Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > RACING DEPARTMENT > Drag Racing Tech
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Drag Racing Tech
Rules | Safety | Setups | Hardware | Methods
Sponsored by
Improved Racing Products
Click Here
Old 05-27-2008, 05:06 PM   #1
Trader Rating: 1
Default ok a3 guys what do you do at the end of the track????
Alright i'm about tired of hearing what i SHOULD do to avoid damage to my tranny when going thru the traps..... I have heard so many things and wanted to find out what you guys do after going thru the finish line...
Tranny is a RMVB TH400 from ATI, ATI 4200 stall converter.... Some people told me to put the tranny in neutral immediately after going thru the finish line (which will require going from 3 to 2 to 1 and then N and will take awhile when I SHOULD be concentrating on slowing down....
Others have told me to leave it in 3rd, slow down and when I get the car back on the return road shift it down to 1st or 2nd depending on speed and go on about my merry way....
So what gives and why????? Something about slamming the converter or boiling fluid or overpressurizing it.... there's gotta be a right way and a wrong way and a reason and i'm looking for it...
__________________
THE OUTLAW
1995 Camaro Z28 1LE
West Coasts Fastest LT1 period..
CSM Racing Engines 383 LT1, AFR 227's, SR Cam, Jesel shaft rockers, Lunati crank, Oliver rods, sngl plane, Accufab TB, Nitrous Pro Flow plate, ATI TH400, Moser 9", FAST XFI
10.62@128 all motor
9.06@153.8, 1.35 60' ft on the bottle, 5.76 1/8th mile (aborted 8 second pass )
My youtube videos here--->http://www.youtube.com/user/tensecLT1
OutlawZ is offline   Reply With Quote
Old 05-27-2008, 05:14 PM   #2
BOOST FIEND MODERATOR!!!!
frcefed98's Avatar
Trader Rating: 15
My builder told me to brake/coast down in third and drop it into 2nd when on the return road and rpm's dropped to under 3000rpm.
So thats what i'll do whenever I get the damn bird to the track again.
__________________
98 Formula A3 RED
Turbocharged BY Frcefed98|Forced Inductions/Turbonetics|FX Coatings|Exotic Performance Plus|TC76MPS/HP76 Turbocharger|348ci Forged LS6 9.1-1 Block|Meth Injected & Intercooled|2bar SD tune|Moser 9 Spool 3.50's|TH400 RMVB TB Built by Gary Gonzales|
frcefed98 is offline   Reply With Quote
Old 05-27-2008, 05:20 PM   #3
pddye's Avatar
Trader Rating: 11
I've also wondered this. I was just going to go with the downshift at lower speeds on my new th400 but i've never been told any different. Also i've read on a few forums the correct way to do the burnout but how is everyone doing this also? Sorry for the hijack to the original poster. That is the problem with buying used parts off of guys that don't give you a lot of info on the tranny and how to use it correctly.
__________________
2000 Trans am
pddye is offline   Reply With Quote
Old 05-27-2008, 05:24 PM   #4
DanZ28's Avatar
Trader Rating: 5
I leave it in third myself. I pulled this directly from Rosslers site:
3 speed and overdrive transmissions: Caution never shift into neutral position at high speeds. This will cause internal components of the transmission to rotate 2 and ½ times faster than your finish line RPM. (Example, If your car’s finish line RPM is 7,500 RPM’S and the Transmission is shifted to neutral then the internal components will spin at 15,000 RPM’s THIS IS VERY DANGEROUS! The parts are spinning so fast, they can explode, turning your transmission into a shrapnel type bomb possibly causing bodily injury and death.
On full competition transmissions with manual valve bodies or transmission brake down shifting to second will cause the same reaction. This also is very dangerous and not recommended.
__________________
New Setup = Money Pit from hell!
DanZ28 is offline   Reply With Quote
Old 05-27-2008, 05:28 PM   #5
red83's Avatar
Trader Rating: 61
Location: sneaking in your back door as you leave!/cartersville ga
another note on the turbo 400. my builder told me not to finish a burnout in 2nd gear and let the tires grab.
