I made 486/458 on a 383 w/ 5.3L heads. This was through a stock 78mm throttle body and LS6 intake. Certainly room for improvement with a 90mm intake setup. Also didn't have my exhaust setup optimized. Will probably dyno again in the next month or so.
460/410 six years ago with a TEA 1.5 head hand finished, 230/232 cam, stock intake, stock bottom end, all other bolt ons. The engine would have probably been worth 480rwhp with today's LSX technology (FAST intakes, new tuning methods, etc).
f body,408,ported 5.3 heads,ls6 intake and tb,pacesetter headers,12 bolt rear
__________________ www.virginiaspeed.comcustom engines for street or race,tuning,installs,fabrication. check our our online store-i'm adding new products every day http://shop.virginiaspeed.com/main.sc757-468-5101 1979 Z28 Outlaw 10.5-670bbc twin promod 94's Crew Chief,engine builder,tuner of Phil Thomas's
LSX powered Mustang"The Renegade" 7.29, 198mph-best 1/8 et.4.70 @ 164mph 315 radials at 3275lbs
My car made 512/502 with my ported 5.3 TEA stg 1.5 heads on my 408 iron block..really curious to see what a set of trickflow 235's would do on my setup
Stock shortblock LS2 , AS 5.3 heads made 455 on a Mustang dyno thru a 12 bolt,unlocked 5K stall. Should go close to 500 thru the more common 6 speed/10 bolt combo on a dyno jet. Rest of motor specs in my signature.
__________________ , Factory LS2 (364) crank, rods, pistons, N/A , A.S. 5.3 heads, LG G5X4 camshaft, FAST 90/90, Performabuilt level 3 4L60E, ARH 1 7/8's, Circle D 230mm converter, full lineup of Spohn hardware out back -- P.B.= 9.87@134.8 - 60'= 1.30 10/19/09
Speed Density Tuned by Kaltech tuning on Long Island www.kaltechtuning.com
Did this with a GM head and pump gas!
4.86 gears you running a 30 inch tire? What kinda RPM is required to get thru the beams?
