__________________ "stang burgers are ready; get'em while their hot!"
2000 NO OPTION ss m6 d1sc procharger kit (almost a full kit) for sale $3k shipped!
Pro 5.0 w/ short stick, tick stage 2 t56, tick master adj, ls7 clutch kit, raptor shift light,magnaflow catback,strano bars,mti clear lid, ngk 55 msd wires,
1 7/8 kooks headers w/ ory through cme, 3" all pro cut out,full suspension soon to be on.
Quote:
Originally Posted by Vendetta
The internet... Where the men are men, the women are men, and the children are the FBI.
ok ive added up whats removed from my car except the whole HVAC assembly im getting around 280ish...myself that airbag and bracket felt a lil heavier than 14lbs IDK....i guess ill weigh all the HVAC stuff tommorrow.....
ive also added up close to 100 lbs left to remove....
if anyone knows the exact hvac weight post up....
i was going to post something about this until i saw this post. so these weight are all dropped off? or the weight of the part itself?i just want to confirm that one more time please.
10e.A-Arms (BMR mild steel)
13e.A-Arms (stock)
38..Catback system (Hooker) lose 38 pounds?
3...Chromoly LCAs
3/9.Carbon fiber driveshaft 3/9?huh?
14..Chromoly A-arms like the post stated above you lose 14lbs! by going chomoly instead of the mild steel at 3lbs? are these bmr also?
25..Chromoly K-member so 42lbs off nose for chromoly lca,a-arms,k mem?
Most of the weights on the list are the actual part weight; so you would take the stock part off your car, weigh it, then look up the new part you are replacing, subtract the 2 numbers and that's how you see how much weight you saved.
__________________
2000 Trans Am 346 NA, 4L60EBest ETs: 6.49 (1/8) and 10.20 (1/4) Wanna Race? GMHTP Feature Car - November 2008 | 2009 LSX Shootout - #1 Qualifier (10.50 Index) www.fquick.com/FastTaGurl
I guess I dont understand this one. What is the difference? I see a 3lbs between plastic and steel factory tanks on the list. I'm pretty sure my LT1 has a steel tank.
-Dustin-
The plastic fuel tank on some 98-99 cars weighs 18 lbs. That's what this means. The weight listed is not what lbs. you save but what the actual part weighs itself. Then you would subtract your new part weight from the number to find weight savings.
__________________
how much does the entire rear hatch weigh with glass????
I'm considering running the VFN fiberglass hatch with a speedglass drop in window....
I think the hatch and the glass (VFN and lexan) is like 18 lbs total... the steel hatch and glass has gotta be like 150 lbs...
__________________ THE OUTLAW
1995 Camaro Z28 1LE West Coasts Fastest LT1 period.. CSM Racing Engines 383 LT1, AFR 227's, SR Cam, Jesel shaft rockers, Lunati crank, Oliver rods, sngl plane, Accufab TB, Nitrous Pro Flow plate, ATI TH400, Moser 9", FAST XFI
10.62@128 all motor
9.06@153.8, 1.35 60' ft on the bottle, 5.76 1/8th mile (aborted 8 second pass )
My youtube videos here--->http://www.youtube.com/user/tensecLT1
I don't know how much it weighs, but the stock hatch is fiberglass. The majority of the weight is the glass itself. There is a firebird hatch across the street from where I work with the glass busted out. I'll see if I can walk over and weigh it tomorrow. I would say a firebird and camaro hatch are close to the same weight and a TA is a solid 40lbs more than both. I've removed all three types and the TA hatch is a heavy sucker.
