thanks mike, yes. clear gains were made with this vs. stock rear sway or w/ air bags
best short time ever was 1.38 previous, 3rd pass on this set up (first hard launch at all) was 1.35
eric i appreciate your time as well having one on deck for me.
normal turning is unaffected far as i can tell. my spool is more noticable on slow turns, but i think slow turns if anything are also better (with spool and no front sway)
yes not taking this set up off during street driving. it is better with it on.
Glad to see it worked out for you. Roughly 2 and a half tenths, thats sick!! Let me know if you need any other help.
Mike
hey mike you seen the video.. where do you think i need to go with adjustment from here? remember its hooked to the bottom of the rear.. i think that reverses your original suggestion no?
in the vid it sill brings up the drivers front more, not that i'm complaining!
quite sure thats the best 60' on that tire EVER, should ask M/T
You should probably tighten the passenger side rear 1/2 turn (or lengthen the driver side rear 1/2 turn, either one) if its still pulling the front driver side slightly more than the pass side front.
If you find out on the 60' let us know!!! Im sure it has more in it too
Let us know if you need anything else, thanks!
__________________ TRZ Motorsports
Manufacturer of Performance Suspension Components
I have had the TRZ ARB on my street car all year ,I really like the way the car drives on the street now. Best 60 ft this season 1.363. I would highly recommend this product to anyone. Thanks TRZ.
__________________ First LT1 Of Any Kind In The 8's
New Combo coming one of these days.. pair of GT42's
i really like this peice but ive been concerend with streetabilty since my car is a street car and al clearance with my dual dual exhaust system. its one big ass muffler.
__________________ 99 SS M6 416 LS3 / TFS 215'S / FAST 90/90 / DANA 60 / NITROUS DAVES 90MM PLATE 527 RWHP/ 496 RWTQ 733 RWHP/ 783 RWTQ on the nitrous
9.91@141 N2O / 10.78@128 NA GMHTP feature car Nov. 09' www.fquick.com/ls2bait
idk about the best ever....ive seen a tt 6 speed cobra do a 1.38 on them...get down to a 1.32 or so and id agree....ive been a 1.38 on 255.50.16
__________________ LATE MODEL PERFORMANCE
94 Artic White A4 Z...The Toy | 95 Polo Green 6 Speed/99 NBM S10...The Daily's | 1994 Polo Green Z, cam only toy
Sold...1998 Black Z, 1999 NBM Z, 1999 Red Z, 2000 NMB Z, 1994 Black Z, 1996 Polo Green Formula, 1996 Artic White Formy, 1999 White S10
cobra is local its irs car too...it was a lucky launch...cars all over the place without a 2 step and with a stick..that was on 315/35/17 hoosiers...not m/t(which the mt should be better)
ive been 1.38 also on 255/50/16 stock wheels...that was cake...i could prolly go faster if i tried to stick them back on...that was a cam only motor with a 125 shot
i know a local guy that was on pinks(blue iroc) that car is about 3650 little heavier and hes been i think a 1.36 on the 255/50/16's
either way your cars running well...the long gears is helping those tires hook a bunch...
i relaly wanna do a very similar car to yours that weighs about 3200...
are you sure the passenger one gets shorter? it would be doing the opposite considering where mine is mounted yes no?
Normally on ARB's above the rearend of ours, lengthening the passenger rear link is whats needed to preload it correctly. Since these are under the rear w/ the links going up, tightening the passenger rear will preload it correctly. It's opposite what we're used to doing. I know this cuz when it was put on Will Stevenson's car, they adjusted it the traditional way which made it worse, and makes sense, cuz they preloaded it the wrong way.
car race ready with you in it with your gear on.
Put two scales under the rear tires
Disconnect the drag bar
adjust the front driver spring, to put 15 lbs. more on the passenger rear then driver rear.
Square up the rear so it sits level to the ground, may have to adjust the front also
Then reconnect the drag bar while you are still sitting in the car with no preload.
This will make it hook better, come up squarely and go straight.
Bob
__________________ 99 WS6 M6 Street/Strip
Engine; FMS; N/A 441ci, 884hp/649tq, ET Canted Valve, SR cam, Beck Intake, TB115mm
Suspension parts from Madman and Burhart. Estimated Race Weight; 3200lbs
from it leaving not alot...it looked good..that mph and et is about right on..there might be some more in the 60' but i wouldent count on it much more...i think your just about at the point where your goana need more power or less weight...
Man that is killer David!! I guess that more than proves that the TRZ piece works on cars quicker than 11 and 12 seconds (somebody claimed that when I first made a post about it = LOL ).
Have you ever put some slicks on the car? I understand the challenge of running it on the street tires, but the thought of launching it harder on slicks would be an interesting test too
Congrats again!!
__________________ 355" Small Block Olds 78 Cutlass
11.44 @ 115.16 N/A PUMP GAS www.TRZMotorsports.com Dealer/Rep
