Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > RACING DEPARTMENT > Drag Racing Tech
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Drag Racing Tech
Rules | Safety | Setups | Hardware | Methods
Sponsored by
Improved Racing Products
Click Here
Old 11-30-2008, 04:40 PM   #1
Transamman25's Avatar
Trader Rating: 0
Send a message via Yahoo to Transamman25
Default What Springs cut the best 60 Ft ??
Well im tearing down my 96 Trans Am for the winter replacing the rearend with a 9" , UMI Stage 5 front suspension and replacing the street rims/tires for slicks and skinnies .... i want to replace my lowering springs to improve my 60 ft ... what is everyone using ?
__________________
68,79T/A,85,95CompT/A,96T/A,99T/A,02Firehawk
Transamman25 is offline   Reply With Quote
Old 11-30-2008, 05:47 PM   #2
DADDY&GIRL93TA's Avatar
Trader Rating: 0
Using stock rears here.
__________________
FASTEST 1/4 - 12.914 @ 106.13
Fquick - FINALLY IN THE 12s
Keith & Tawny
DADDY&GIRL93TA is offline   Reply With Quote
Old 11-30-2008, 06:46 PM   #3
Trader Rating: 0
what kind of 60 ft's on how much power ? Im making 867 to the rear wheels on a mustang dyno -- 1.9 60ft through 10 bolt when it died !
__________________
Old 11-30-2008, 07:00 PM   #4
Trader Rating: 0
low 1.8s on stock motor,tranny,. Best run to date is 12.94 i think . Thanks to the weather lol
__________________
Keith & Tawny
Old 11-30-2008, 07:04 PM   #5
Blake01SS's Avatar
Trader Rating: 21
Send a message via AIM to Blake01SS
Im using stock springs in the rear as well. Went 1.60's in the 60ft all day with only 420hp.
Blake
__________________
LME 416ci LS3...Glide...9"...???mm Turbo...
Blake01SS is offline   Reply With Quote
Old 11-30-2008, 08:12 PM   #6
T/A KID's Avatar
Trader Rating: 6
What do you have to make 867RWHP???
__________________
http://s69.photobucket.com/albums/i77/TAKID/?start=0
383 LT4, AFR's,Custom Super Vic, D1SC procharger, Alky, 4L80E, Fab 9
Goal is a 9 second Daily Driver
T/A KID is offline   Reply With Quote
Old 11-30-2008, 08:51 PM   #7
Trader Rating: 0
alot of Nitrous (on a Forged stroker engine with a great tuner) thanks to Nitrous Outlet .
Window switch is 3000-6000rpm's , but damn i cant get her going ( i even tried over-gearing to get her moving) now im going over board before the LTX shootout to turn the #'s i should be !
__________________
Old 11-30-2008, 10:48 PM   #8
Trader Rating: 19
stock springs with QA1 12ways in the rear with spohn drag bar. best is 1.509, normally some where in the mid 1.5s, stock LS1 with bolt ons, 3110#s, not making much power with only 113MPH...
__________________
Lots of different things going on
Shon Herron is offline   Reply With Quote
Old 11-30-2008, 11:20 PM   #9
9sec93's Avatar
Trader Rating: 39
i have stock springs with QA1 shocks in the rear and stock springs with QA1 R-series up front and many many 1.29 60's
__________________
97 Firebird
9sec93 is offline   Reply With Quote
Old 11-30-2008, 11:27 PM   #10
Packy's Avatar
Trader Rating: 5
Send a message via Yahoo to Packy
I have stock springs with QA-1's in the front and rear. The rear springs I do not run spring isolaters on them so it sits about an inch lower in the rear. I just put some rubber tubing around the top of the spring. The front I lowered on the QA-1's about an 1" to 1.25". I cut from 1.5 to 1.6's regularly.
__________________
1999 Trans Am WS6 - Forged 346, P-1SC (8psi), TH-400, and 12 bolt. Best 1/4 mile 10.60@127 w/1.54 sixty ft.
2004 Mustang Cobra/Screaming Yellow-Whippled-DD
571rwhp 520 tq
Packy is offline   Reply With Quote
Old 12-01-2008, 09:30 AM   #11
Race your car!
JL ws-6's Avatar
Trader Rating: 43
Location: In the garage, working towards a 2900 lb raceweight :D
Send a message via AIM to JL ws-6 Send a message via Yahoo to JL ws-6
Stock rear springs, 300 lb qa1 front springs, r series front shocks and standard 12 way rears and the car will go a 1.35 on a good day, 1.40 on a shitty prep.
