Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
Go Back   LS1TECH > RACING DEPARTMENT > Drag Racing Results
Sign in using an external account
Register Forgot Password?
Drag Racing Results Track Times | Records | Testing Info
Timeslip Database CLICK HERE
Thread Tools Search this Thread
Old 11-07-2009, 07:44 PM   #1
Garage is empty, add now
Trader Rating: 8
Default 9's at 140+ through stock LS1 TB/2.73 rear 10bolt :)
EDIT: Got into the 9's this weekend. See last posts
I thought i'd share this here since i'm running some 4th gen parts on my 3rd gen. Shows you can go pretty quick on stock stuff.
Ran my twin turbo 401 small block 89 Iroc-Z today on 12, 13, and 14 psi boost.
Motor uses a victor EFI manifold with intakeelbows.com 90 degree elbow and stock LS1 throttle body. Nothing else really special, strong bottom end, Dart SHP block, AFR 195 heads, Mike Jones custom cam, etc
Rear end is a bone stock 10 bolt from some 99+ car with zexel torsen diff 2.73 gears. No girdle or anything. Previous 10 bolt finally broke a spider/worm gear tooth and it was making some noise and slipping on gears, chewing up other teeth alittle so I dumped it. Needed a quick spare for racing today so i put in the other 10 bolt late last night.
Car should go 9's with abit more tuning and harder launch. 93 octane gas no meth, etc.
__________________
1999 Trans Am
Daily Driver--Pacesetter LT/SLP LM2/LS6 intake/Lid/3200 stall
1989 Iroc-Z L98
401" Dart block, AFR 195cc, Jones 233/233 112lsa
Twin 60mm turbos, Victor EFI single plane
TH400, PTC converter, 10 bolt 2.73 gear
9.86 at 141 1.56 60' 14psi street tune pump gas
Orr89rocz is offline   Reply With Quote
Old 11-08-2009, 08:41 AM   #2
STOCK12SECZ's Avatar
Trader Rating: 22
Good Job man. It's trucking on the big end. 9's will be no problem .
__________________
2001 NBM SS
2000 RED SS
2006 TBSS
91 Z28 Procharged 383SBC
http://community.webshots.com/user/11secz
STOCK12SECZ is offline   Reply With Quote
Old 11-08-2009, 11:45 PM   #3
SPEED#1's Avatar
Trader Rating: 14
Damn boy that car flies on the top end. What rpm do you leave at off the line? WHATS UP WITH THE BURNOUTS OUT THE GATE TOO....MAN THAT THING DONT HOOK LOL
__________________
Stock LT1 Cam only AI 226/234 3600 stall, 3.73 gear, full bolt ons, full suspension, almost full weight minus bumper supports, No a/c. 17s on a nitto
SPEED#1 is offline   Reply With Quote
Old 11-09-2009, 06:39 AM   #4
Trader Rating: 8
I brake torque it up to about 2400-2500 then floor it. Think it flashes to near 4000. It hooks just fine, spun just once for a split second
__________________
1999 Trans Am
1989 Iroc-Z L98
Old 11-09-2009, 05:44 PM   #5
2007 Chevrolet Tahoe
My Garage
SuperSlow02's Avatar
Trader Rating: 12
why were you beating up on those poor mustangs
awsome times man
__________________
2002 Camaro SS-Cammed 7.2@94mph sometimes faster
SuperSlow02 is offline   Reply With Quote
Old 11-09-2009, 07:39 PM   #6
Trader Rating: 8
my track was flooded with stangs and usually is... some 4th gen fbods but mostly stangs. They wanted to play To bad i didnt get to line up with some of the other ones there, one was doing high 10's and another looked very fast but didnt see him run. That cobra was no slouch tho, 11.0's at 128
__________________
1999 Trans Am
1989 Iroc-Z L98
Old 11-09-2009, 07:42 PM   #7
silverz28camaro's Avatar
Trader Rating: 20
wow congrates, yeah those 2.73 gears are what makes the 10 bolt strongish. big pinion gear!! get that 60 down and 9's no problem.
__________________
Brad, 1988 LS1/4L60E Dodge Ram
LS1 Dodge Ram Project! http://www.ls1tech.com/forums/conver...l#post13219630
silverz28camaro is offline   Reply With Quote
Old 11-09-2009, 09:12 PM   #8
1998 Chevrolet Camaro
Trader Rating: 9
Send a message via AIM to 98blueSScamaro
Sick ride for sure
__________________
06 TBSS AWD 14.34 & 98 Camaro SS M6 Navy Blue LS6 Cam Only 10.88 @ 126.81 with a 1.48 60 455RWHP & 402RWTQSpeed INC Tuned
98blueSScamaro is offline   Reply With Quote
Old 11-10-2009, 07:19 AM   #9
T/ALT1's Avatar
Trader Rating: 1
Nice times, looks like a 12 second car maybe but flies when the boost comes on. You need some slicks on that bad baoy and 9's would be easy.
__________________
1995 T/A 383" 12.1, Lloyd Elliott Heads/Cam,Tbraked TH350, 4000 Vigilante n20 converter, 12bolt 4.10's,Madman suspension 3,450lbs. NX dual stage.
10.82@127mph all motor spinning.
9.83@136mph old 355" n2o times
GMHTP Budget 9second T/A
T/ALT1 is offline   Reply With Quote
Old 11-10-2009, 12:06 PM   #10
Trader Rating: 8
I have ET streets on it and it hooks fine, just doesnt leave hard enough... need to get into boost on the launch
__________________
1999 Trans Am
1989 Iroc-Z L98
Old 11-10-2009, 02:04 PM   #11
RapidRick's Avatar
Trader Rating: 9
Thumbs up "Holy Smokes!"
