Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Dynamometer Results & Comparisons
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Old 02-01-2008, 08:55 PM   #21
2002 Chevrolet Camaro
ExceSSive's Avatar
Trader Rating: 10
Send a message via Yahoo to ExceSSive
Quote:
Originally Posted by Silver-Dollar View Post
As another option for heads, you can use LS6 (#243) heads to increase the compression ratio without milling. 317s and 243s are the same design with the exception of bowl sizes; 317 = 72cc and 243 = 66cc. The 66cc will net you around 11.1:1. WCCH does have work LS6 heads that had a 68cc bowl that can give you 10.8:1.
What do you have your shift points set to with that cam?
I am pretty sure 243s are 64cc and 241s are 66cc. Good numbers BTW. Go to the track and get the ones that count now.
__________________
00 Suburban 5.3L, 100k and going.
ExceSSive is offline   Reply With Quote
Old 02-01-2008, 10:45 PM   #22
venom ws7's Avatar
Trader Rating: 1
Quote:
Your right 243 are 64cc 241 are 66cc.
formybird
CONGRATS man these are awesome numbers and you have 1 hot Formula
__________________
01 ZO6 - Built 346ci H/C STS TT 557rwhp 535rwtq 9psi 701rwhp 669rwtq 16psi(Old Setup)
now N/A 346ci H/C 8:5.1 compression 370rwhp but not for long
venom ws7 is offline   Reply With Quote
Old 02-01-2008, 11:01 PM   #23
pj4553's Avatar
Trader Rating: 4
I am also on a budget build and i'm not too far from you. If you come across another LQ9 or even a LQ4 for that much please pm me! I've been looking for one
__________________
2006 Silverado
2000 SS M6
pj4553 is offline   Reply With Quote
Old 02-01-2008, 11:15 PM   #24
zmonsterjb's Avatar
Trader Rating: 17
Default lq9
Quote:
Originally Posted by black_z View Post
Is the stock bottom end good enough for that RPM? I just bought an 01 LQ9 today, I am trying to learn more about them.
Why wouldnt they be? The rods in the lq9 are the better than any lq4 or ls1 rod! Just put some aftermarket rodbolts in.
__________________
"TRUE POWER comes from GOD!"
zmonsterjb is offline   Reply With Quote
Old 02-03-2008, 09:11 AM   #25
AINT SKEERED's Avatar
Trader Rating: 1
Hey mark, good numbers. This is Chad , i worked with you a few weeks ago.
My lq9 is going in my nova soon and with a very simular set up as yours , except I decided to go carbed. Same cam you are running (only because I am getting it free) and maybe getting a set of 243's for a killer deal. Good luck and hope it works out for you. Hopefully you can get your idle straight, You will more then likely need another tuner for that though.
__________________
2000 nbm T/A
best 60 on Nittos= 1.644 on 315x35x17 nittos
Best ET: 11.38@121.3 mph 1.62 60 ft . 3700 lbs race weight
1.59 best 60 on m/t drag radials
64ChevyII race car with 347 ls1. 10.68@124 1.53 60 ft.
AINT SKEERED is offline   Reply With Quote
Old 04-15-2008, 05:52 PM   #26
formybird's Avatar
Trader Rating: 0
Quote:
I bought mine from latino motors in Donaldsonville. Sometimes he'll have a few LQ4s and the occasional LQ9.Sometimes time he wont have any.Luck of the draw.He'll deal with you also if he has one. Heres the number if ya intrested.
Latino motors (225) 473-8601. I also have an older number. 717-1711
Also google maps shows a different location than where i went too..Maybe they moved.Not sure.Same area though.lol
__________________
01 Formula 6.0 A3......Toy. 11.5@122 n/a.New nitrous times soon!!
1995 Tercel...............Work car.slow@slow
2007 Mustang GT.....Girlfriends ride.13.4@101
formybird is offline   Reply With Quote
Old 04-15-2008, 06:07 PM   #27
formybird's Avatar
Trader Rating: 0
Thanks Chad.The 6.0 is still alive though i have some electrical gremlins.I keep popping the engine sensor fuses.It pops right when i crank it.So of course thats why my idle is crap.
Ive replaced the o2s and the o2 extension harnesses.The passenger side o2never did read even when the fuse had worked.Must be in the main harness.Fun Fun.
