Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > RACING DEPARTMENT > Drag Racing Tech
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-26-2008, 11:23 PM   #21
1998 Chevrolet Camaro
LT1Formula007's Avatar
Trader Rating: 16
Send a message via AIM to LT1Formula007
I found a good deal on a 12 bolt from a 3rd gen as well, And was wondering the back spacing for a 8 inch wide wheel to fit under the wheel wells and not stick out at ALL on my 98 Z28?
Also if I chose to use a 10 inch wide wheel for the track, What should the back spacing be??
Any Help?
Thanks in advance!
James
__________________
JUST ANOTHER SLOW CAMARO!!!
RIP DAD.... I LOVE YOU!!!
LT1Formula007 is offline   Reply With Quote
Old 10-30-2008, 07:18 PM   #22
kenSS's Avatar
Trader Rating: 1
i have a third gen with 15*9 draglites with 5.5 backspacing. tucks under real nice with a 28*11*15 tire.
__________________
2000 SS M6 black SLP package, spec stage 2 clutch, RAM billet steel flywheel, BMR sub frames, Lakewood LCA, Random Tech. Adj torque arm,
1986 Camaro, 383 stroker, scat forged bottom end, diamond 11:1 pistons, 220 motown heads, bullet solid roller cam. Crower HIPPO lifters,RMVB TH 350, ATI 8"converter, S60 W/ 4.11gears and locker. All Spohn suspension. TRC 950 Carb.
1966 Chevelle 427 4 speed
kenSS is offline   Reply With Quote
Old 11-13-2008, 01:50 AM   #23
zssman's Avatar
Trader Rating: 1
Quote:
Any pics of this setup?
__________________
-Phil
1992 Z28 Camaro- Taking a nap.
02 black SS, 383,4L60E,12bolt, Bogart d10s w/mt drs.99 Pewter ext cab sportside silverado, 5.3
zssman is offline   Reply With Quote
Old 11-13-2008, 02:30 AM   #24
11 Second Truck Club
sprayinLS1s's Avatar
Trader Rating: 17
my question relating to this is...... i have 305-35-18s on 10.5"x18" Z06 wheels on my '01 Z w/ 10 bolt, does anybody know the spacing on these, i will probably go with a 3rd gen rear b/c i have also seen several good deals on them, i knew they would bolt in and that they were narrower, but didnt know how much, i'm changing to 15s all around, the wheels i want are only available with dish, just need to find out how much b.space i need so they will clear the same as the 18s......... any help is greatly appreciated
__________________
1.60 60'.........0-60 in 3.6 sec...... 1/8 in 7.30..... 1/4 in 11.6....
7.29 pass
http://videos.streetfire.net/video/8...c800ef37d4.htm
0-60 in 3.6 sec.
http://videos.streetfire.net/video/0...ado_157346.htm
sprayinLS1s is offline   Reply With Quote
Old 11-14-2008, 08:43 PM   #25
kenSS's Avatar
Trader Rating: 1
Quote:
unfortunatly not right now. i just painted the car and the wheels are off the car. i have to buff the car out. pics soon hopefully.
__________________
Old 11-15-2008, 06:25 PM   #26
xpndbl3's Avatar
Trader Rating: 7
Send a message via AIM to xpndbl3
i run a 28x12.50 with 6.5bs on a 15x10 rim. the "typical" thirdgen spacing would be 5.5bs but i wanted to hack out my wheelhousing to tuck the slicks even more.
__________________
xpndbl3 is offline   Reply With Quote
Old 11-15-2008, 06:29 PM   #27
Trader Rating: 3
thirdgen rear is almost 2" narrower than 4th gen
I put a 4th gen on my thirdgen and its about 3.5-3.625" wider OVERALL which means 1.75 or so wider per side
__________________
1999 Trans Am
Stock Daily Driver
1989 Iroc-Z L98
401" Dart block, AFR 195cc, Jones 233/233 112lsa
Twin 60mm turbos, Victor EFI single plane
TH400, PTC converter, 10 bolt 2.73 gear
9.86 at 141 1.56 60' 14psi street tune pump gas
Orr89rocz is offline   Reply With Quote
Old 11-15-2008, 07:37 PM   #28
Taubr Unit's Avatar
Trader Rating: 24
Send a message via AIM to Taubr Unit
car looks a lot better with a real set of tires in the back steve, no more mud boggs, lol.
Well i ended up getting a midwest fab9 stock width, works out perfect for me
__________________
Super Light, ProCharged 6.0 build-------> http://www.ls1tech.com/forums/drag-r...ootin-10s.html
Taubr Unit is offline   Reply With Quote
Old 11-15-2008, 07:58 PM   #29
JUICED96Z's Avatar
Trader Rating: 2
My car has a broken 10 bolt in it (12 bolt going in wifes car) and its about that much shorter, I put my third ged BS rear wheels back on and there is no was I was going to take it off the jacks haha.
__________________
Black 86 IROC-Z - Wifes car - FOR SALE, Roller.
My Car - I dunno George.....
JUICED96Z is offline   Reply With Quote
Old 11-15-2008, 10:26 PM   #30
xpndbl3's Avatar
Trader Rating: 7
nice i also have a set of 28x11.50 ET drags i'm going to try out as well if I don't sell them. Those mud bogs were sweet on the street with the spool though. I took the slick pics way back with mike when we put over 50 miles on the car that one day for our photo shoot.
__________________
Old 11-15-2008, 10:50 PM   #31
1BADAIR's Avatar
Trader Rating: 1
these two cars have a 3rd gen 9inch(actually the same rearend was in both cars)
1BADAIR is offline   Reply With Quote
Old 11-16-2008, 12:53 PM   #32
tomcowle's Avatar
Trader Rating: 5
I have a 9" (3rd gen width) that I'm putting in my 4th gen, I didn't want all the backspacing that the 4th gen rear has. Couldn't beat the price either.
__________________
LT1 Bolt on only 11.48 @ 118mph Fuel Injected
LT1 Bolt on only 11.50 @ 118mph Carbed
Thanks: MT Tires, Mike Blood Transmissions, TI Dyno
tomcowle is offline   Reply With Quote
Old 11-19-2008, 01:08 PM   #33
Trader Rating: 0
mine is the opposite of all yours, a 3rd gen with a 4th gen 9"(found it carlise for 600$) with 15x10 prostars with 7.5 bs
__________________
89 305 tpi formula stealth manifold, 650 dp holley, msd pro billet and 6al box, t-56 with a pep boys clutch,spohn x-member and torque arm,1.65 lunati rockers,1/4 12.54 @109 1.722 60'
89305formula is offline   Reply With Quote
Tags
10, 3rd, 4th, 75, body, bolt, camaro, end, gen, gm, mini, narrowed, narrowing, rear, tubbed
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