You sure weren't kidding around on the other thread (Torsen Rear).
That's 1BADTURBO, in a mild mannered sort of way!
Congrats!
9's ?...
won't take but another trip out to the strip.... :
__________________
'01 FORMULA,Low Miles,SuncoastExtractor Hood/Airbox,StageII Heads,Lunati Rev.Split 112+4Cam,BBK80mm,ThundJetMAF,Jet Chip,QTP Ceramic LT's,FlowTech RaceReadies,CORSA 3"exhst,TCI3200 Stall,3.73&Girdle,BMR,Hotchkis,KBconnects,
SLPlineloc,MASPORT TUNE,In the11's
.-'98T/A,WS9,NBM,SOLD-'71 BUICK GS455,SOLD-'95 VETTE-6Spd.
RapidRick is offline   Reply With Quote
Old 11-15-2009, 09:39 AM   #12
LS1Tech Sponsor
LS1 SPEED's Avatar
Trader Rating: 22
very cool! congrats
__________________
Larry @ Speed Inc.
FOR SALE
97 Z/28 396, SI LT1 H/I, LE HR, FLT 7 w/SS3600, S60, UMI, Nitrous Outlet
10.62@126 NA 1.40 60ft
9.67@138.9 200 shot 1.31 60ft best MPH 140.5
GM High Tech cover car April 2009 + LTx Shootouts
facebook.com/SpeedIncUSA
www.speedinc.com
LS1 SPEED is offline   Reply With Quote
Old 11-15-2009, 02:30 PM   #13
kinglt-1's Avatar
Trader Rating: 15
Very nice times! There is nothing wrong with leaving the line a little soft, especially when you drove the car to the track. 10.0 is an awsome feat on the stock 10 bolt imo... sick setup you have there, congrats!!
__________________
2002 Z28, 1SC/1SZ, A4, 15k original miles.
kinglt-1 is offline   Reply With Quote
Old 11-15-2009, 02:51 PM   #14
02sleeperz28's Avatar
Trader Rating: 11
Congrats nice setup indeed!
__________________
Daily driven, grocery-getting 10-second club member.
02sleeperz28 is offline   Reply With Quote
Old 11-15-2009, 03:07 PM   #15
DRAG RACING IS LIFE! Mod
Villain281H's Avatar
Trader Rating: 5
Location: Gainesville, Florida # of drag strips runs: ?!?!?
Send a message via AIM to Villain281H
nicely done!!
Derek
__________________
1970 Nova SS Clone: 383 SBC on 93 swill, 3600 lb street/strip ride, never fast enough...
2000 Formula: MACS, ORY, Magnaflow, !EGR, !AIR, Formato tune, stock long block, trans and rear end, still slow
2004 GMC Sierra 1500 ECSB 5.3: Magnaflow CB, K&N CAI, Formato tune, baby and car hauler
Check out pictures and info: www.fquick.com/Villain281H
Videos here: www.youtube.com/user/Villain281H
Villain281H is offline   Reply With Quote
Old 11-16-2009, 05:28 PM   #16
Trader Rating: 8
Just went 9.97, 9.93, 9.86 all at 139-141 at my home town track saturday. PRP
Then went to MIR sunday and went 9.86, and 9.73 at 142 mph. Last run i mixed in some race gas, cranked the boost up to what I was hoping to see 17-18psi and went 1.49 60 foot but blew a vacuum line off the intake on 1-2 shift and power dropped out. Says i hit 16.6psi on the log but car didnt run like it i guess. Still ran 9.73 but it wasnt liking the street tune with the 110/93 octane mix. Car was richer and just didnt feel as strong as I expected it would be but that leak must have caused that. Would have been a 9.5 pass i think at near 145 mph I bet
__________________
1999 Trans Am
1989 Iroc-Z L98
Old 11-16-2009, 06:19 PM   #17
TTA1437's Avatar
Trader Rating: 6
AWESOME CAR MAN!!!
Lets see some engine pics!
Compression on the engine?
Love to see the 3rd gens sneek up on people.
__________________
1989 TTA
10.67 @130 19lbs of boost
Lonnies double pumper kit going in soon for low 10s high 9s
2000 TA - 351rwhp with bolt ons & heavy TT2s. Extreme Automatics 4L60E with PTC 3600 stall.
TTA1437 is offline   Reply With Quote
Old 11-16-2009, 06:31 PM   #18
Trader Rating: 8
It looks better in person, i need to get better pics. Here's when it was just about 99% done
Just 9 to 1 compression and 14 psi so far. Should handle 16 on pump gas no problems but havent taken it that far yet
__________________
1999 Trans Am
1989 Iroc-Z L98
Old 11-16-2009, 09:15 PM   #19
JRracing's Avatar
Trader Rating: 34
Send a message via AIM to JRracing
Very impressive car. You need to get a brake in it so you can bring it up to about 4K on a tweo step. LOL. Wouldn't that be something???
__________________
93 LX coupe-eagle 383 LS1 13:1,AFR 205's, super victor,Quick Fuel 950,MSD 6LS ign,coan th400 T-brake,TCS 4500,spooled 8.8 4.10's. 9.98@134 1.36 60' NA.
04 chevy 2500 ccsb 4x4.
JRracing is offline   Reply With Quote
Old 11-16-2009, 09:28 PM   #20
TTA1437's Avatar
Trader Rating: 6
That is impressive man! Who did the manifolds and what intercooler is on this car?
I would love to do this to a third gen.
__________________
1989 TTA
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
273, drag, end, forward, gear, iroc, ls1, lsx, pictures, racing, rear, stock, tb, tube, turbo, twin, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
