Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > RACING DEPARTMENT > Drag Racing Tech
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-12-2006, 01:31 AM   #1
Taubr Unit's Avatar
Trader Rating: 24
Send a message via AIM to Taubr Unit
Default 3rd gen rear in f-body = poormans narrowed rearend
since you can put a 4th gen in a 3rd gen. i would assum you can do a 3rd into a 4th gen. Since a 3rd gen is 1.5in. shorter on each side, it would basically be like shorting the rearend correct? So then can you run a 15x10 on a 11'' tire and it wouldnt stick out? Asking because my buddy has a line on a 9'' with 33 spline axles 4.10's blah blah for $1500!!
__________________
Super Light, ProCharged 6.0 build-------> http://www.ls1tech.com/forums/drag-r...ootin-10s.html
Taubr Unit is offline   Reply With Quote
Old 10-12-2006, 02:17 AM   #2
Trader Rating: 4
would all mounting points for the rear and suspension pieces be the same?
__________________
STILL EATIN MUSTANGS AT A MILE HIGH
Just a few bolt ons.
http://i75.photobucket.com/albums/i3...L/94Z28L-1.jpg
Mike
94z28L is offline   Reply With Quote
Old 10-12-2006, 02:19 AM   #3
Taubr Unit's Avatar
Trader Rating: 24
yes, direct bolt-in
__________________
Old 10-12-2006, 02:44 AM   #4
Trader Rating: 4
do it, just will need different wheels or some spacers and hardened studs
__________________
Mike
Old 10-12-2006, 05:25 AM   #5
tektrans's Avatar
Trader Rating: 6
I'm all for the poor man's route. Let us know how it works out.
__________________
'98 Trans Am WS6 Cartek N/A (L92/LS7) Hydraulic roller 441 ci.
9.59 @ 138 1.30 60' - Best 60' 1.29
video of 9.6x passes http://uk.youtube.com/watch?v=KVdBZk5Y3s4
**check out my TA in the Aug '09 issue of GMHTP magazine**
http://www.gmhightechperformance.com...ws6/index.html
tektrans is online now   Reply With Quote
Old 10-12-2006, 08:57 AM   #6
slow trap's Avatar
Trader Rating: 10
if it is 1.5" a side shorter then you will need either a 5.5" or 6.0"back spacing.the main thing about going in too far is rubbing on the inner wheelwell which may have to be massaged.keep us posted on the progress.
__________________
tsp 408,katech heads,244/248 110 +1,fast 90/90,blah,blah,blah.538 rwhp,486 rwtq with cutout open .
11.11 @ 125 1.63 60' with alittle less hp.
slow trap is offline   Reply With Quote
Old 10-12-2006, 09:07 AM   #7
gator's 99TA's Avatar
Trader Rating: 2
Send a message via AIM to gator's 99TA
you can always order a rear thats narrowed. locally guys are paying 275 complete to narrow rears. but otherwise it will work. 1.5" isnt much IMO
__________________
- John
1999 Pontiac TA - 404" LQ9|N2O|TH400|Radials|3600 lbs|Pump gas street car
2003 GMC Yukon 4wd - Baby Car Seat
gator's 99TA is offline   Reply With Quote
Old 10-13-2006, 12:08 AM   #8
Trader Rating: 0
Send a message via AIM to GlitzyGirlSS Send a message via Yahoo to GlitzyGirlSS
can you narrow a rear end and run a deeper dish wheel without having to mini tub?? if it only cost 275 to narrow a rear end i may go this route. does that price include narrowing the axles??
GlitzyGirlSS is offline   Reply With Quote
Old 10-13-2006, 09:52 AM   #9
Trader Rating: 2
a local chasis shop does it for that much. yes you can. do a search b/c its been talked about many many times.
__________________
- John
Old 10-14-2006, 05:06 PM   #10
Trader Rating: 6
I just had my car mini tubbed (will post pics), and was speaking to the chassis builder (NRC Motorsports) and he told me it's better to go with a 15x10 with 5" BS instead of 7.5" (I believe that's what's required with a stock length rear in a 4th gen) because it puts the load right in the middle/center of the wheel?? I don't like the deep dish look cause it will take away the stock look from the car but if it works better than I'll use it,besides the American Racing Trak Star wheel I wanna use can't be had with a 7" or 6" BS (atleast they don't list it). I know you can fit a 11.5" without major surgery (minitub) because I had 17x11.5" ( 315/35/17) Fikse's in the rear, I rolled the lip and massaged the inner well and they never touched! Not sure about a taller 28-29" tire, but I've seen 325/50/15 without minitubbing and not sticking out past the wells. Regardless of rear length you cannot change what size wheel/tire combo will fit without minitubbing or some sort of mod to the wheel well. I think I'm gonna need a rearend 2.5" shorter than a stock 4th gen, but I'll put the wheel/tire combo on the measure up to make sure it's right! Just my .02!