I also bought the PTC frmv th350/ss3600 i mentioned to ya.I'll deal without overdrive.It'll be worth it . Its not in the car yet though.Just saving for the BMR conversion crossmember torque arm mount.
Ill deal with the sensor mess after its installed.lol.And then maybe one day everything will work well long enough to run her at the track.
__________________
Old 04-15-2008, 08:50 PM   #28
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Trader Rating: 91
Time to put the car on a diet. Other than that it everything looks nice.
Beaflag VonRathburg is offline   Reply With Quote
Old 09-25-2008, 09:31 PM   #29
Trader Rating: 15
And what does it do at the track now?
__________________
1998 6 speed Camaro
Nine sets of heads, and seven different cams!
8.8" hybrid build COMPLETED... 3-channel compatible.
See pictures here,
http://web.camaross.com/forums/showthread.php?t=434580
Studytime is offline   Reply With Quote
Old 09-29-2008, 09:36 AM   #30
SIC LSX's Avatar
Trader Rating: 9
Send a message via AIM to SIC LSX
find you some cheep stock ls6 heads and pick up another 15-20
__________________
99 m6 Z28
11 sec club & cam only
Quote:
Originally Posted by 98Z28CobraKiller View Post
turbos and glides go together like vaginas and penises
SIC LSX is offline   Reply With Quote
Old 09-29-2008, 09:37 AM   #31
SIC LSX's Avatar
Trader Rating: 9
Quote:
When i get my a lq9 im going to do that
__________________
99 m6 Z28
Old 09-29-2008, 09:43 AM   #32
SIC LSX's Avatar
Trader Rating: 9
I love how the 6.0's make torq! I have seen 346ci make 470-500whp but only 400-415 trq
__________________
99 m6 Z28
Old 09-29-2008, 09:46 AM   #33
99ta's Avatar
Trader Rating: 8
Quote:
Over ported and milled 6.0 heads???????????????
__________________
Casey 2005 GMC Sierra
5.3 ECSB, Sand Beige Metallic
AEM Dry Flow, OBX Long Tubes, 3in Cutout, Magnaflow Muffler, Patriot Dual Springs, FLT Level 4 4l60e(BROKEN P.O.S.), TB Converter
99ta is online now   Reply With Quote
Old 09-29-2008, 11:07 AM   #34
SIC LSX's Avatar
Trader Rating: 9
whoops missed that part. Just thought they were some stock 6.0 heads with dual springs lol
__________________
99 m6 Z28
Old 10-06-2008, 11:24 PM   #35
Trader Rating: 0
Not only that I'm pretty sure the LQ9 heads flow just as good as the LS6 heads.
ss454327 is offline   Reply With Quote
Old 10-08-2008, 04:15 AM   #36
formybird's Avatar
Trader Rating: 0
Quote:
Still havent been.Cars not quite ready yet Got the th350 put in and Dustin has the stock shifter at the moment so he can mod it to work with the rev pattern.After that im getting some relocation brackets and hopefully she'll hook so i can get some numbers.Still have some other odds n ends but that should be enough too make a pass.Cant come soon enough the girlfriends stang is starting to feel fast again....lol
__________________
Old 02-22-2009, 10:22 PM   #37
formybird's Avatar
Trader Rating: 0
Update on budget 6.0 .Finally got it to a track.Link
New to the club...
__________________
Old 02-23-2009, 07:12 AM   #38
Trader Rating: 13
That cam is the same as the TSP torquer 2, right? How does the engine feel down low?
__________________
Up and wiping!
GMCtrk is offline   Reply With Quote
Old 02-23-2009, 09:10 AM   #39
Trader Rating: 1
cam is only the same at .050 as the tsp cam. much different everywhere else.
I have this cam and it feel ok down low but the f13 is better down low, this one pulls to a higher rpm. Both have there place.
If you like a lot of tq down low, the 13 is for you. above 4000 , this one is better then the 13 but still not a slouch below 4000 rpms. I have used both
__________________
2000 nbm T/A
Old 02-23-2009, 09:12 AM   #40
Trader Rating: 1
Quote:
New to the club...
what tires was this on ? you should run 11.3's or so with a little better traction. mph could be a little higher for the hp you posted but still doing pretty good for the first time to the track.
__________________
2000 nbm T/A
Tags
500whp, 60l, budget, build, cam, chart, dyno, head, horsepower, hp, lq9, numbers, patriot, radix, stock, tuned
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
