Who's using it and how ya liking it. Im needing something and this looks good. Any bitches on it. I can use this in conjunction with my transbrake, Right?
__________________ 2000 Artic White SS
TEA 1.5s, FAST 90/90, X1, Braked A3, ATI 8" MRT, 4.10s 3300#s.
N/A 10.53@127.23 1.47 60'
100,000 Mile Stock 346.
1999 Hugger Orange Z28 M6
A Few Bolt-ons "Mama's Ride"
We still haven't tested the unit with the MSD coils. We don't use those coils or sell them so I am not sure when we will have a chance to test that ourselves. I have not received any feedback from any customers regarding if it does or does not work with the MSD coils.
I don't see any particular reason why it wouldn't work with the MSD coils. The only reason I put that warning in the instructions is that we haven't tested it and I don't want to claim that it works with them until we have had a chance to test it.
Quote:
Originally Posted by JaSSon
I wonder about its use with MSD coils?
__________________ Jason Haines, Project Director
Lingenfelter Performance Engineering
260-724-2552 www.lingenfelter.com
Is there a way that the box will dissable itself after launch? So there is no chance of activation down track.
__________________ 2002 Trans Am m6: stock heads and bottom end, 10.02 @ 136 on a 150 shot, 3400lbs
Tuned and built by me, welded/fabricated by Madman.
2007 Dodge Ram 2500 Q/C m6
"If it flys, floats, or fucks you're bound to have trouble with it."
Our box will not disable itself after launch, at least not on its own. You either have to have another switch in the wiring to disable it once you are moving (that you manually switch) or you need to use our MPH switch to use that to disable it once you are moving.
Our MPH switch takes in the MPH signal from the ECM/PCM and you then adjust what MPH you want it to trigger at (much like an RPM switch).
If you always stage/launch off the brake, you can also wire it to the brake switch so it is only active when the brakes are on.
Some customers have let the launch controller trigger during the shift on manual cars (when you press in the clutch to shift) and have said it helps improve the shifts and allows them to do wide open throttle shifts.
Quote:
Originally Posted by SPEEDYws6
Not to jack your thread...
thats a good idea.. but it would be a bitch on nitrous
I just don't care to have it popping off on every shift. There may come a time, maybe on a bad track, that I would have to lower the launch rpms below my shift point. Yeah I could use your speed based switch, but DAMN thats getting expesive.
Location: In the garage, working towards a 2900 lb raceweight :D
I'd actually like to pick one of these up, I just haven't figured out how it will get wired in.
I have my transbrake wired so that with the button on, the relay changes state, so the n/o contacts close when the brake is pushed on, opening the n/c contacts, which the nitrous kist is wired to. Of course the nos kit also has a wot switch that is in line with the relay as well, so that way if my foot's not to the floor, or if the transbrake is on, the kit can't come on. Master switch also has to be on as well.
mine works awesome!! Easy as hell to install. Mine triggers WITH my tbrake button. My tbrake solenoid is activated by a ground (my tbrake switch.) the 2 step is on the same switch...activated by ground. when you let go of the tbrake button, tbrake and 2 step disengage and away you go. it is a one wire hookup...EASY install. Thanks Jason for your help getting this to me last week for our track day. Jerry Hunnicutt/67convert from ebay is how you know me
__________________ 9.29 @ 150 at 14psi
3960# raceweight
OFI s488
Transformance 4l80 with rossler tbrake
408 with etp heads
3.08 rear
Yank PY3400 stall
Bmr everything
You have to have something to turn it off or the RPM cut will occur every time you achieve that RPM point. This is basically what happens when you use the device as just a spark based RPM limiter (and connect the yellow wire directly to the green wire).
So for it to be used as a launch controller it has to be connected to some type of switch to disable it - clutch switch, brake switch, manual switch etc.
Quote:
Originally Posted by MetallicaMatt
I bought this unit, but have yet to install it yet. I will be using it with my 6spd and nitrous
the initial set RPM for launch will no longer be limited once I launch correct? I don't want to have to flip it off after I get moving...?
You could add an additional clutch switch but most people wire it into the factory clutch switch.
So you leave off the line, the limiter shuts down after you release clutch. You press clutch in at 6100 to shift to second. At this point does the limiter activate again (say you are launching @ 3500-fairly low launch) and motor cuts out to 3500 until you release clutch into second gear.
If this is the case, what is the solution?
It's only going to be on the 2-step for a very short time as you'd be shifting quickly or even powershifting. That said, the engine won't mechanically slow from, your example, of 6100 rpm to 3500 rpm in that short time...what you are doing with it wired this way is effectively taking a lot of the torque load off the driveline momentarily making it easier to do WOT shifts or near to. Take care. Dave