__________________
95 Camaro, EFI SB2 SBC, 2004R, CM Cage, BS3, more
01 Z28 Fikses M6 Black/Black , SOLD!
07 Imp SS, Black/Tan Bolt ons coming, I'm broke right now!
Notime383 is offline   Reply With Quote
Old 10-24-2006, 09:38 PM   #11
black_z's Avatar
Trader Rating: 4
Send a message via AIM to black_z Send a message via MSN to black_z
Just wondering if the 3rd gen is 1.5" narrower or 3" narrower? I have heard both now.
__________________
Quote:
Originally Posted by flyin red TA
But most importantly, could you still see yourself peeing in her butt in 40 years?
black_z is offline   Reply With Quote
Old 10-26-2006, 01:55 AM   #12
Taubr Unit's Avatar
Trader Rating: 24
its both. 1.5 on each side. Making the entire rear a total of 3'' narrower.
__________________
Old 10-26-2006, 06:16 AM   #13
stevemilz's Avatar
Trader Rating: 3
15x10 7.5" BS
28x10.5W Tires
Quote:
stevemilz is offline   Reply With Quote
Old 10-26-2006, 10:54 AM   #14
DSG
DSG's Avatar
Trader Rating: 1
Why would you want a narrowed 10 bolt rear? Just order a Moser or Strange rear and they will narrow it for you.
__________________
Dave
98 Metallic Purple T/A...Eight Second Turbo Build Has Begun http://www.ls1tech.com/forums/drag-racing-tech/692234-project-barney-turbo-t.html
06 White GMC Sierra VortecMax... | 07 Harley-Davidson FXSTB Night Train | 04 Black GTO...Factory Stock, wifes beater
http://www.n2s1.net/images/Kevin'...06DaveN2S2.jpg
DSG is offline   Reply With Quote
Old 10-26-2006, 02:17 PM   #15
Trader Rating: 2
Good Question
__________________
- John
Old 10-26-2006, 06:00 PM   #16
wolfy's Avatar
Trader Rating: 2
what would the back spacing be on the 3rd gen rear for a 11" wheel? ive got a spare 84 camaro sitting around and ive got 15 x 11 draglites just sitting around...i might have to try this out for a weekend or two at the track...somebody let me know...
-cam
__________________
02 T/A, m6 ("natalie")
-new plans...and parts awaiting install
Quote:
Originally Posted by Old SStroker
The world (Mother Nature) doesn't run on math. Math is used to explain what happens; math doesn't cause it.
Mother Nature isn't a mathematician, She is a practicing physicist, and one tough ol' broad
wolfy is offline   Reply With Quote
Old 10-26-2006, 08:56 PM   #17
Taubr Unit's Avatar
Trader Rating: 24
Quote:
Im not talking about a 10 bolt. Question came about because i found a 9'' for a 3rd gen for a crazy cheap price. So if i could get a "narrowed 9''" for next to nothing then why not. Im with you, im not building a 10 bolt, but getting a narrowed 12/9''
__________________
Old 10-27-2006, 12:12 AM   #18
Trader Rating: 2
1.5" on each side is barely narrowed.
__________________
- John
Old 10-27-2006, 01:07 AM   #19
Moderator
FANTAZ28's Avatar
Trader Rating: 1
i run a strange 12 bolt that is out of a 3rd gen... works great , everything bolts up and you can usualy get good deals on them.
__________________
Cuttin' lites!
FANTAZ28 is offline   Reply With Quote
Old 10-27-2006, 01:17 AM   #20
Taubr Unit's Avatar
Trader Rating: 24
i know its just barely narrowed, but if you then run a 15x10 with a 11.5 tire, it prob. be mint
__________________
Tags
10, 3rd, 4th, 75, body, bolt, camaro, end, gen, gm, mini, narrowed, narrowing, rear, tubbed
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