Looking at changing things a little bit in the future, but it will be a $ thing to see what I can float when I am ready to get back to it.
__________________
I'm Looking for someone to make me a set of rails for a pin on ws6 hood.. PM me if you can do it!
Quote:
Originally Posted by J-Rod
First off Hp/L is ricer math, and is pretty much useless
JL ws-6 is offline   Reply With Quote
Old 12-01-2008, 10:08 AM   #12
Trader Rating: 3
I run Eibach Drag Launches, with QA1 12 way's. I've had the springs for a while, they were cheap. I cut 1.3's on a DR with them though
__________________
6.19@111.3 Shakin' it down
347--TH350--BS3
jmill96Z is offline   Reply With Quote
Old 12-01-2008, 10:11 AM   #13
BlackScreaminMachine's Avatar
Trader Rating: 16
Pretty much the plan I am following, 300 pounders up front, stockers in the rear and the QA1 to adjust the transfer!
__________________
2002 Navy Blue Metallic Trans Am.
FS: Stock GM & Ram Clutch Master Cyl. LOW MILES
http://www.ls1tech.com/forums/lsx-pa...l#post12706945
BlackScreaminMachine is offline   Reply With Quote
Old 12-01-2008, 10:24 AM   #14
tektrans's Avatar
Trader Rating: 7
Stock springs here with dual airlift airbags that I adjust for track conditions.
__________________
'98 Trans Am WS6 Cartek N/A (L92/LS7) Hydraulic roller 441 ci.
9.59 @ 138 1.30 60' - Best 60' 1.29
video of 9.6x passes http://uk.youtube.com/watch?v=KVdBZk5Y3s4
**check out my TA in the Aug '09 issue of GMHTP magazine**
http://www.gmhightechperformance.com...ws6/index.html
tektrans is online now   Reply With Quote
Old 12-01-2008, 10:34 AM   #15
Trader Rating: 16
Oh and if no one has mentioned, a good drag swaybar. TRZ has a trick peice that I just found out about, or you can get a BMR/Wolfe style bar to keep the rear from mushing to the right.
__________________
Old 12-01-2008, 01:21 PM   #16
Z-RATED94's Avatar
Trader Rating: 6
Times and 60ft. in sig. I'm on stock shocks and Eibach Pro lowering springs. There's an air bag in the right rear and a few suspension pieces too. I'm thinking when I need more traction I'll keep the rear springs and put the stock springs back up front with some double adjustable shocks. For now, if it works I'll leave it alone.
__________________
94Z28, full bolt-ons, LE heads and 222/226 Joe O. cam, Wolfe CM 6-point, Nitro Daves plate kit (140 shot), Yank SS3600, 3.73s, Bogart wheels, MT tires. 11.88 @114mph NA, 10.75 @ 125mph juiced w/factory shortblock, trans, and 10 bolt.
Z-RATED94 is offline   Reply With Quote
Old 12-01-2008, 03:02 PM   #17
Trader Rating: 2
I have Stock rear springs, 275 lb qa1 front springs and QA1 shocks but I have 400 less rwhp then you lol(only 451 rwhp)
I generally get 1.43-1.45 60fts
__________________
96 camaro,LT4 solidroller 383,single plane intake with 90mm accufab tb,afr 210cc heads,th400 with t brake 5200 ati stall,26 inch et drags
10.62@127(1.43 60ft) 6.68@102 1/8th (all motor)
3325lb race weight
http://videos.streetfire.net/video/S...-DJ_133669.htm
Dave J is offline   Reply With Quote
Old 12-01-2008, 04:40 PM   #18
Trader Rating: 19
Quote:
I like the look of that TRZ unit, just hard to get it over the Spohn Drag Bar I already have but you never know....it is lighter and looks to be just as effective.....
__________________
Old 12-01-2008, 04:47 PM   #19
smokeum99ta's Avatar
Trader Rating: 15
Quote:
eibach lowering springs here. 1.35 60'. I don't think the springs matter as much as the shocks. I run QA1's single adj. with good results. And a thicker rear sway bar helps alot too.
smokeum99ta is offline   Reply With Quote
Old 12-02-2008, 12:53 PM   #20
Z-RATED94's Avatar
Trader Rating: 6
Quote:
Eibach lowering springs (1.35 60ft.), maybe we're on to something here.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
