Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > RACING DEPARTMENT > Drag Racing Tech
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 06-15-2009, 05:45 PM   #161
LS1Tech Sponsor
Jason Haines @ LPE's Avatar
Trader Rating: 0
Default 5500 rpm pop
So you have it set for 4200 and have it activated and it lets you get to 5500 rpm? You mentioned you are using the clutch switch to activate the two step so is the "pop" happening while the clutch is pressed down (switch active)?
Please also feel free to contact me directly if you would prefer to do so.
Quote:
Originally Posted by 06X6spdGTO View Post
Well i have my 2step installed and with it set a 4200rpm i noticed that it causes my car to make a terrible pop when reved anything higher than 5500k and shifted to the next gear. But with the unit shut off i dont get any pop at all.
Is this popping bad for my motor?? What can be hurt??
__________________
Jason Haines, Project Director
Lingenfelter Performance Engineering
260-724-2552
www.lingenfelter.com
Jason Haines @ LPE is offline   Reply With Quote
Old 06-15-2009, 06:28 PM   #162
06X6spdGTO's Avatar
Trader Rating: 3
the pop is happening after i make the shift and let the clutch back out and floor the gas.
(I think) If i shift slow it doesnt happen. Only when barely lifting to shift.
__________________
2006 BOM M6 GTO- Lingenfelter Maggie 112H, 458 RWHP 453 RWTQ.
2001 QS M6 Z06-Forged 347, SVO 30# injectors, 233/239 598 603 113lsa TSP, Probe Rods, Diamond Piston, LS6 heads****, B&M shifter, Stock LS6 TB/Intake, (NX WET KIT in the WORKS), Kooks 1 7/8Lts, B&B Bullets, SLP Ud pulley, Centerforce DF 12" clutch, O/R xpipe, Callaway CAI, 446 RWHP 406 RWTQ
06X6spdGTO is offline   Reply With Quote
Old 06-16-2009, 10:37 AM   #163
Trader Rating: 0
Im guessing the pop you hear is the sparking being cut then coming back in and igniting the unburnt fuel which in return causes a back fire.
SilV8 is offline   Reply With Quote
Old 07-09-2009, 04:11 PM   #164
camscam02's Avatar
Trader Rating: 10
quick question about the lcc-02(forgot the exact name) but anyways are the 2 step and timing retard on two separate switches? Meaning if I have the 2 step wired to the my momentary switch for my transbrake and push that down it will not retard the timing until it sees 12 volts from the nitrous controller? and vice versa if/when I release the transbrake button(momentary switch) and the timing retard will see 12 volts from going WOT, it will still retard the timing without the transbrake button being pushed?
if that makes any sense. lol
__________________
Cam only 10.97 at 123 w/a 1.46 sixty foot
Cam only+ a shot 10.10's at 135 and no traction
camscam02 is offline   Reply With Quote
Old 07-09-2009, 05:12 PM   #165
LS1Tech Sponsor
Trader Rating: 0
Default LNC-002 timing retard and 2-step operation
The LNC-002 timing retard feature and 2-step function are separate so you can trigger one or the other at different times. The 2-step is controlled by the RPM setting on the LNC-002, the timing retard activation is triggered by your external trigger source (nitrous controller etc.).
__________________
260-724-2552
Old 07-09-2009, 06:33 PM   #166
camscam02's Avatar
Trader Rating: 10
Quote:
Ok cool, think I was just overthinking it and just wanted to run it by you guys to make sure I was correct. Now to think of ideas and the best way to make it work aka the hard part.
thanks
__________________
Old 07-09-2009, 08:06 PM   #167
studderin's Avatar
Trader Rating: 18
I love mine, got it a few weeks ago. It shoots fireballs too when I shift fast WOT, but it shifts so easy
http://www.facebook.com/ext/share.ph...u=QConG&ref=mf
then 2 days later I got like a CEL, with like 10 codes for coil 1,2,3,4,5,6,7,8 missfires.
hookup was really easy, Just T taped the clutch switchwire right off the PCM. Think it was blue 35? that was 12v off the switch. So didnt have to run any wires into the car. I have the 003 with 2 stages so think I'm gona use the foglight (I removed them) 12v to trip the otehr setting, I can set lower for the DRs and street launches . Like 3500-4000 unpreped streets at night hook. That way I can still drive around daily without it back fireing every time I get over 3500 rpms. Did that once leaving a light passing a simi shit was realllly loud off the trailor with my windows down. And keep the main 2step at 6500
I can use it on the 2nd limiter (lower) launch with the foglights on. And turn it off if I want easliy
__________________
2001 Z28 m6 Mike@NewEra tune,SLP lid,NewEra portedTB, powerbond,SUX2BU ramair,3.73 s60, RAM HD-330whp/350wtq12.21 @114
StreetSweeper cam, 4:30s,ARH 1 7/8,SLP 2OTL fast92/92: 10.84@127 ~3280 street mode/drag wheels 10.66@128.4 open headers, 3160#
studderin is offline   Reply With Quote
Old 07-09-2009, 09:00 PM   #168
AChotrod's Avatar
Trader Rating: 10
Im gonna mount mine to a momentary on the steering wheel. Now I have a momentary near the shifter.
