Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > RACING DEPARTMENT > Drag Racing Tech
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Drag Racing Tech
Rules | Safety | Setups | Hardware | Methods
Sponsored by
Improved Racing Products
Click Here
Old 03-08-2009, 05:55 PM   #21
Trader Rating: 1
Ahh stick with the 400.....Just get rossler to build you one.....Talk about some coin..
__________________
http://i146.photobucket.com/albums/r...008-0112-1.jpg
SOLD
Bye truck lotta fun. But now to get the BBC turbo outlaw drag radial going........
notyets10 is offline   Reply With Quote
Old 03-08-2009, 05:56 PM   #22
8 Second Cyber Gray Mod
Navy David SS's Avatar
Trader Rating: 12
On my "Navy David SS" - Navy= retired U.S. Navy. 22 years from 1971 until 1993.
It has been mentioned changing to "Cyber Gray David SS" .
__________________
1998 SS NBM, Build #114, A3
My SS Site on fquick.com
Sponsored by Excessive AutoSports, Sioux Falls, SD
Navy David SS is offline   Reply With Quote
Old 03-09-2009, 09:35 AM   #23
Trader Rating: 0
Quote:
Originally Posted by Gen414 View Post
First of all, VERY nice setup. Love teh color, looks REAl good, I like it alot.
I do have a couple questions:
First, sure does seem like alot of injector for your goals. Why do you feel you need the 160 AND the 100?
Second. With all the work you are doing to the car, and this is obvioulsy not some "throwing a new turbo on" type of job, AND since you are wanting to pick up @ a second in teh 1/4....why would you keep the same cam? Converter?
I mean, you see so many cars running rock bottom 7's and 6's with just set of 160 lb r's, just curious as to why you want the complexity of running the 2nd row. I mean, you can even step up to the Moran's injectors that are adjustable. Just seems like alot of work (and $$$$$$) to add that second row of injectors, when you can get what you want with just one set.
The cam and converter I can see more so than the injectors, but thought I would ask anyways. Obviously you are gonna be making and NEEDING alot more power to pick up that second you want....I would think you would want more cam to help out and more converter.
I am just simply asking some simple questions that I thought of after reading about your build. PLEASE do not take it anyway but that...a SIMPLE question is all. As I said, your car look sick, and the build looks like it is gona be a nice setup, for sure. Good luck!
The reason for the pair of injectors is two fold... we already had both pairs and we will be running the car on e98... our 1200whp modular foxbody is at 91% on 1600cc on e98 so we will be needing the extra very easily.... also we do all the fabrication in house so the cost ended up being around 75.00 for materials to add the seconds... and seeing 16 injectors just shows you mean business...
copbait is offline   Reply With Quote
Old 03-09-2009, 09:50 AM   #24
LS1Tech Sponsor
Gen414's Avatar
Trader Rating: 37
Quote:
Originally Posted by Navy David SS View Post
Thanks guys.
Reason for the double injectors: we are going to be running E98..more injector is going to be needed to pump in more gas. The car is run off AEM so we will be able to control the amount, time, etc for the injectors. If we do run a race that E98 is not allowed will just retune for C16.
Converter was built for 1500+ hp.. why change. I worry more about the TH-400. If someone wants to donate $5K for a new glide and converter, I'm wide open for the donation.
Cam.. again it works. We have thought about going solid, but we'll try this first.
NOTHING, I mean NOTHING, is thrown together on this set up. My builder has thought everything out. There is a lot more changes. To list all of the changes would take way to much space. Money is more of a limiting factor. My sponsor has a very small shop. I supply the parts, he has been supply many, many hours of his own time. I can't thank Joey enough.
David
Again, I NEVER said anything was thrown together, just had a couple of simple questions.
I understand your reasoning on teh injectors more now, even though I can not completely agree with it, I understand why you want to.
