com/forums/genera...r-install.html
without ac see post 5, pm me if you need one
chrs1313 is offline   Reply With Quote
Old 10-27-2009, 02:21 PM   #30
robsquikz28's Avatar
Trader Rating: 76
congrats guys that car is moving out..
robsquikz28 is offline   Reply With Quote
Old 10-27-2009, 02:54 PM   #31
ONEBADWS6's Avatar
Trader Rating: 17
Quote:
Originally Posted by ONEBADWS6 View Post
what kind of power does it make to the tire?
What this guy said!!!
__________________
402 LS2, 12.5-1 compression, hyd cam, ported LS6 heads and Vic jr intake. 9.82@137, best 60ft 1.29. N/A.
ONEBADWS6 is offline   Reply With Quote
Old 10-27-2009, 05:46 PM   #32
Trader Rating: 21
Quote:
Wrap a big blanket around the motor and tie it tight!
As for RWHP that car should be in the 520 range with those DA's.
__________________
Old 10-28-2009, 01:16 PM   #33
tektrans's Avatar
Trader Rating: 6
Quote:
Police will be here soon, that's for sure!
Predator will be tuning in from Dubai with a bunch of crap to say that nobody cares about.
That's an unbelievable ET, VERY nice job!! You guys have that combo well tuned in and it's cood to see a H/C car going mid 9's!!
__________________
'98 Trans Am WS6 Cartek N/A (L92/LS7) Hydraulic roller 441 ci.
9.59 @ 138 1.30 60' - Best 60' 1.29
video of 9.6x passes http://uk.youtube.com/watch?v=KVdBZk5Y3s4
**check out my TA in the Aug '09 issue of GMHTP magazine**
http://www.gmhightechperformance.com...ws6/index.html
tektrans is offline   Reply With Quote
Old 10-30-2009, 12:06 AM   #34
promod1955's Avatar
Trader Rating: 19
wow. big congrats and awesome job! Is it a solid roller cam?
__________________
-Robbie Dowdy www.fquick.com/Promod1955
-Twin Turbo Outlaw 10.5 02' Camaro
-4.90 index Trans Am
-Stock Internal 00' SS Camaro 11.03@124. "SI" MPH record
promod1955 is offline   Reply With Quote
Old 10-30-2009, 12:36 AM   #35
2001 Chevrolet Camaro
MelScrilla's Avatar
Trader Rating: 2
I want more info on those PRC 227 small bore heads as they're not on the website yet. Alot of 383 guys probably would like to get those. And that MS-5 should be interesting too, I doubt it will be a solid roller though because a fast intake probably wouldnt feed it.
__________________
01 Z28- Magnaflow catback, A4, 4:10's, SLP Lid, more power coming soon......
94 Integra - daily driver
MelScrilla is offline   Reply With Quote
Old 10-30-2009, 04:08 PM   #36
383lt1impala's Avatar
Trader Rating: 27
Send a message via AIM to 383lt1impala Send a message via Yahoo to 383lt1impala
ms5 cam? i like the sound of that.
__________________
1995 PIMPALA SS #419
MY BUILT LS1/TH400 SWAP THREAD!
383lt1impala is offline   Reply With Quote
Old 10-30-2009, 11:24 PM   #37
Trader Rating: 0
CONGRATS TEXAS SPEED....WOULD LIKE TO SEE THE CAR IN GMHIGHTECH MAGAZINE WITH THE FULL LIST OF MODS MADE TO THE CAR....THAT CAR IS MOVING
__________________
02 z/28, ms4 cam, rosslers th400,
ls6, 3600 stall, tuned
by Rick @ synergy motorsports
wichoms4 is offline   Reply With Quote
Old 10-30-2009, 11:43 PM   #38
Paint_It_Black's Avatar
Trader Rating: 0
Send a message via AIM to Paint_It_Black Send a message via MSN to Paint_It_Black
Jugg, why didn't you get the compression up to 14-15:1 and run some race gas too?
__________________
"If a Pro Stock engine builder bought heads the way most people do on the internet they would never qualify, I guarantee it." - Joe Mendelis
Paint_It_Black is offline   Reply With Quote
Old 10-31-2009, 12:05 AM   #39
chrs1313's Avatar
Trader Rating: 8
Quote:
with stock pistions that is some serious milling...
__________________
02 z28 A4
Cam Only and SS4000
Old 10-31-2009, 12:21 AM   #40
LSxGuy widda 9sec Mustang
-Joseph-'s Avatar
Trader Rating: 9
How would you get a stock 346ci shortblock to 14-15:1 compression with a .040" head gasket and ~52cc combustion chamber and "who knows" what size flycut valve reliefs? (2-3cc?) It comes out to ~12.5:1 everytime I figure it.
Fuel comparisons make way less of a difference than running in really good mineshaft air. I would rather have pump gas and -1800 ft DA, than "race gas" and -250 ft DA.
__________________
Joseph - 1967 Camaro LS1/TH400/Twin Turbo - In Progress
Editorial Staff - PlanetLSX.com
Fbook LSX Retrofit Group
How-To Build and Modify GM LS-Series Engines
Publications under the knife: "1993-2002 Camaro and Firebird Performance Hand Book" and "LSx Swap Manual"
-Joseph- is offline   Reply With Quote
Tags
10, 966, bottom, cam, camshaft, end, heads, ls1, lt1, ms5, record, sec, speed, stock, texas
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