__________________
LE2, Speedinc, Bedroom built 355, T56
LE2 H/C/I, Speedinc tuned, LPP, UMI, BMR, Dana S60, Street twin, blah blah blah.......
2nd place EX NA at LTXshootout
AChotrod is offline   Reply With Quote
Old 08-13-2009, 04:50 AM   #169
rmata's Avatar
Trader Rating: 12
Is this the same with the LNC-001? I have one of those with the timing retard, but I have only ever used it as a launch controller with my transbrake button. But now I've been thinking about using it to retard the timing for my nitrous too so that I can give myself a little more power n/a instead of always running on a nitrous tune.
__________________
2000 Trans Am WS6 - 5.3l heads, G5X2, LTs, Volant, LS6 intake, Moser 9", TH400, and a little bit of nitrous
rmata is offline   Reply With Quote
Old 08-13-2009, 09:47 AM   #170
brandonppr's Avatar
Trader Rating: 6
What is the lowest RPM the launch control can be set to?
brandonppr is offline   Reply With Quote
Old 08-13-2009, 10:23 AM   #171
Trader Rating: 25
^^^1500
__________________
98 Trans Am Forged LS7 solid roller
25x/25x .705/.706 110 LSA
LME prepped TFS 245's 12:5:1
Tick Stage 2 rebuild and M/C W/Spec Super Twin
Vengeance ported Fast 92 with NW??
Midwest Chassis Fab 9inch 35 spline spool 4:10's
581rwhp/537rwtq
03 BUSA is offline   Reply With Quote
Old 08-13-2009, 12:20 PM   #172
brandonppr's Avatar
Trader Rating: 6
Quote:
Originally Posted by 03 BUSA View Post
^^^1500
Nice. They told me the Senergy one would only go down to 3k. I was wanting to launch off the line locks with a delay box until I get a tbrake, but I don't think they will hold 3k. This would be perfect for what I need.
Old 10-07-2009, 08:03 AM   #173
Trader Rating: 0
Default little help here
So i just got my LNC-0002 and i have a boosted application (turbo) I have it running off a momentary switch and set the rpm to 3500, if i want to build boost i need another 3-bar map with a vac source to the manifold?..ok i get that.. and do i need to hook up the orange wire also and where?
devil6rr is offline   Reply With Quote
Old 11-06-2009, 04:53 AM   #174
MY99TAWS6's Avatar
Trader Rating: 1
Are you an auto. If so you dont use antilag retarded timing to build boost just to make things safer and you could run higher timing off boost.
If you are m6 then to use antilag and two step both to build boost you would need the 3 bar map.
I find autos usually build good boost on just a two step as long as you have a good enough /high enough stall to let the turbo spool up .If you have a really slow spooling turbo on auto then you can run small shots of spray .
On the subject of how to activate my 002 was first thinking to put it on brake
and have line lock on shifter. Have on transbrake right now. But now thinking since if forget to shut off main switch and touch brakes it would seriously mess things up say all of sudden hitting the limiter. So guy would have to add that mph switch if he wanted it to shut off from mph. Not sure how much pain that one is to wire .
So think just activate two step and line lock from same button on the shifter. But not sure if how much rpm would need to do good burnouts and how high would rev when shift to second or third in burnout box. Opinions on this..? I should have bought the 003 maybe. I don't think am going to run timing or nitrous retard off this unit.
__________________
99TAWS6"DEATH WISH" :Iron 408/Aps tt, Lingenfelter GT-7 cam,Yt 1.8s,,Afr 225, Corsa catback,Fast90 /NW90,Zex direct port, Lonnies twin pump,60's(temporary),Asp,sfcs,Kyb agx,Hotchkis lcas/stb. Bmr torque arm/relo brackets,Spohn sway bars/panhard,RPM 4l80,Yank PY3400 ,Dana 60,TTM ,C5z06 brakes, HPtuners,Street pro cutout,Eboost2,Interceptor guages.
96z28 vert,97 Talon Awd Turbo ,91 talon awd auto turbo race car .
MY99TAWS6 is offline   Reply With Quote
Tags
1001, 2005, a4, auto, boost, build, control, controller, gto, launch, lingenfelter, retarding, step, timing, works
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