I did want to add a more familiar face 1 row of injectors...Isn't Phil (of this board) running 1 row of injectors as well? 7.50's @ 190. Now, I am not 100% on that, but pretty sure. Again, I am NOT trying to argue. You want to run 2 rows of injectors, it's cool.
Converter. So, it was made for 1500 HP in the first place? So, you had too tight of a convert this whole time? Wow, car should really pick up now since you will be making the power the converter was made for.
Cam. It's cool. Run whatcha got, no problems here. When you do swap over to solid you will ask yourself why you did not do it before. Once you hit these power levels, a solid can and will pick up power across teh board. Running those ET's with a hydraulic is impressive
Again, very nice build, clean car, I like. I hope my car turns out this nice when I am done with it
__________________
www.morrismotorsports.net
281-732-8215
Dealer for Monster Clutches
Gen414 is offline   Reply With Quote
Old 03-09-2009, 09:52 AM   #25
LS1Tech Sponsor
Gen414's Avatar
Trader Rating: 37
Quote:
Fair enough. Thanks for teh deailed explanation. I posted my above post, before I read this post.
Either way, I understand why, even though I do not necessarily agree, I do understand. hell, you are making boat loads of power, and that is all that matters, right? No matter HOW you get there, as long as you are there. And you are
__________________
281-732-8215
Old 03-09-2009, 09:54 AM   #26
LS1Tech Sponsor
Gen414's Avatar
Trader Rating: 37
Thank you for serving our country! You military guys do me and my family proud, thank you!
__________________
281-732-8215
Old 03-09-2009, 07:49 PM   #27
Black Sunshine/ 00SS's Avatar
Trader Rating: 1
Yes, I thought that's what it was in reference to. Thank you again, for your service!!!
__________________
01/SS, Black. W2W 402, AFR225, T400, 12 bolt, Eldebrock LT, true duals. 10.43@129 NA, 9's with help
Bolt on stock internal: 11.496@116.42 (1.52)
396 & n2o: 9.90@137.39 (1.41)
http://community.webshots.com/user/blacksunshine00ss
http://community.webshots.com/user/hotrodharry03
[/SIGPIC]
Black Sunshine/ 00SS is offline   Reply With Quote
Old 03-10-2009, 07:14 AM   #28
Trader Rating: 12
Thanks. It was my pleasure to serve our country.
David
__________________
Old 03-10-2009, 07:19 AM   #29
Super Slow Mod
Fireball's Avatar
Trader Rating: 16
any pics of how you mounted the radiator?
__________________
1999 Pewter T/A | Just another slow drag radial car (see here)
Virginia Speed 366ci LS2 + big turbo (the little block that could) | 7.99 @ 177.8 (1.36)
Virginia Speed 388ci LS2 + bigger turbo | In Progress
Special Thanks to TheOutlaw1, Phil99vette, Shawn @ Va Speed and MADMAN for all their help
Freshened up 366 turbo race motor for sale
Fireball is online now   Reply With Quote
Old 03-10-2009, 09:01 AM   #30
LS1Tech Sponsor
Gen414's Avatar
Trader Rating: 37
Quote:
^Agreed
Also, any more pics at all? Nice work, ya need to share
__________________
281-732-8215
Old 03-10-2009, 09:45 AM   #31
veee8's Avatar
Trader Rating: 26
You have to remember, as mentioned, that this is being setup for Ethanol. The demands are much higher with any of the alcohol type fuels. If it were strictly a C16 or Q16 setup, 1 row would probably work. With the 2 rows, and the proper management to control them, you can take a lot of load off the pump(s), and leave room for big power. All the while, saving the environment!