__________________
THE GREAT ONE
Too many toys!!!
red83 is offline   Reply With Quote
Old 05-27-2008, 05:47 PM   #6
Trader Rating: 1
ATI fully describes the burnout as:
start tires rotating after rolling them thru the water and pulling a few feet forward of the box...
start burnout in 1st, shift to 2nd then after a few seconds shift to 3rd and drop the hammer. It then says "POWER out of the box for a few feet before letting off, do not allow the tires to snatch traction by just letting off the gas... You should continue to do a burnout after releasing the line lock or the brakes.... then close the throttle slowly instead of just releasing it abrubtly....
nothing about what to do at the end of the track..
But I just talked to my tranny builder and he concurs DO NOT shift to neutral and just leave it in 3rd till you get onto the return road....
__________________
THE OUTLAW
1995 Camaro Z28 1LE
10.62@128 all motor
Old 05-27-2008, 05:58 PM   #7
2000 Chevrolet Camaro
Camaro396's Avatar
Trader Rating: 12
Send a message via AIM to Camaro396
I have always been told to leave it in 3rd until your on return road.
__________________
LOW-TECH RACING
NBM Camaro Z28
Mineral Grey SVT Cobra
http://i664.photobucket.com/albums/vv7/faster346/sig-10.jpg
Camaro396 is offline   Reply With Quote
Old 05-27-2008, 06:05 PM   #8
RAGENZ28's Avatar
Trader Rating: 5
Burn outs, start in second gear and shift to third gear asap, then roll out of the burn out in 3rd.
After you get out of it on the top end, I leave it in 3rd and then once on the return road, I down shift to 2nd, then 1st gear and cruise to get my time slip. I was told never to down shift under power.
As far as what ATI says about not letting the tires grab, they will do that as soon as the tire speed slows down so that is unavoidable so you should be in 3rd gear when burning out.
__________________
Black 1998 Camaro Z28 Currently under construction tin can with 4 wheels
Email:CHRISTOPHERMORALES@HOTMAIL.COM
www.fquick.com/RAGEN98Z28
"Friends don't let friends drive imports"
RAGENZ28 is offline   Reply With Quote
Old 05-27-2008, 06:09 PM   #9
FIST PUMP
Trader Rating: 21
NEVER downshift a RMVB 400 without first giving it very slight throttle, just enough to make sure the car is not slowing down. Otherwise when you let off in 2nd the car turns the drum the opposite direction and the second you hit the gas it has to spin back the other way. Never slow down in second eaither.
__________________
2006 GSXR1000
dlove is offline   Reply With Quote
Old 05-27-2008, 08:01 PM   #10
DanZ28's Avatar
Trader Rating: 5
Mine doesn't actually "brake" in any gear, let off the gas is like neautral.
__________________
Old 05-27-2008, 08:06 PM   #11
red83's Avatar
Trader Rating: 61
Quote:
i think 99.999% rmvb's are like that... i think you can get them built with the engine braking feature.........i think
__________________
THE GREAT ONE
Too many toys!!!
Old 05-27-2008, 08:30 PM   #12
Smoke346's Avatar
Trader Rating: 0
In my 69 camaro I had (468BBC w/ RMVB 400), I would clean the slicks for a split sec, shift to 2nd, mash it , shift to 3rd and roll out while slowly letting off the throttle. As for the big end I would leave her in third, slow down and when around 20 mph or so, start downshifting until I was in 1st. Never had any issues doing it this way, probably ran the car that way 40 or 50 times.
Smoke346 is offline   Reply With Quote
Old 05-27-2008, 09:18 PM   #13
TwoFast4Lv's Avatar
Trader Rating: 7
Send a message via AIM to TwoFast4Lv Send a message via MSN to TwoFast4Lv
DO NOT shift to nuetral at speed, NEVER! Some brake setups WILL explode the transmission if you do! IF you do it can over drive the third gear drum until it exploded like a grenade.
Burn outs start in 2nd and go to third rolling out and lifting before you hook. If you hook you slamm the sprag inside the converter
__________________
"The Penguin"
9.82@137 1.41 60ft
Lloyd LE-X and Nitro Daves Money Maker!