veee8 is offline   Reply With Quote
Old 03-10-2009, 09:49 AM   #32
Trader Rating: 0
No picts of the radiator as of yet... in the next five days all of our parts will be back from the powder coater so ill make sure dave updates with those picts... as for the injectors remember we are on e98 this year... so it takes 55% more fuel then your normal race gas. so without having to buy 200 dollar a piece moran injectors.. thanks for the kind words
Old 03-10-2009, 06:43 PM   #33
Trader Rating: 12
The painter was suppose to bring the rest of the SS to the shop today, but good old South Dakota. Started as freezing rain, turned to snow
Engine is together. Wiring is almost done. Cage is painted. Carpet is going in tonight. Everything is tracking OK. Power coating is scheduled to be done tomorrow (Wednesday), Thursday at the latest. Joey (my builder) is hoping to set the engine in tomorrow. Tranny was freshened up last year - only 1 weekend on it. Converter was just reflashed and cleaned - only 2 weekends on it. Rear end is still in great shape - we are going to only have to change its oil. Fuel and water tanks are completed and in; battery set-up is ready to go in. Man, Joey has busted ass on this build. Oh yea, the tires are bought just need to be mounted - ET Drag 30x10.5W front; new ET Front Runners - same rims. The M/T Drag Radials are still good for another 30-40 passes.
Only 10 days to the car show.
Still have to wait until last weekend in April for the local track to open.
David
Old 03-11-2009, 09:52 AM   #34
LS1Tech Sponsor
Gen414's Avatar
Trader Rating: 37
David
Wow. Our track opened in January It is closed for like 1 month during teh year. Dec-Jan. I lived in N.D. (Wapenton, sp?) for almost 5 months back in 1995, or 1996 I got there in May, with snow on teh ground , wore a winter coat in teh morning all through teh summer and left in Sept, with snow back on teh ground.
Back on topic, car is almost there!! Obviously you will, but make sure you post up some pics when you get 'em and of course some time slips!!
__________________
281-732-8215
Old 03-11-2009, 09:59 AM   #35
LS1Tech Sponsor
Gen414's Avatar
Trader Rating: 37
Right, I understand and that was actually something I either did not see, or was not posted (about the 98) is why I was not sure on teh 2 row, and that is why I asked.
Sometimes I come off as being rude, but I just ask questions that don't make sense to me, and that is why I was trying to be VERY clear that is was just a simple question, and no more. As you can tell, I have come across some "sensitive" people on this board, and other forums for that matter
It's cool (and so is the build!!) that is why I am following this thread along
__________________
281-732-8215
Old 03-12-2009, 09:20 PM   #36
Trader Rating: 12
UPDATED Pictures
David
__________________
Old 03-13-2009, 12:23 AM   #37
patriotformula's Avatar
Trader Rating: 22
Send a message via AIM to patriotformula
David is that wrinkle finish on those cold parts and canister? Looks like the same finish on my old man's hemi valve covers...
__________________
98 Camaro SS MS4 cam only, TH400 w/ transbrake, Midwest Chassis Fabricated 9 inch
patriotformula is offline   Reply With Quote
Old 03-13-2009, 09:06 AM   #38
LS1Tech Sponsor
Gen414's Avatar
Trader Rating: 37
Heck yeah, looking GOOD!!
__________________
281-732-8215
Old 03-13-2009, 08:58 PM   #39
Trader Rating: 12
Valve covers, turbo cold parts, both tanks, radiator shroud, etc. are all wrinkled powder coated.
New pictures from today..
Got the rest of the body parts back from Painter-the car is taking shape
Turbo is in place. Most of the hose it hooked up. Radiator is in place
NEW CUT FENDER WELLS - TOTAL REDID BY MY BODY MAN
David
__________________
Old 03-14-2009, 12:12 AM   #40
LS1Tech Sponsor
Josh@KY-Turbo's Avatar
Trader Rating: 114
That is friggin awesome bro.
__________________
www.KY-Turbo.com
KY-Turbo Inc.
112 D Nugent St
Bowling Green, KY 42101
270-303-0531
Josh@KentuckyTurboAndPerformance.com
Josh@KY-Turbo is offline   Reply With Quote
Tags
wapenton
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