TwoFast4Lv is offline   Reply With Quote
Old 05-27-2008, 10:01 PM   #14
Head Fabricator
MADMAN's Avatar
Trader Rating: 2
HMMMMMMMM maybe we need to buy a good valve body????? All the 400s I have built donot allow down shifting. The standard procedure I teach my drivers is to cross the traps and throw the chutes. Then let off the gas and put the car in nuetral. At that time shut the engine down so I can read a plug. I have 1000s of passes on cars with over 100hp engines and have yet hurt a trans. Also all my burnout start in 1st and then second then third and you roll out.
Sorry Ellis but we need to talk !!!!!!!!!!
__________________
www.madmanandcoracing.com
225-673-3533
Avoid nutswingers: for genuine Madman products, buy only from authorized dealers - http://madmanandcoracing.com/dealers.htm
World Record 60ft 1.18 on a 275 drag radial
Worlds Fastest Torque Arm F-body - 7.43 @ 188
Late Model Racecraft Quickest and Fastest LS1 on stock suspension
MADMAN is offline   Reply With Quote
Old 05-27-2008, 10:06 PM   #15
red83's Avatar
Trader Rating: 61
Quote:
Originally Posted by MADMAN View Post
HMMMMMMMM maybe we need to buy a good valve body????? All the 400s I have built donot allow down shifting. The standard procedure I teach my drivers is to cross the traps and throw the chutes. Then let off the gas and put the car in nuetral. At that time shut the engine down so I can read a plug. I have 1000s of passes on cars with over 1000hp engines and have yet hurt a trans. Also all my burnout start in 1st and then second then third and you roll out.
fixed the hp number for ya
__________________
THE GREAT ONE
Too many toys!!!
Old 05-27-2008, 10:41 PM   #16
TJ
Trader Rating: 10
ive made hundreds of passes and always shift to neutral. i dont understand how the tranny can spin twice the speed?
i dont mind learing something new.
i dont do it to save a tranny, i do it to save my motor. dont want the rods at high rpm unless they need to be.
downshifting a manual valve body is a no no unless you are under throttle.
__________________
STAGE 20
88 IROC-z/28. 408 LSx swap. 4th gen interior.
6.265@109.15 pump gas. all motor.
05 2500hd. 6.0L
one hauls, one hauls a$$.
http://i102.photobucket.com/albums/m...igpicSmall.jpg
TJ is offline   Reply With Quote
Old 05-27-2008, 11:57 PM   #17
Trader Rating: 1
my valve body doesn't let the tranny downshift that's for sure. cuz i had it on the dyno and shifted to neutral and it was fine... never downshifted....
i'm just wondering does it hurt the tranny to keep it in 3rd and just start getting on the brakes... (hard)....
__________________
THE OUTLAW
1995 Camaro Z28 1LE
10.62@128 all motor
Old 05-28-2008, 12:07 AM   #18
Trader Rating: 2
thats what I do
__________________
96 camaro,LT4 solidroller 383,single plane intake with 90mm accufab tb,afr 210cc heads,th400 with t brake 5200 ati stall,26 inch et drags
10.62@127(1.43 60ft) 6.68@102 1/8th (all motor)
3325lb race weight
http://videos.streetfire.net/video/S...-DJ_133669.htm
Dave J is offline   Reply With Quote
Old 05-28-2008, 12:12 AM   #19
Trader Rating: 2
on a rmvb how do you shift to neutral with out going to 2nd and 1st before that?
__________________
3325lb race weight
Old 05-28-2008, 12:12 AM   #20
patriotformula's Avatar
Trader Rating: 22
Send a message via AIM to patriotformula
Maybe things have changed... But I have seen tons of guys shift into neutral after going through the traps with no problem... But I have also seen 2 guys shift into neutral with a rmvb 400 to see it catch a lower gear and actually flip the car... Its up to you, but if your not reading plugs (even if you are) you need to realize you're shifting down through gears and cant trust it to not accidentally catch one...
__________________
98 Camaro SS MS4 cam only, TH400 w/ transbrake, Midwest Chassis Fabricated 9 inch
patriotformula is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
